查看: 7929|回復: 0
LPC2124流水燈及閃爍燈proteus仿真和源碼
分享一個LPC2124芯片做的流水燈及閃爍燈的proteus仿真,下面是原理圖:
源碼:
  1. /****************************************Copyright (c)**************************************************
  2. **                               Guangzou ZLG-MCU Development Co.,LTD.
  3. **                                      graduate school
  4. **
  5. **--------------File Info-------------------------------------------------------------------------------
  6. ** File name:                        main.c
  7. ** Last modified Date:  2004-09-16
  8. ** Last Version:                1.0
  9. ** Descriptions:                The main() function example template
  10. **
  11. **------------------------------------------------------------------------------------------------------
  12. ** Created by:                        Chenmingji
  13. ** Created date:                2004-09-16
  14. ** Version:                                1.0
  15. ** Descriptions:                The original version
  16. **
  17. **------------------------------------------------------------------------------------------------------
  18. ** Modified by:
  19. ** Modified date:
  20. ** Version:
  21. ** Descriptions:
  22. **
  23. ********************************************************************************************************/
  24. #include"config.h"
  25. /*延時子函數*/
  26. void  delay(uint32 z)
  27. {
  28.         uint32  i;
  29.         for(;z>0;z--)
  30.                 for(i=0;i<50000;i++);
  31. }
  32. /*初始化IO口子程序*/
  33. void  sys_init()
  34. {
  35.         PINSEL0=0X00000000;
  36.         PINSEL1=0X00000000;//所有半端口接到GPIO
  37.
  38.         IO0DIR=1<<17|1<<18|1<<19|1<<20;//設為輸出方式
  39.         IO0SET=1<<17|1<<18|1<<19|1<<20;//設為高電平
  40.
  41. }
  42. //*主程序*/
  43. int  main()
  44. {
  45.         sys_init();//調用初始化IO口子程序
  46.         while(1)
  47.         {
  48.                 IO0CLR=1<<17;//輸出低電平
  49.                 delay(20);
  50.                 IO0SET=1<<17;//輸也高電平
  51.                 delay(20);
  52.
  53.                 IO0CLR=1<<18;
  54.                 delay(20);
  55.                 IO0SET=1<<18;
  56.                 delay(20);
  57.
  58.
  59.                 IO0CLR=1<<19;
  60.                 delay(20);
  61.                 IO0SET=1<<19;
  62.                 delay(20);
  63.                 IO0CLR=1<<20;
  64.                 delay(20);
  65.                 IO0SET=1<<20;
  66.                 delay(20);
  67.         }
  68. }
  69. /*********************************************************************************************************
  70. **                            End Of File
  71. ********************************************************************************************************/
所有資料下載:
LED燈閃爍仿真 流水燈仿真.rar (280.16 KB, 下載次數: 53)
LPC2124_LED.rar (110.76 KB, 下載次數: 44)
