查看: 5959|回復: 2
PI3USB14引腳圖,真值表,管腳功能與電路圖 USB快速切換開關芯片資料
PI3USB14是一個4路高帶寬 USB快速切換開關
Features
•    Near-Zero propagation delay
•    5Ω switches connect inputs to outputs
•  High signal passing bandwidth (300MHz)
•  Beyond Rail-to-Rail switching
•  5V I/O tolerant with 3.3V supply
•  2.5V and 3.3V supply voltage operation
•  Hot insertion capable
•  Industrial operating temperature: -40ºC to +85ºC
•  2KV ESD Protection (human body model)
•  Latch-up performance >250mA per JESD17
•    Packaging (Pb-free & Green available):
– 16-pin 150-mil wide plastic QSOP (Q)
– 16-pin 173-mil wide plastic TSSOP (L)
– 20-contact TQFN (ZH)
PI3USB14引腳圖:
PI3USB14結構圖
PI3USB14真值表:
PI3USB14管腳功能:
PI3USB14應用電路:
PI3USB14芯片的pdf資料下載地址:
PI3USB14_datasheet.pdf (475.3 KB, 下載次數: 8)
ID:1 發表于 2017-6-3 20:19 | 只看該作者
好資料,51黑有你更精彩!!!
好資料,51黑有你更精彩!!!
