查看: 3078|回復: 0
程序人生 —— SQL Server函數(shù)小記
ID:83710 發(fā)表于 2015-6-25 15:16 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
1、多行拼接成一列(FOR XML PATH)
DECLARE @t_Temp TABLE
        id VARCHAR(100)
INSERT INTO @t_Temp VALUES ('ID1')
INSERT INTO @t_Temp VALUES ('ID2')
INSERT INTO @t_Temp VALUES ('ID3')
INSERT INTO @t_Temp VALUES ('ID4')
INSERT INTO @t_Temp VALUES ('ID5')
SELECT id + ','
        FROM @t_Temp
        FOR XML PATH('')
2、截取并插入新字符串(STUFF)
SELECT STUFF('入庫貨位1,出庫貨位1,入庫貨位2,出庫貨位2,', 1, 2, '123')
3、數(shù)據(jù)分頁(ROW_NUMBER())
        id VARCHAR(100)
SElECT *
        FROM (SELECT ROW_NUMBER() OVER(ORDER BY id) AS ROW,*
        FROM @t_Temp) T WHERE T.ROW BETWEEN 1 AND 2
待續(xù)...
