- * $Id:: i2cslave.c 3635 2010-06-02 00:31:46Z usb00423 $
- * Project: NXP LPC11xx I2C Slave example
- * Description:
- * This file contains I2C slave code example which include I2C slave
- * initialization, I2C slave interrupt handler, and APIs for I2C slave
- * access.
- * Software that is described herein is for illustrative purposes only
- * which provides customers with programming information regarding the
- * products. This software is supplied "AS IS" without any warranties.
- * NXP Semiconductors assumes no responsibility or liability for the
- * use of the software, conveys no license or title under any patent,
- * copyright, or mask work right to the product. NXP Semiconductors
- * reserves the right to make changes in the software without
- * notification. NXP Semiconductors also make no representation or
- * warranty that such application will be suitable for the specified
- * use without further testing or modification.
- #include "LPC11xx.h"/* LPC11xx Peripheral Registers */
- #include "type.h"
- #include "i2cslave.h"
- volatile uint32_t I2CMasterState = I2C_IDLE;
- volatile uint32_t I2CSlaveState = I2C_IDLE;
- volatile uint32_t I2CMode;
- volatile uint8_t I2CWrBuffer[BUFSIZE];
- volatile uint8_t I2CRdBuffer[BUFSIZE];
- volatile uint32_t I2CReadLength;
- volatile uint32_t I2CWriteLength;
- volatile uint32_t RdIndex = 0;
- volatile uint32_t WrIndex = 0;
- From device to device, the I2C communication protocol may vary,
- in the example below, the protocol uses repeated start to read data from or
- write to the device:
- For master read: the sequence is: STA,Addr(W),offset,RE-STA,Addr(r),data...STO
- for master write: the sequence is: STA,Addr(W),offset,RE-STA,Addr(w),data...STO
- Thus, in state 8, the address is always WRITE. in state 10, the address could
- be READ or WRITE depending on the I2C command.
- ** Function name:I2C_IRQHandler
- ** Descriptions:I2C interrupt handler, deal with master mode only.
- ** parameters:None
- ** Returned value:None
- void I2C_IRQHandler(void)
- uint8_t StatValue;
- /* this handler deals with master read and master write only */
- StatValue = LPC_I2C->STAT;
- switch ( StatValue )
- case 0x60:/* An own SLA_W has been received. */
- case 0x68:
- RdIndex = 0;
- LPC_I2C->CONSET = I2CONSET_AA;/* assert ACK after SLV_W is received */
- LPC_I2C->CONCLR = I2CONCLR_SIC;
- I2CSlaveState = I2C_WR_STARTED;
- break;
- case 0x80:/* data receive */
- case 0x90:
- if ( I2CSlaveState == I2C_WR_STARTED )
- I2CRdBuffer[RdIndex++] = LPC_I2C->DAT;
- LPC_I2C->CONSET = I2CONSET_AA;/* assert ACK after data is received */
- else
- LPC_I2C->CONCLR = I2CONCLR_AAC;/* assert NACK */
- break;
- case 0xA8:/* An own SLA_R has been received. */
- case 0xB0:
- RdIndex = 0;
- LPC_I2C->CONSET = I2CONSET_AA;/* assert ACK after SLV_R is received */
- I2CSlaveState = I2C_RD_STARTED;
- WrIndex = I2CRdBuffer[0];/* The 1st byte is the index. */
- break;
- case 0xB8:/* Data byte has been transmitted */
- case 0xC8:
- if ( I2CSlaveState == I2C_RD_STARTED )
- LPC_I2C->DAT = I2CRdBuffer[WrIndex+1];/* write the same data back to master */
- WrIndex++;/* Need to skip the index byte in RdBuffer */
- LPC_I2C->CONSET = I2CONSET_AA;/* assert ACK */
- else
- break;
- case 0xC0:/* Data byte has been transmitted, NACK */
- I2CSlaveState = DATA_NACK;
- break;
- case 0xA0:/* Stop condition or repeated start has */
- LPC_I2C->CONSET = I2CONSET_AA;/* been received, assert ACK. */
- I2CSlaveState = I2C_IDLE;
- break;
- default:
- LPC_I2C->CONSET = I2CONSET_I2EN | I2CONSET_SI;
- break;
- return;
- ** Function name:I2CSlaveInit
- ** Descriptions:Initialize I2C controller
- ** parameters:I2c mode is either MASTER or SLAVE
- ** Returned value:true or false, return false if the I2C
- **interrupt handler was not installed correctly
- void I2CSlaveInit( void )
- /* SSP and I2C reset are overlapped, a known bug,
- for now, both SSP and I2C use bit 0 for reset enable.
- Once the problem is fixed, change to "#if 1". */
- #if 1
- LPC_SYSCON->PRESETCTRL |= (0x1<<1);
- #else
- LPC_SYSCON->PRESETCTRL |= (0x1<<0);
- #endif
- LPC_SYSCON->SYSAHBCLKCTRL |= (1<<5);
- LPC_IOCON->PIO0_4 &= ~0x3F;/* I2C I/O config */
- LPC_IOCON->PIO0_4 |= 0x01;/* I2C SCL */
- LPC_IOCON->PIO0_5 &= ~0x3F;
- LPC_IOCON->PIO0_5 |= 0x01;/* I2C SDA */
- /*--- Clear flags ---*/
- LPC_I2C->CONCLR = I2CONCLR_AAC | I2CONCLR_SIC | I2CONCLR_STAC | I2CONCLR_I2ENC;
- /*--- Reset registers ---*/
- #if FAST_MODE_PLUS
- LPC_IOCON->PIO0_4 |= (0x1<<9);
- LPC_IOCON->PIO0_5 |= (0x1<<9);
- LPC_I2C->SCLL = I2SCLL_HS_SCLL;
- LPC_I2C->SCLH = I2SCLH_HS_SCLH;
- #else
- LPC_I2C->SCLL = I2SCLL_SCLL;
- LPC_I2C->SCLH = I2SCLH_SCLH;
- #endif
- LPC_I2C->ADR0 = PCF8594_ADDR;
- /* Enable the I2C Interrupt */
- NVIC_EnableIRQ(I2C_IRQn);
- return;
- ** End Of File
- * $Id:: i2cslave.h 3635 2010-06-02 00:31:46Z usb00423 $
- * Description:
- * This file contains I2C slave code header definition.
- #ifndef __I2CSLAVE_H
- #define __I2CSLAVE_H
- #define FAST_MODE_PLUS 1
- #define BUFSIZE 6
- #define MAX_TIMEOUT 0x00FFFFFF
- #define PCF8594_ADDR 0xA0
- #define READ_WRITE 0x01
- #define RD_BIT 0x01
- #define I2C_IDLE 0
- #define I2C_STARTED 1
- #define I2C_RESTARTED 2
- #define I2C_REPEATED_START 3
- #define DATA_ACK 4
- #define DATA_NACK 5
- #define I2C_WR_STARTED 6
- #define I2C_RD_STARTED 7
- #define I2CONSET_I2EN (0x1<<6) /* I2C Control Set Register */
- #define I2CONSET_AA (0x1<<2)
- #define I2CONSET_SI (0x1<<3)
- #define I2CONSET_STO (0x1<<4)
- #define I2CONSET_STA (0x1<<5)
- #define I2CONCLR_AAC (0x1<<2) /* I2C Control clear Register */
- #define I2CONCLR_SIC (0x1<<3)
- #define I2CONCLR_STAC (0x1<<5)
- #define I2CONCLR_I2ENC (0x1<<6)
- #define I2DAT_I2C 0x00000000 /* I2C Data Reg */
- #define I2ADR_I2C 0x00000000 /* I2C Slave Address Reg */
- #define I2SCLH_SCLH 0x00000180 /* I2C SCL Duty Cycle High Reg */
- #define I2SCLL_SCLL 0x00000180 /* I2C SCL Duty Cycle Low Reg */
- #define I2SCLH_HS_SCLH 0x00000020 /* Fast Plus I2C SCL Duty Cycle High Reg */
- #define I2SCLL_HS_SCLL 0x00000020 /* Fast Plus I2C SCL Duty Cycle Low Reg */
- extern void I2C_IRQHandler( void );
- extern void I2CSlaveInit( void );
- #endif /* end __I2CSLAVE_H */
- ** End Of File
- * $Id:: i2cslvtst.c 3635 2010-06-02 00:31:46Z usb00423 $
- * Project: NXP LPC11xx I2C example
- * Description:
- * This file contains I2C slave test modules, main entry, to test I2C
- * slave APIs.
- #include "type.h"
- extern volatile uint8_t I2CWrBuffer[BUFSIZE];
- extern volatile uint8_t I2CRdBuffer[BUFSIZE];
- extern volatile uint32_t I2CSlaveState;
- extern volatile uint32_t I2CReadLength, I2CWriteLength;
- ** Main Function main()
- int main (void)
- uint32_t i;
- SystemInit();
- for ( i = 0; i < BUFSIZE; i++ )
- I2CRdBuffer[i] = 0x00;
- I2CSlaveInit();/* initialize I2c */
- /* When the NACK occurs, the master has stopped the
- communication. Just check the content of I2CRd/WrBuffer. */
- while ( I2CSlaveState != DATA_NACK );
- return 0;
- ** End Of File
