查看: 4420|回復: 0
Arduino 開關計數器控制兩個LED神燈
ID:118080 發表于 2016-5-3 10:16 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最后由 shanzhiyuan123 于 2016-5-3 12:51 編輯
Hi,大家好。小弟是新人發帖, 我想做一個Project 用Arduino記錄兩個開關的按鍵次數并且用LCD顯示出來,如果哪個按鍵次數多,哪個led神燈就亮。時間限制大概在一分鐘左右。 也就是說一分鐘之后比較兩個開關的按鍵次數借此來決定打開哪個LED燈。有大神有代碼嗎?
這是計時器的代碼:
#include <LiquidCrystal.h>
LiquidCrystal lcd(7,8,9,10,11,12);
int runTimer = 1;
int runFor = 20; // time in seconds
int buzzerPin = 13;
int relayPin=4;
int data = 0;
void setup() {
   pinMode(buzzerPin, OUTPUT);
   pinMode(relayPin,OUTPUT);
   lcd.begin(16, 2);
void loop() {
   if(runTimer == 1){
      digitalWrite(relayPin,LOW); // relay is OFF during countdown
      lcd.clear();
      lcd.print("TIMER=");
      //Start timer
      timer();
   runTimer = 0;
   lcd.noDisplay();
   delay(250);
   for(int duration = 0; duration < 100; duration ++){
      digitalWrite(buzzerPin, HIGH);
      delayMicroseconds(500);
      digitalWrite(buzzerPin, LOW);
   lcd.display();
   delay(250);
void timer() {
   for(int timer = runFor;timer > 0; --timer){
   if(timer >= 10) {
      lcd.setCursor(6,0);
   } else {
      lcd.setCursor(6,0);
      lcd.print("0");
      lcd.setCursor(7,0);
   lcd.print(timer);
   lcd.print(" SECOND!");
   delay(1000);
   lcd.setCursor(0,0);
   lcd.clear();
   lcd.print(" TIMER OUT!");
這是記錄開關按鍵次數的代碼:
const int switchPin = 5;
int hits = 0;
int switchState = 0;
int prevSwitchState = 0;
const int switchPin1 = 6;
int hits1 = 0;
int switchState1 = 0;
int prevSwitchState1 = 0;
void setup() {
  // set up the number of columns and rows on the LCD
  lcd.begin(16, 2);
  pinMode(switchPin,INPUT);
  lcd.clear();
  lcd.setCursor(0, 0);
  lcd.print("Hit the button");
  pinMode(switchPin1,INPUT);
  lcd.clear();
void loop() {
  switchState = digitalRead(switchPin);
  if (switchState != prevSwitchState) {
    if (switchState == LOW) {
      hits = hits + 1;
      lcd.clear();
      lcd.setCursor(0, 1);
      lcd.print("Hits:");
      lcd.setCursor(7, 1);
      lcd.print(hits);
      lcd.setCursor(11, 1);
      lcd.print(hits1);
      delay(90);
   prevSwitchState = switchState;
  switchState1 = digitalRead(switchPin1);
  if (switchState1 != prevSwitchState1) {
    if (switchState1 == LOW) {
      hits1 = hits1 + 1;
      lcd.clear();
      lcd.print("Hits:");
      lcd.print(hits1);
      lcd.print(hits);
      delay(90);
  prevSwitchState1 = switchState1;
我想把這部分代碼組合到一起, 在倒計時的同時記錄兩個開關的按鍵次數。 當倒計時結束時,停止兩個開關的計數。不知道怎么做,總是一個工作另外一個就不工作。。求大神解答
