查看: 5582|回復(fù): 1
超聲波測距模塊程序和原理圖
ID:212924 發(fā)表于 2017-6-20 21:56 | 顯示全部樓層 |閱讀模式
#include <reg52.H>//器件配置文件
#include <intrins.h>
//傳感器接口
sbit RX  = P3^2;
sbit TX  = P3^3;
//按鍵聲明
sbit S1  = P1^4;
sbit S2  = P1^5;
sbit S3  = P1^6;
//蜂鳴器
sbit Feng= P2^0;
sbit W1=P1^0;
sbit W2=P1^1;
sbit W3=P1^2;
sbit W4=P1^3;
//變量聲明
unsigned int  time=0;
unsigned int  timer=0;
unsigned char posit=0;
unsigned long S=0;
unsigned long BJS=50;//報(bào)警距離80CM
//模式 0正常模式 1調(diào)整
char Mode=0;
bit  flag=0;
bit flag_KEY=0;
unsigned char const discode[] ={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x40,0xff/*-*/}; //數(shù)碼管顯示碼0123456789-和不顯示
//unsigned char const positon[4]={0xfd,0xfb,0xf7,0xfe}; //位選
unsigned char disbuff[4]    ={0,0,0,0};   //數(shù)組用于存放距離信息
unsigned char disbuff_BJ[4] ={0,0,0,0};//報(bào)警信息
void Display();
//延時(shí)20ms(不精確)
void delay(void)
    unsigned char a,b,c;
    for(c=2;c>0;c--)
        for(b=38;b>0;b--)
            for(a=60;a>0;a--);
//按鍵掃描
void Key_()
if(flag_KEY==0)
  if(Mode!=0)
   if(S1==0)
    delay();    //延時(shí)去抖
    if(S1==0)
     BJS++;  //報(bào)警值加
     flag_KEY=1;
     if(BJS>=151) //最大151
      BJS=0;
//     while(S1==0)
//     Display();
   if(S2==0)
    delay();
    if(S2==0)
     BJS--;  //報(bào)警值減
     flag_KEY=1;
     if(BJS<=1)  //最小1
      BJS=150;
//     while(S2==0)
//     Display();
  //功能
  if(S3==0)  //設(shè)置鍵
   delay();
   if(S3==0)
    Mode++;  //模式加
    flag_KEY=1;
    if(Mode>=2)  //加到2時(shí)清零
     Mode=0;
//    while(S3==0)
//    Display();
if((P1&0x70)==0x70)
  flag_KEY=0;
//掃描數(shù)碼管
void Display(void)
//正常顯示
if(Mode==0)
  P0=0x00;  //關(guān)閉顯示
  if(posit==1)//數(shù)碼管的小數(shù)點(diǎn)
   P0=(discode[disbuff[posit]])|0x80;//按位或,最高位變?yōu)?,顯示小數(shù)點(diǎn)
  else if(posit==0)
   P0=~discode[11];
   P0=discode[disbuff[posit]];
  switch(posit)
   case 0 : W1=0;W2=1;W3=1;W4=1; break;
   case 1 : W1=1;W2=0;W3=1;W4=1; break;
   case 2 : W1=1;W2=1;W3=0;W4=1; break;
   case 3 : W1=1;W2=1;W3=1;W4=0; break;
  posit++;
  if(posit>3)  //每進(jìn)一次顯示函數(shù),變量加1
   posit=0;  //加到3時(shí)清零
//報(bào)警顯示
  P0=0x00;
   P0=(discode[disbuff_BJ[posit]])|0x80;
  else if(posit==0)
   P0=0x76; //顯示字母
   P0=discode[disbuff_BJ[posit]];
  switch(posit)
  posit++;
  if(posit>3)
   posit=0;
//計(jì)算
void Conut(void)
time=TH0*256+TL0;   //讀出T0的計(jì)時(shí)數(shù)值
TH0=0;
TL0=0;      //清空計(jì)時(shí)器
S=(time*1.7)/100;     //算出來是CM
//聲音的速度是340m/s,時(shí)間的單位是us,計(jì)算到秒需要將時(shí)間數(shù)據(jù)/1000000,
//長度=速度*時(shí)間,340*time/1000000,長度數(shù)據(jù)單位是m轉(zhuǎn)換成cm需要乘以100得到340*time/10000,
//小數(shù)點(diǎn)都向左移兩位得到3.4*time/100,因?yàn)槌暡ㄊ峭盗耍栽俪?,得到距離數(shù)據(jù)(time*1.7)/100
if(Mode==0)     //非設(shè)置狀態(tài)時(shí)
  if((S>=700)||flag==1) //超出測量范圍顯示“-”
   Feng=0;      //蜂鳴器報(bào)警
   flag=0;
   disbuff[1]=10;    //“-”
   disbuff[2]=10;    //“-”
   disbuff[3]=10;    //“-”
   //距離小于報(bào)警距
   if(S<=BJS)
    Feng=0; //報(bào)警
   else  //大于
    Feng=1;  //關(guān)閉報(bào)警
   disbuff[1]=S%1000/100;   //將距離數(shù)據(jù)拆成單個(gè)位賦值
   disbuff[2]=S%1000%100/10;
   disbuff[3]=S%1000%10 %10;
   Feng=1;
   disbuff_BJ[1]=BJS%1000/100;
   disbuff_BJ[2]=BJS%1000%100/10;
   disbuff_BJ[3]=BJS%1000%10 %10;
//定時(shí)器0
void zd0() interrupt 1    //T0中斷用來計(jì)數(shù)器溢出,超過測距范圍
flag=1;       //中斷溢出標(biāo)志
//定時(shí)器1
void zd3() interrupt 3    //T1中斷用來掃描數(shù)碼管和計(jì)800MS啟動(dòng)模塊
TH1=0xf8;
TL1=0x30;     //定時(shí)2ms
Key_();     //掃描按鍵
Display();    //掃描顯示
timer++;    //變量加
if(timer>=400)   //400次就是800ms
  timer=0;
  TX=1;             //800MS  啟動(dòng)一次模塊
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  _nop_();
  TX=0;
//主函數(shù)
void main(void)
TMOD=0x11;     //設(shè)T0為方式1
TH0=0;
TL0=0;
TH1=0xf8;     //2MS定時(shí)
TL1=0x30;
ET0=1;    //允許T0中斷
ET1=1;      //允許T1中斷
TR1=1;      //開啟定時(shí)器
EA=1;     //開啟總中斷
  while(!RX);  //當(dāng)上次接收完波后,RX引腳是低電平,取反就是1,此while成立,反復(fù)判斷RX狀態(tài)。當(dāng)RX沒有接收到返回波時(shí)是高電平,取反就是0,此while不成立,跳出
  TR0=1;   //開啟計(jì)數(shù)
  while(RX);  //當(dāng)RX沒有接收到返回波,此while成立,程序停在這里一直判斷RX狀態(tài)。當(dāng)RX接收到返回波,RX引腳變?yōu)榈碗娖剑藈hile不成立,跳出
  TR0=0;   //停止計(jì)數(shù)
  Conut();   //計(jì)算
原理圖.pdf
61.73 KB, 下載次數(shù): 21, 下載積分: 黑幣 -5
原理圖
原理圖.doc
104 KB, 下載次數(shù): 12, 下載積分: 黑幣 -5
原理圖
評(píng)分
參與人數(shù) 1黑幣 +10 收起 理由
564654654 + 10 贊一個(gè)!
查看全部評(píng)分
ID:44037 發(fā)表于 2017-8-10 22:15 | 顯示全部樓層
謝謝分享   網(wǎng)上下載了很多程序  都不能用  你的程序  仿真成功  但是SRF04模塊標(biāo)值和數(shù)碼管差1cm
