查看: 4834|回復: 1
寫好的超聲波測距代碼,請大神給加一個語音播報模塊,在線等,急求!!!
ID:188856 發表于 2017-6-6 09:31 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
5黑幣
#include <reg52.h>                 //μ÷óÃμ¥Ƭ»úí·Îļt
#define uchar unsigned char  //ÎT·ûoÅ×Ö·ûDí o궨òå        ±äá¿·¶Î§0~255
#define uint  unsigned int         //ÎT·ûoÅÕûDí o궨òå        ±äá¿·¶Î§0~65535
#include <intrins.h>
#include "eeprom52.h"
//êyÂë1ü¶ÎÑ¡¶¨òå      0     1    2    3    4    5        6         7          8           9
uchar code smg_du[]={0x28,0xee,0x32,0xa2,0xe4,0xa1,0x21,0xea,0x20,0xa0,
                                           0x60,0x25,0x39,0x26,0x31,0x71,0xff};         //¶ÏÂë
uchar dis_smg[8]   ={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8};
//êyÂë1üλѡ¶¨òå
sbit smg_we1 = P3^4;            //êyÂë1üλѡ¶¨òå
sbit smg_we2 = P3^5;
sbit smg_we3 = P3^6;
sbit smg_we4 = P3^7;
sbit c_send   = P3^2;                //3¬éù2¨·¢éä
sbit c_recive = P3^3;                //3¬éù2¨½óêÕ
sbit beep = P2^3;   //·äÃùÆ÷IO¿ú¶¨òå
uchar smg_i = 3;    //ÏÔê¾êyÂë1üμĸöλêy
bit flag_300ms ;
long distance;                //¾ààë
uint set_d;                    //¾ààë
uchar flag_csb_juli;    //3¬éù2¨3¬3öá¿3ì
uint  flag_time0;       //óÃà′±£′æ¶¨ê±Æ÷0μÄê±oòμÄ
uchar menu_1;           //2Ëμ¥éè¼Æμıäá¿
/***********************1msÑóê±oˉêy*****************************/
void delay_1ms(uint q)
        uint i,j;
        for(i=0;i<q;i++)
                for(j=0;j<120;j++);
/***********************′|àí¾ààëoˉêy****************************/
void smg_display()
        dis_smg[0] = smg_du[distance % 10];
        dis_smg[1] = smg_du[distance / 10 % 10];
        dis_smg[2] = smg_du[distance / 100 % 10] & 0xdf; ;
/******************°Ñêy¾Y±£′æμ½μ¥Ƭ»úÄú2¿eepromÖD******************/
void write_eeprom()
        SectorErase(0x2000);
        byte_write(0x2000, set_d % 256);
        byte_write(0x2001, set_d / 256);
        byte_write(0x2058, a_a);
/******************°Ñêy¾Y′óμ¥Ƭ»úÄú2¿eepromÖD¶á3öà′*****************/
void read_eeprom()
        set_d  = byte_read(0x2001);
        set_d <<= 8;
        set_d  |= byte_read(0x2000);
        a_a      = byte_read(0x2058);
/**************¿a»ú×Ô¼ìeeprom3õê¼»ˉ*****************/
void init_eeprom()
        read_eeprom();                //Ïè¶á
        if(a_a != 1)                //DÂμÄμ¥Ƭ»ú3õê¼μ¥Ƭ»úÄúÎêeeprom
                set_d = 50;
                a_a = 1;
                write_eeprom();           //±£′æêy¾Y
/********************¶àᢰ′¼ü3ìDò*****************/
uchar key_can;         //°′¼üÖμ
void key()         //¶àᢰ′¼ü3ìDò
        static uchar key_new;
        key_can = 20;                   //°′¼üÖμ»1Ô-
        P2 |= 0x07;
        if((P2 & 0x07) != 0x07)                //°′¼ü°′ÏÂ
                delay_1ms(1);                     //°′¼üÏû¶¶¶ˉ
                if(((P2 & 0x07) != 0x07) && (key_new == 1))
                {                                                //è·èÏêǰ′¼ü°′ÏÂ
                        key_new = 0;
                        switch(P2 & 0x07)
                                case 0x06: key_can = 3; break;           //μÃμ½k2¼üÖμ
                                case 0x05: key_can = 2; break;           //μÃμ½k3¼üÖμ
                                case 0x03: key_can = 1; break;           //μÃμ½k4¼üÖμ
                key_new = 1;
/****************°′¼ü′|àíÏÔê¾oˉêy***************/
void key_with()
        if(key_can == 1)                //éèÖüü
                menu_1 ++;
                if(menu_1 >= 2)
                        menu_1 = 0;
                        smg_i = 3;                //Ö»ÏÔê¾3λêyÂë1ü
                if(menu_1 == 1)
                        smg_i = 4;           //Ö»ÏÔê¾4λêyÂë1ü
        if(menu_1 == 1)                        //éèÖñ¨¾ˉ
                if(key_can == 2)
                        set_d ++ ;                //¼ó1
                        if(set_d > 400)
                                set_d = 400;
                if(key_can == 3)
                        set_d -- ;                //¼õ1
                        if(set_d <= 1)
                                set_d = 1;
                dis_smg[0] = smg_du[set_d % 10];                   //è¡D¡êyÏÔê¾
                dis_smg[1] = smg_du[set_d / 10 % 10] ;         //衸öλÏÔê¾
                dis_smg[2] = smg_du[set_d / 100 % 10] & 0xdf ; //è¡ê®Î»ÏÔê¾
                dis_smg[3] = 0x60;                //a
/****************±¨¾ˉoˉêy***************/
void clock_h_l()
        static uchar value;
        if(distance <= set_d)
                value ++;  //Ïû3yêμ¼ê¾ààëÔúé趨¾ààë×óóò±ä»ˉê±μĸéèÅ
                if(value >= 2)
                        beep = ~beep;           //·äÃùÆ÷±¨¾ˉ
                value = 0;
                beep = 1;                //è¡Ïû±¨¾ˉ
/***********************êyÂëλѡoˉêy*****************************/
void smg_we_switch(uchar i)
        switch(i)
                case 0: smg_we1 = 0;  smg_we2 = 1; smg_we3 = 1;  smg_we4 = 1; break;
                case 1: smg_we1 = 1;  smg_we2 = 0; smg_we3 = 1;  smg_we4 = 1; break;
                case 2: smg_we1 = 1;  smg_we2 = 1; smg_we3 = 0;  smg_we4 = 1; break;
                case 3: smg_we1 = 1;  smg_we2 = 1; smg_we3 = 1;  smg_we4 = 0; break;
/***********************êyÂëÏÔê¾oˉêy*****************************/
void display()
        static uchar i;
        i++;
        if(i >= smg_i)
                i = 0;
        smg_we_switch(i);                 //λѡ
        P1 = dis_smg[i];                 //¶ÎÑ¡
/******************D¡Ñóê±oˉêy*****************/
void delay()
        _nop_();                            //Ö′DDò»ìõ_nop_()Ö¸áî¾íêÇ1us
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
/*********************3¬éù2¨2a¾à3ìDò*****************************/
void send_wave()
        c_send = 1;                           //10usμĸßμçÆ½′¥·¢
        delay();
        c_send = 0;
        TH0 = 0;                          //¸ø¶¨ê±Æ÷0Çåáã
        TL0 = 0;
        TR0 = 0;                                  //1ض¨ê±Æ÷0¶¨ê±
        while(!c_recive);                  //μ±c_reciveÎaáãê±μè′y
        TR0=1;
        while(c_recive)                      //μ±c_reciveÎa1¼Æêy2¢μè′y
                flag_time0 = TH0 * 256 + TL0;
                if((flag_time0 > 40000))      //μ±3¬éù2¨3¬1y2aá¿·¶Î§ê±£¬ÏÔê¾3¸ö888
                        TR0 = 0;
                        flag_csb_juli = 2;
                        distance = 888;
                        break ;
                        flag_csb_juli = 1;
        if(flag_csb_juli == 1)
                TR0=0;                                                         //1ض¨ê±Æ÷0¶¨ê±
                distance =flag_time0;                         //¶á3ö¶¨ê±Æ÷0μÄê±¼ä
                distance *= 0.017;               // 0.017 = 340M / 2 = 170M = 0.017M Ëã3öà′êÇÃ×
                if((distance > 500))                                 //¾ààë = Ëù¶è * ê±¼ä
                        distance = 888;                                 //èç1û′óóú3.8m¾í3¬3ö3¬éù2¨μÄá¿3ì
/*********************¶¨ê±Æ÷0¡¢¶¨ê±Æ÷13õê¼»ˉ******************/
void time_init()
        EA  = 1;                   //¿a×üÖD¶Ï
        TMOD = 0X11;          //¶¨ê±Æ÷0¡¢¶¨ê±Æ÷11¤×÷·½ê½1
        ET0 = 0;                  //1ض¨ê±Æ÷0ÖD¶Ï
        TR0 = 1;                  //ÔêDí¶¨ê±Æ÷0¶¨ê±
        ET1 = 1;                  //¿a¶¨ê±Æ÷1ÖD¶Ï
        TR1 = 1;                  //ÔêDí¶¨ê±Æ÷1¶¨ê±
/***************Ö÷oˉêy*****************/
        beep = 0;                 //¿a»ú½Dò»éù
        delay_1ms(150);
        P0 = P1 = P2 = P3 = 0xff;           //3õê¼»ˉμ¥Ƭ»úIO¿úÎa¸ßμçÆ½
        send_wave();        //2a¾ààëoˉêy
        smg_display();        //′|àí¾ààëÏÔê¾oˉêy
        time_init();        //¶¨ê±Æ÷3õê¼»ˉ3ìDò
        init_eeprom();  //¿aê¼3õê¼»ˉ±£′æμÄêy¾Y
                if(flag_300ms == 1)
                        flag_300ms = 0;
                        clock_h_l();    //±¨¾ˉoˉêy
                        if(beep == 1)
                        if(menu_1 == 0)
                key();                                         //°′¼üoˉêy
                if(key_can < 10)
                        key_with();                         //°′¼ü′|àíoˉêy
/*********************¶¨ê±Æ÷1ÖD¶Ï·tÎñ3ìDò************************/
void time1_int() interrupt 3
        static uchar value;                         //¶¨ê±2msÖD¶Ïò»′Î
        TH1 = 0xf8;
        TL1 = 0x30;     //2ms
        display();                //êyÂë1üÏÔê¾oˉêy
        value++;
        if(value >= 150)
                value = 0;
                flag_300ms = 1;
//////EEPRO52.h
#ifndef _EEPROM52_H_
#define _EEPROM52_H_
uchar a_a;
/********STC89C51éèÇø·Ö2¼*******
μúò»éèÇø£o1000H--11FF
μú¶téèÇø£o1200H--13FF
μúèyéèÇø£o1400H--15FF
μúËÄéèÇø£o1600H--17FF
μúÎåéèÇø£o1800H--19FF
μúáùéèÇø£o1A00H--1BFF
μúÆßéèÇø£o1C00H--1DFF
μú°ËéèÇø£o1E00H--1FFF
/********STC89C52éèÇø·Ö2¼*******
μúò»éèÇø£o2000H--21FF
μú¶téèÇø£o2200H--23FF
μúèyéèÇø£o2400H--25FF
μúËÄéèÇø£o2600H--27FF
μúÎåéèÇø£o2800H--29FF
μúáùéèÇø£o2A00H--2BFF
μúÆßéèÇø£o2C00H--2DFF
μú°ËéèÇø£o2E00H--2FFF
#define RdCommand 0x01 //¶¨òåISPμÄ2ù×÷Ãüáî
#define PrgCommand 0x02
#define EraseCommand 0x03
#define Error 1
#define Ok 0
#define WaitTime 0x01 //¶¨òåCPUμÄμè′yê±¼ä
sfr ISP_DATA=0xe2;  //¼Ä′æÆ÷éêÃ÷
sfr ISP_ADDRH=0xe3;
sfr ISP_ADDRL=0xe4;
sfr ISP_CMD=0xe5;
sfr ISP_TRIG=0xe6;
sfr ISP_CONTR=0xe7;
/* ================ ′ò¿a ISP,IAP 1|Äü ================= */
void ISP_IAP_enable(void)
         EA = 0;       /* 1ØÖD¶Ï   */
         ISP_CONTR = ISP_CONTR & 0x18;       /* 0001,1000 */
         ISP_CONTR = ISP_CONTR | WaitTime; /* D′èëó2¼tÑóê± */
         ISP_CONTR = ISP_CONTR | 0x80;       /* ISPEN=1  */
/* =============== 1Ø±Õ ISP,IAP 1|Äü ================== */
void ISP_IAP_disable(void)
         ISP_CONTR = ISP_CONTR & 0x7f; /* ISPEN = 0 */
         ISP_TRIG = 0x00;
         EA   =   1;   /* ¿aÖD¶Ï */
/* ================ 1«óÃμÄ′¥·¢′úÂë ==================== */
void ISPgoon(void)
         ISP_IAP_enable();   /* ′ò¿a ISP,IAP 1|Äü */
         ISP_TRIG = 0x46;  /* ′¥·¢ISP_IAPÃüáî×Ö½ú1 */
         ISP_TRIG = 0xb9;  /* ′¥·¢ISP_IAPÃüáî×Ö½ú2 */
         _nop_();
/* ==================== ×Ö½ú¶á ======================== */
unsigned char byte_read(unsigned int byte_addr)
        EA = 0;
         ISP_ADDRH = (unsigned char)(byte_addr >> 8);/* μØÖ·¸3Öμ */
         ISP_ADDRL = (unsigned char)(byte_addr & 0x00ff);
         ISP_CMD   = ISP_CMD & 0xf8;   /* Çå3yμí3λ  */
         ISP_CMD   = ISP_CMD | RdCommand; /* D′èë¶áÃüáî */
         ISPgoon();       /* ′¥·¢Ö′DD  */
         ISP_IAP_disable();    /* 1رÕISP,IAP1|Äü */
         EA  = 1;
         return (ISP_DATA);    /* ·μ»Ø¶áμ½μÄêy¾Y */
/* ================== éèÇø2á3y ======================== */
void SectorErase(unsigned int sector_addr)
         unsigned int iSectorAddr;
         iSectorAddr = (sector_addr & 0xfe00); /* è¡éèÇøμØÖ· */
         ISP_ADDRH = (unsigned char)(iSectorAddr >> 8);
         ISP_ADDRL = 0x00;
         ISP_CMD = ISP_CMD & 0xf8;   /* Çå¿Õμí3λ  */
         ISP_CMD = ISP_CMD | EraseCommand; /* 2á3yÃüáî3  */
/* ==================== ×Ö½úD′ ======================== */
void byte_write(unsigned int byte_addr, unsigned char original_data)
         EA  = 0;
//         SectorErase(byte_addr);
         ISP_ADDRH = (unsigned char)(byte_addr >> 8);  /* è¡μØÖ·  */
         ISP_CMD  = ISP_CMD & 0xf8;    /* Çåμí3λ */
         ISP_CMD  = ISP_CMD | PrgCommand;  /* D′Ãüáî2 */
         ISP_DATA = original_data;   /* D′èëêy¾Y×¼±¸ */
         ISP_IAP_disable();     /* 1رÕIAP1|Äü */
         EA =1;
#endif
ID:82765 發表于 2017-6-6 10:39 來自觸屏版 | 只看該作者
提示: 作者被禁止或刪除 內容自動屏蔽
