仿真工程文件及所有完整程序等資料下載地址:
http://www.raoushi.com/bbs/dpj-56304-1.html
源程序:
- This program was produced by the
- CodeWizardAVR V1.23.8c Standard
- Project : SKYT
- Version : 0.01
- Date : 2006-12-6
- Author : hlchen
- Company :
- Comments:
- 數控云臺
- Chip type : ATmega8
- Program type : Application
- Clock frequency : 3.690000 MHz
- Memory model : Small
- External SRAM size : 0
- Data Stack size : 256
- typedef unsigned char uchar;
- typedef unsigned int uint;
- #include <mega8.h>
- #include <math.h>
- #include "macro.h"
- #include "LCD.h"
- //#include "sed1565_s.h"
- #define RXB8 1
- #define TXB8 0
- #define UPE 2
- #define OVR 3
- #define FE 4
- #define UDRE 5
- #define RXC 7
- #define Light 5
- #define FRAMING_ERROR (1<<FE)
- #define PARITY_ERROR (1<<UPE)
- #define DATA_OVERRUN (1<<OVR)
- #define DATA_REGISTER_EMPTY (1<<UDRE)
- #define RX_COMPLETE (1<<RXC)
- #define sysInitLcd 0
- // USART Receiver buffer
- #define RX_BUFFER_SIZE 8
- char rx_buffer[RX_BUFFER_SIZE];
- unsigned char rx_wr_index,rx_rd_index,rx_counter;
- // This flag is set on USART Receiver buffer overflow
- bit rx_buffer_overflow,b_ComEnable;
- uchar uc_syssta;
- // USART Receiver interrupt service routine
- #pragma savereg-
- interrupt [USART_RXC] void uart_rx_isr(void)
- char status,data;
- #asm
- push r26
- push r27
- push r30
- push r31
- in r26,sreg
- push r26
- #endasm
- status=UCSRA;
- data=UDR;
- if ((status & (FRAMING_ERROR | PARITY_ERROR | DATA_OVERRUN))==0)
- rx_buffer[rx_wr_index]=data;
- if (++rx_wr_index == RX_BUFFER_SIZE) rx_wr_index=0;
- if (++rx_counter == RX_BUFFER_SIZE)
- rx_counter=0;
- rx_buffer_overflow=1;
- if ((rx_buffer[0]=='o')&&(rx_buffer[1]=='k')) b_ComEnable=1;
- #asm
- pop r26
- out sreg,r26
- pop r31
- pop r30
- pop r27
- pop r26
- #endasm
- #pragma savereg+
- #ifndef _DEBUG_TERMINAL_IO_
- // Get a character from the USART Receiver buffer
- #define _ALTERNATE_GETCHAR_
- #pragma used+
- char getchar(void)
- char data;
- while (rx_counter==0);
- data=rx_buffer[rx_rd_index];
- if (++rx_rd_index == RX_BUFFER_SIZE) rx_rd_index=0;
- #asm("cli")
- --rx_counter;
- #asm("sei")
- return data;
- #pragma used-
- #endif
- // USART Transmitter buffer
- #define TX_BUFFER_SIZE 8
- char tx_buffer[TX_BUFFER_SIZE];
- unsigned char tx_wr_index,tx_rd_index,tx_counter;
- // USART Transmitter interrupt service routine
- #pragma savereg-
- interrupt [USART_TXC] void uart_tx_isr(void)
- #asm
- push r26
- push r27
- push r30
- push r31
- in r26,sreg
- push r26
- #endasm
- if (tx_counter)
- --tx_counter;
- UDR=tx_buffer[tx_rd_index];
- if (++tx_rd_index == TX_BUFFER_SIZE) tx_rd_index=0;
- #asm
- pop r26
- out sreg,r26
- pop r31
- pop r30
- pop r27
- pop r26
- #endasm
- #pragma savereg+
- // Write a character to the USART Transmitter buffer
- #define _ALTERNATE_PUTCHAR_
- #pragma used+
- void putchar(char c)
- while (tx_counter == TX_BUFFER_SIZE);
- #asm("cli")
- if (tx_counter || ((UCSRA & DATA_REGISTER_EMPTY)==0))
- tx_buffer[tx_wr_index]=c;
- if (++tx_wr_index == TX_BUFFER_SIZE) tx_wr_index=0;
- ++tx_counter;
- else UDR=c;
- #asm("sei")
- #pragma used-
- #endif
- // Standard Input/Output functions
- #include <stdio.h>
- uchar ucInputValue;
- uint uiLastADValue[3];
- uchar ucInputParam0;
- uchar ucChannelN,uc_ReceiveSta;
- bit bInputChange,bMotorSpeed,bLight,bReceiveOpend;
- void inputdeal(void);
- void TransmitEnable(void);
- void ReceiveEnable(void);
- void Communication(void);
- void LcdShow(void);
- #define HighSpeed 0x33
- #define SlowSpeed 0x99
- #define ADC_VREF_TYPE 0x00
- #define RE 0
- #define DE 1
- // ADC interrupt service routine
- interrupt [TIM0_OVF] void timer0_ovf_isr(void)
- // Place your code here
- TCNT0=0xf0;
- interrupt [ADC_INT] void adc_isr(void)
- uint adc_data;
- // Read the AD conversion result
- adc_data=ADCW;
- switch (ucChannelN)
- case 0:
- if (uiLastADValue[0]!=adc_data)
- uiLastADValue[0]=adc_data;
- ucInputParam0=uiLastADValue[0]*24/1024;
- //ucInputParam0 = tmp/100;
- //ucInputParam1 = (tmp%100)/10;
- //ucInputParam2 = (tmp%100)%10;
- bInputChange=1;
- ucInputValue=0x01;
- ADMUX=0x01;
- break;
- case 1:
- if (uiLastADValue[1]!=adc_data)
- uiLastADValue[1]=adc_data;
- ucInputParam0=uiLastADValue[1]*12/1024;
- bInputChange=1;
- ucInputValue=0x02;
- ADMUX=0x02;
- break;
- case 2:
- if (uiLastADValue[2]!=adc_data)
- uiLastADValue[2]=adc_data;
- //ucInputParam0=uiLastADValue[2]*6/1024;
- if (abs(uiLastADValue[2]-1023)<100)
- ucInputValue=3;
- else if (abs(uiLastADValue[2]-465)<50)
- ucInputValue=4;
- else if (abs(uiLastADValue[2]-292)<25)
- ucInputValue=5;
- else if (abs(uiLastADValue[2]-204)<25)
- ucInputValue=6;
- else if (abs(uiLastADValue[2]-146)<12)
- ucInputValue=7;
- else if (abs(uiLastADValue[2]-93)<12)
- ucInputValue=8;
- else if (abs(uiLastADValue[2])<6)
- ucInputValue=9;
- else break;
- // else if (abs(uiLastADValue[2]-512
- bInputChange=1;
- // ucInputValue=ucInputParam0+2;
- ADMUX=0x00;
- break;
- default:
- break;
- ADCSRA|=0x40;
- //ADMUX^=0x01;
- if (ucChannelN++==3) ucChannelN=0;
- // Declare your global variables here
- void main(void)
- // Declare your local variables here
- uint i;
- // Input/Output Ports initialization
- // Port B initialization
- // Func0=Out Func1=Out Func2=Out Func3=Out Func4=Out Func5=Out Func6=Out Func7=Out
- // State0=0 State1=0 State2=0 State3=0 State4=0 State5=0 State6=0 State7=0
- PORTB=0x00;
- DDRB=0xFF;
- // Port C initialization
- PORTC=0x00;
- DDRC=0xff;
- // Port D initialization
- PORTD=0x00;
- DDRD=0x73;
- // Timer/Counter 0 initialization
- // Clock source: System Clock
- // Clock value: 3690.000 kHz
- TCCR0=0x03;
- TCNT0=0xf0;
- // Timer/Counter 1 initialization
- // Clock value: Timer 1 Stopped
- // Mode: Normal top=FFFFh
- // OC1A output: Discon.
- // OC1B output: Discon.
- // Noise Canceler: Off
- // Input Capture on Falling Edge
- //模式1(計數器上限值=0xff) PWM頻率 = 系統時鐘頻率/(分頻系數*2*計數器上限值))
- TCCR1A=0x00;
- //COM1A1,COM1A0,COM1B1,COM1B0=1表示升序記數時比較匹配將置位OC1A/OC1B,降序記數時比較匹配將清零OC1A/OC1B
- //即OCR1AL<tcnt1<TOP(0xff)時 OC1A為高 tcnt1<OCR1AL時OC1A為低
- //WGM11=0 WGM10=1
- TCCR1B=0x00;
- //WGM13=0 WGM12=0 CS12=1 CS11=0 CS10=0 分頻系數=256
- TCNT1H=0x00;
- TCNT1L=0x00;
- OCR1AH=0x00;
- OCR1AL=0x00; //占空比=40% (0xff-0x99)/0xff=0.4
- //占空比=80% 0x33
- OCR1BH=0x00;
- OCR1BL=0x00;
- // Timer/Counter 2 initialization
- // Clock value: Timer 2 Stopped
- // Mode: Normal top=FFh
- // OC2 output: Disconnected
- ASSR=0x00;
- TCCR2=0x00;
- TCNT2=0x00;
- OCR2=0x00;
- // External Interrupt(s) initialization
- // INT0: Off
- // INT1: Off
- GICR|=0x00;
- MCUCR=0x00;
- // Timer(s)/Counter(s) Interrupt(s) initialization
- TIMSK=0X01;
- // USART initialization
- // Communication Parameters: 8 Data, 1 Stop, No Parity
- // USART Receiver: On
- // USART Transmitter: On
- // USART Mode: Asynchronous
- // USART Baud rate: 1200
- UCSRA=0x00;
- UCSRB=0xD8;
- UCSRC=0x86;
- UBRRH=0x00;
- UBRRL=0x33;
- // Analog Comparator initialization
- // Analog Comparator: Off
- // Analog Comparator Input Capture by Timer/Counter 1: Off
- // Analog Comparator Output: Off
- ACSR=0x80;
- SFIOR=0x00;
- // ADC initialization
- // ADC Clock frequency: 115.313 kHz
- // ADC Voltage Reference: AREF pin
- // ADC High Speed Mode: Off
- // ADC Auto Trigger Source: Timer0 Overflow
- ADMUX=0x00;
- ADCSRA=0x00;
- //SFIOR&=0x0F;
- //SFIOR|=0x80;
- // Global enable interrupts
- InitLCD();
- #asm("sei")
- TransmitEnable();
- printf("Ready?");
- for (i=0;i<10000;i++);
- while (1)
- if (tx_counter==0) ReceiveEnable();
- if (b_ComEnable)
- b_ComEnable=0;
- LcdShow();
- break;
- while(1)
- //inputdeal();
- Show_Circle();
- Show_HalfCircle();
- Show_Preset();
- Show_Slow();
- PORTB|=Bit(RE);
- PORTB|=Bit(DE);
- PORTB&=Bit(RE);
- PORTB&=Bit(DE);
- void TransmitCommandOk(void)
- //if (uc_syssta==sysInitLcd)
- // LcdShow();
- switch (uc_ReceiveSta)
- case 0:
- if (getchar()=='R')
- uc_ReceiveSta++;
- else if (getchar()=='O')
- uc_ReceiveSta++;
- break;
- case 1:
- if (getchar()=='e')
- uc_ReceiveSta++;
- else if (getchar()=='k')
- uc_ReceiveSta=0;
- b_ComEnable=1;
- else
- uc_ReceiveSta=0;
- break;
- case 2:
- if (getchar()=='a')
- uc_ReceiveSta++;
- else
- uc_ReceiveSta=0;
- break;
- case 3:
- if (getchar()=='d')
- uc_ReceiveSta++;
- else
- uc_ReceiveSta=0;
- break;
- case 4:
- uc_ReceiveSta=0;
- if (getchar()=='y')
- printf("ok");
- break;
- if (!bInputChange) return;
- bInputChange=0;
- switch (ucInputValue)
- case 0x01:
- //printf("%bu,%bu,%bu\n",ucInputParam0,ucInputParam1,ucInputParam2);
- // PaintDegree(ucInputParam0,0);
- break;
- case 0x02:
- // PaintDegree(ucInputParam0,1);
- break;
- case 0x03://key1
- if (!bLight) PORTB|=Bit(Light);
- else PORTB&=~Bit(Light);
- bLight=!bLight;
- PORTD|=0x04;
- break;
- case 0x04://key2
- // PORTD&=0xc3;
- PORTD|=0x08;
- // if (bMotorSpeed) {Show_Slow();OCR1AL=SlowSpeed;}
- // else {Show_Quick();OCR1AL=HighSpeed;}
- bMotorSpeed=!bMotorSpeed;
- break;
- case 0x05://key3
- // PORTD&=0xc3;
- PORTD|=0x0c;
- break;
- case 0x06://key4
- // PORTD&=0xc3;
- PORTD|=0x10;
- break;
- case 0x07://key5
- // PORTD&=0xc3;
- PORTD|=0x14;
- break;
- case 0x08://key6
- //PORTD&=0xc3;
- PORTD|=0x18;
- break;
- case 0x09://keyrelease
- PORTD&=0xc3;
- break;
- default:
- break;
