查看: 5971|回復: 1
幫看一眼這個程序錯在哪 為什么輸出頻率與顯示的不一致
ID:186199 發(fā)表于 2017-6-2 21:05 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg51.h>
#include<intrins.h>
#include<string.h>
//--LCD¿ØÖÆòy½Å
sbit RS=P3^0;
sbit RW=P3^1;
sbit EN=P3^3;
//--°′¼ü
sbit K1=P2^0;
sbit K2=P2^1;
sbit K3=P2^2;
sbit K4=P2^3;
sbit K5=P2^4;
uchar WaveChoice=0;
float ys=30;
uchar i,a=0;
uchar sqar_num=128;
uint freq;
uchar code Sin[]={"Sine      "};
//uchar code exp[]={"Exp      "};
uchar code Squ[]={"Square    "} ;
uchar code Tri[]={"Triangle  "};
uchar code Saw[]={"Sawtooth  "} ;
uchar code No[]={"No OutPut"};
uchar code Wave[]={"Wave :"};
uchar code Fre[]={"Freq :"};
uchar code tosin[256]=
0x80,0x83,0x86,0x89,0x8d,0x90,0x93,0x96,0x99,0x9c,0x9f,0xa2,0xa5,0xa8,0xab,
0xae,0xb1,0xb4,0xb7,0xba,0xbc,0xbf,0xc2,0xc5,0xc7,0xca,0xcc,0xcf,0xd1,0xd4,
0xd6,0xd8,0xda,0xdd,0xdf,0xe1,0xe3,0xe5,0xe7,0xe9,0xea,0xec,0xee,0xef,0xf1,
0xf2,0xf4,0xf5,0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfd,0xfd,0xfe,0xff,0xff,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfd,0xfd,0xfc,0xfb,
0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,0xf4,0xf2,0xf1,0xef,0xee,0xec,0xea,0xe9,0xe7,
0xe5,0xe3,0xe1,0xde,0xdd,0xda,0xd8,0xd6,0xd4,0xd1,0xcf,0xcc,0xca,0xc7,0xc5,
0xc2,0xbf,0xbc,0xba,0xb7,0xb4,0xb1,0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x99,
0x96,0x93,0x90,0x8d,0x89,0x86,0x83,0x80,0x80,0x7c,0x79,0x76,0x72,0x6f,0x6c,
0x69,0x66,0x63,0x60,0x5d,0x5a,0x57,0x55,0x51,0x4e,0x4c,0x48,0x45,0x43,0x40,
0x3d,0x3a,0x38,0x35,0x33,0x30,0x2e,0x2b,0x29,0x27,0x25,0x22,0x20,0x1e,0x1c,
0x1a,0x18,0x16,0x15,0x13,0x11,0x10,0x0e,0x0d,0x0b,0x0a,0x09,0x08,0x07,0x06,
0x05,0x04,0x03,0x02,0x02,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x01,0x02,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,
0x0d,0x0e,0x10,0x11,0x13,0x15,0x16,0x18,0x1a,0x1c,0x1e,0x20,0x22,0x25,0x27,
0x29,0x2b,0x2e,0x30,0x33,0x35,0x38,0x3a,0x3d,0x40,0x43,0x45,0x48,0x4c,0x4e,
0x51,0x55,0x57,0x5a,0x5d,0x60,0x63,0x66,0x69,0x6c,0x6f,0x72,0x76,0x79,0x7c,
0x80}; //ÕyÏò2¨Âë
//--Ñóê±MS
void DelayMS(uchar ms)
        uchar i;
        while(ms--)                for(i=0;i<120;i++);
//--Ñóê±y*9us
void Delay1(uint y)
        uint i;
        for(i=y;i>0;i--);
//Ã|¼ì2é
uchar Busy_Check()
        uchar LCD_Status;
        RS=0;  //        ¼Ä′æÆ÷Ñ¡Ôñ
        RW=1; //¶á×′쬼Ä′æÆ÷
        EN=1;  // ¿aê¼¶á
        DelayMS(1);
        LCD_Status=P1;
        EN=0;
        return  LCD_Status;
//D′LCDÃüáî
void Write_LCD_Command(uchar cmd)
           while((Busy_Check()&0x80)==0x80);   //Ã|μè′y
           RS=0;  //Ñ¡ÔñÃüáî¼Ä′æÆ÷
           RW=0;  //D′
           EN=0;
           P1=cmd;
           EN=1;
           DelayMS(1);
           EN=0;
//·¢Ëíêy¾Y
void Write_LCD_Data(uchar dat)
          RS=1;
    RW=0;
          EN=0;
          P1=dat;
          EN=1;
          DelayMS(1);
          EN=0;
//LCD3õê¼»ˉ
void Init_LCD()
        Write_LCD_Command(0x38);
        DelayMS(1);
        Write_LCD_Command(0x01); //ÇåÆá
        DelayMS(1);
        Write_LCD_Command(0x06); //×Ö·û½øèëģ꽣oÆáÄ»2»¶ˉ£¬×Ö·ûoóòÆ
        DelayMS(1);
        Write_LCD_Command(0x0C); //ÏÔ꾿a¡¢1Ø1a±ê
        DelayMS(1);
//--ÏòLCDD′ÆμÂêÖμ
void Write_freq(uint k)
        uchar qian,bai,shi,ge;
        qian=k/1000;
        bai=k/100%10;
        shi=k/10%10;
        ge=k%10;
        Write_LCD_Command(0x86+0x40);
        Write_LCD_Data(0x30+qian);
        Write_LCD_Data(0x30+bai);
        Write_LCD_Data(0x30+shi);
        Write_LCD_Data(0x30+ge);
        Write_LCD_Data(0x48);
        Write_LCD_Data(0x5a);
//--LCDéÏÏÔê¾2»í¬2¨DÎÆμÂê
  void Xianshi_f()
  if(WaveChoice==1)
    freq=(10000000/(50000+2860*ys));
         Write_freq(freq);
  if(WaveChoice==2)
     freq=(10000000/(50000+2300*ys));
         Write_freq(freq);
   if(WaveChoice==3)
     freq=(10000000/(14000+2300*ys));
         Write_freq(freq);
    if(WaveChoice==4)
     freq=(10000000/(15000+2300*ys));
         Write_freq(freq);
//--LCDéÏD′2¨DÎààDí
void Write_wave(uchar  t )
        switch(t)
                case 0:
                                //-- ÎTêä3ö
                                 Write_LCD_Command(0x86);
                                   DelayMS(5);
                                    for (i=0;i<sizeof(No)-1;i++)
                                                Write_LCD_Data(No);
                                                DelayMS(5);
                                        break;
                case 1:
                                //--ÕyÏò2¨
                                ys=25;
                                   DelayMS(5);
                                    for (i=0;i<sizeof(Sin)-1;i++)
                                                Write_LCD_Data(Sin);
                                                DelayMS(5);
                                break;
                case 2:
                                //---¾ØDÎ2¨
                                ys=30;
                                   DelayMS(5);
                                    for (i=0;i<sizeof(Squ)-1;i++)
                                                Write_LCD_Data(Squ);
                                                DelayMS(5);
                                break;
                case 3:
                                //---èy½Ç2¨
                                ys=30;
                                   DelayMS(5);
                                    for (i=0;i<sizeof(Tri)-1;i++)
                                                Write_LCD_Data(Tri);
                                                DelayMS(5);
                                break;
                case 4:
                                //----¾a3Y2¨
                                   ys=30;
                                   Write_LCD_Command(0x86);//òo¾§ÏÔê¾Î»ÖÃ
                                   DelayMS(5);
                                    for (i=0;i<sizeof(Saw)-1;i++)
                                                Write_LCD_Data(Saw);
                                                DelayMS(5);
                                break;
//---êä3ö2¨DÎ
void Out_Wave(uchar i)
{         uchar j;
        switch(i)
                case 0:        P0=0x00;break;
                case 1:
                                //---ÕyÏò2¨
                                for (j=0;j<255;j++)
                                        P0=tosin[j];
                                        Delay1(ys);
                                 break;
                case 2:
                                //----¾ØDÎ2¨
                                        if(a<sqar_num)
                                                        P0=0xff;
                                                        Delay1(ys);
                                                        P0=0x00;
                                                        Delay1(ys);
                                                a++;
                                }  break;
                case 3:
                                //----èy½Ç2¨
                                        if(a<128)
                                                        P0=a;
                                                        Delay1(ys);
                                                        P0=255-a;
                                                        Delay1(ys);
                                                a++;
                                }   break;
                case 4:
                           //----¾a3Y2¨
                                         if(a<255)
                                                P0=a;
                                                Delay1(ys);
                                a++;
                        if(a==255)
                                        a=0;
                                }   break;
//----°′¼üé¨Ãè
void keyscanf()
        if(K2==0)
                DelayMS(5);
                if(K2==0)
                        while(!K2);
                        ys--;
                        if(ys==0)
                        ys=20;
        if(K3==0)
                DelayMS(5);
                if(K3==0)
                        while(!K3);
                        ys++;
                        if(ys>22)
                        ys=20;
        if(K4==0)
                DelayMS(5);
                if(K4==0)
                        while(!K4);
                        if(WaveChoice==2)
                        sqar_num=sqar_num+2;
                        if(sqar_num==238)
                                sqar_num=128;
        if(K5==0)
                DelayMS(5);
                if(K5==0)
                        while(!K5);
                        if(WaveChoice==2)
                        sqar_num=sqar_num-2;
                        if(sqar_num==18)
                                sqar_num=128;
//----Ö÷3ìDò---
        Init_LCD();
        IE=0X81;
        IT0=1;
        Write_LCD_Command(0x80);//--ÏÔê¾wave:
           DelayMS(5);
   for (i=0;i<sizeof(Wave)-1;i++)
                        Write_LCD_Data(Wave);
                        DelayMS(5);
            Write_LCD_Command(0x80+0X40);//----ÏÔê¾freq:
     DelayMS(5);
    for (i=0;i<sizeof(Fre)-1;i++)
                        Write_LCD_Data(Fre);
                        DelayMS(5);
           Write_wave(WaveChoice);
        while (1)
                         keyscanf();
                Out_Wave(WaveChoice);
                if(!(K1&K2&K3))
                                Xianshi_f();
//---INT0ÖD¶Ï
void EX_INT0() interrupt 0
                WaveChoice++;
                if(WaveChoice==5) WaveChoice=1;
ID:276332 發(fā)表于 2018-1-29 10:28 | 只看該作者
看你的輸出模塊跟顯示模塊參數(shù)了
