查看: 3724|回復(fù): 0
當(dāng)距離變化過快這個(gè)程序就不執(zhí)行電機(jī)的程序了,測(cè)量和顯示還是可以進(jìn)行的
ID:194551 發(fā)表于 2017-5-28 18:44 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
附上程序
#include "reg52.h"
#include "intrins.h"
typedef unsigned char BYTE;
typedef unsigned int WORD;
#define FOSC 12000000L          //系統(tǒng)頻率
#define BAUD 115200             //串口波特率
#define Busy    0x80 //用于檢測(cè)LCM狀態(tài)字中的Busy標(biāo)識(shí)
//////液晶屏數(shù)據(jù)口///////
sbit LCM_RS  =P2^0;//定義液晶屏信號(hào)引腳
sbit LCM_RW  =P2^1;
sbit LCM_E   =P2^2;
#define LCM_Data  P0//液晶數(shù)端口
unsigned char code uctech[] = {"0123456789ABCDEF:"};
sfr AUXR  = 0x8e;               //輔助寄存器
#define T1MS (65536-FOSC/8000)      //1000MS模式
sbit ONA                =P2^3;//電機(jī)1A
sbit ONB                =P2^4;//電機(jī)1B
sbit ONC                =P2^6;//電機(jī)2A
sbit OND                =P2^7;//電機(jī)2B
sbit Echo1              =P3^2;//超聲波數(shù)據(jù)
sbit Trig1              =P2^5;//超聲波啟動(dòng)
void delay(unsigned int z)//延時(shí)
   unsigned int x,y;
    for(x=z;x>0;x--)
        for(y=110;y>0;y--);
//1ms延時(shí)
void Delay5Ms(void)
   delay(5);
void WriteDataLCM(unsigned char WDLCM)
//ReadStatusLCM(); //檢測(cè)忙
LCM_RS = 1;
LCM_Data = WDLCM;
Delay5Ms();
LCM_RW = 0;
LCM_E = 1; //若晶振速度太高可以在這后加小的延時(shí)
Delay5Ms();
LCM_E = 0; //延時(shí)
//寫指令
void WriteCommandLCM(unsigned char WCLCM,BuysC) //BuysC為0時(shí)忽略忙檢測(cè)
//if (BuysC) ReadStatusLCM(); //根據(jù)需要檢測(cè)忙
LCM_RS = 0;
LCM_Data = WCLCM;
Delay5Ms();
LCM_RW = 0;
LCM_E = 1;
Delay5Ms();
LCM_E = 0;
#if 0
//讀數(shù)據(jù)
unsigned char ReadDataLCM(void)
LCM_RS = 1;
LCM_RW = 1;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
return(LCM_Data);
//讀狀態(tài)
unsigned char ReadStatusLCM(void)
LCM_Data = ~0xFF;
LCM_RS = 0;
LCM_RW = 1;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
while (LCM_Data & Busy); //檢測(cè)忙信號(hào)
return(LCM_Data);
#endif
void LCMInit(uchar i) //LCM初始化
LCM_Data = 0;
WriteCommandLCM(0x38,0); //三次顯示模式設(shè)置,不檢測(cè)忙信號(hào)
Delay5Ms();
Delay5Ms();
Delay5Ms();
WriteCommandLCM(0x38,1); //顯示模式設(shè)置,開始要求每次檢測(cè)忙信號(hào)
WriteCommandLCM(0x08,1); //關(guān)閉顯示
WriteCommandLCM(0x01,1); //顯示清屏
WriteCommandLCM(0x06,1); // 顯示光標(biāo)移動(dòng)設(shè)置
WriteCommandLCM(i,1); // 顯示開及光標(biāo)設(shè)置
void LCMInitc(uchar i)
WriteCommandLCM(0x06,0); //光標(biāo)歸位
WriteCommandLCM(i,0); //關(guān)光標(biāo),閃爍
//按指定位置顯示一個(gè)字符
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData,uchar i)
Y &= 0x1;
X &= 0xF; //限制X不能大于15,Y不能大于1
if (Y) X |= 0x40; //當(dāng)要顯示第二行時(shí)地址碼+0x40;
X |= 0x80; // 算出指令碼
WriteCommandLCM(X,0); //這里不檢測(cè)忙信號(hào),發(fā)送地址碼
LCMInitc(i);
Delay5Ms();
LCMInitc(0x0c);
WriteDataLCM(DData);
//按指定位置顯示一串字符
void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData)
unsigned char ListLength;
  ListLength = 0;
Y &= 0x1;
while (DData[ListLength]>0x20) //若到達(dá)字串尾則退出
   if (X <= 0xF) //X坐標(biāo)應(yīng)小于0xF
     DisplayOneChar(X, Y,DData[ListLength],0x0c); //顯示單個(gè)字符
     ListLength++;
     X++;
void tim0init()
    //AUXR |= 0x80;                   //定時(shí)器0為1T模式
    TMOD = 0x00;                    //設(shè)置定時(shí)器為模式0(16位自動(dòng)重裝載)
    TL0 = 0x66;                  //初始化計(jì)時(shí)值
    TH0 = 0xfc;
    TR0 = 1;                        //定時(shí)器0開始計(jì)時(shí)
    ET0 = 1;                        //使能定時(shí)器0中斷
     TMOD|=0x11;                   //設(shè)T1為方式1,GATE=1;
         EA=1;                           //開啟總中斷
         TH1=0;
         TL1=0;
         ET1=1;             //允許T1中斷
         TR1=0;
     EA = 1;
WORD U16FLAG;
unsigned int time_c,Dista1;
unsigned char timeH,timeL;
bit succeed_flag;
void  StartModule()
//    unsigned int distance;
     #if 1
         Trig1=1;   //啟動(dòng)模塊
         delay(1);
         Trig1=0;
     U16FLAG=58477;
     while((!Echo1)&&U16FLAG++);
     TR1=1;                            //開啟計(jì)數(shù)
     U16FLAG=58477;
     while((Echo1)&&U16FLAG++);
     TR1=0;
         time_c=TH1*256+TL1;
         TH1=0;
         TL1=0;
         Dista1=(time_c*1.7)/100;//算出來是CM
         delay(50);
         #endif
void timer1() interrupt 3 using 1
  TH0=0;
  TL0=0;                                                         //中斷溢出標(biāo)志
uint tim0[20];
//定時(shí)器中斷
void tm0_isr() interrupt 1 using 1
        tim0[0]++;
   if(Dista1>110)//加速正轉(zhuǎn)
   tim0[3]=(Dista1-80);
   tim0[2]=65536-FOSC/(tim0[3]*200);
        TL0=tim0[2];
        TH0=tim0[2]>>8;
        switch(tim0[0])
          case 1: ONA=0;ONB=1;ONC=1;OND=1;break;
          case 2: ONA=1;ONB=0;ONC=1;OND=1;break;
          case 3: ONA=1;ONB=1;ONC=0;OND=1;break;
          case 4: ONA=1;ONB=1;ONC=1;OND=0;tim0[0]=0; break;
   if(Dista1>80&&Dista1<140)//勻速正轉(zhuǎn)
     tim0[2]=65536-FOSC/3000;
        TL0=tim0[2];
        TH0=tim0[2]>>8;
        switch(tim0[0])
    else if(Dista1<=20)//加速反轉(zhuǎn)
       tim0[3]=(50-Dista1) ;
          TL0=tim0[2];
          TH0=tim0[2]>>8;
      switch(tim0[0])
          case 1: ONA=1;ONB=1;ONC=0;OND=1;break;
          case 3: ONA=0;ONB=1;ONC=1;OND=1;break;
          case 4: ONA=1;ONB=1;ONC=1;OND=0;tim0[0]=0;break;
  else if(Dista1<=50)//勻速反轉(zhuǎn)
          TL0=tim0[2];
          TH0=tim0[2]>>8;
      switch(tim0[0])
  else if(Dista1>50&&Dista1<80)//不轉(zhuǎn)
    ONA=1;ONB=1;ONC=1;OND=1;
    tim0[0]=0;
   else if(Dista1>140)//         勻速轉(zhuǎn)
         tim0[2]=65536-FOSC/6000;
        TL0=tim0[2];
        TH0=tim0[2]>>8;
        switch(tim0[0])
    tim0init();
        LCMInit(0x0c); //LCM初始化
    Delay5Ms(); //延時(shí)片刻(可不要
    DisplayListChar(8, 1,"C");//在指定,列顯示字符串
           DisplayListChar(9, 1,"M");//在指定,列顯示字符串
          StartModule();
          DisplayOneChar(4,1,uctech[Dista1/1000%10],0x0c);//顯示個(gè)位
      DisplayOneChar(5,1,uctech[Dista1/100%10],0x0c);//顯示個(gè)位
      DisplayOneChar(6,1,uctech[Dista1/10%10],0x0c);//顯示個(gè)位
      DisplayOneChar(7,1,uctech[Dista1%10],0x0c);//顯示個(gè)位
相關(guān)帖子
