2017-5-23 14:53 上傳
原理圖下載:
PDF格式 模塊超聲波測距儀.pdf
(123.7 KB, 下載次數(shù): 11)
2017-5-23 14:40 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
- #include <reg51.h>
- #define uchar unsigned char
- #define uint unsigned int
- #include <intrins.h>
- //數(shù)碼管段選定義 0 1 2 3 4 5 6 7 8 9
- uchar code smg_du[]={0x28,0xee,0x32,0xa2,0xe4,0xa1,0x21,0xea,0x20,0xa0,
- 0x60,0x25,0x39,0x26,0x31,0x71,0xff}; //斷碼
- uchar dis_smg[8] ={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8};
- //數(shù)碼管位選定義
- sbit smg_we1 = P3^4; //數(shù)碼管位選定義
- sbit smg_we2 = P3^5;
- sbit smg_we3 = P3^6;
- sbit smg_we4 = P3^7;
- uint code wendu_buchang1[46] = { //溫度補(bǔ)償表格
- 331,332,333,333,334,334,335,336,336,337, // 0-9度
- 337,338,339,339,340,341,341,342,342,343, //10-19度
- 343,344,345,345,346,346,347,348,348,349, //20-29度
- 349,350,351,351,352,352,353,354,354,355, //30-39度
- 355,356,357,357,358,358 //40-45度
- sbit dq = P2^4; //18b20 IO口的定義
- uint temperature ; //
- sbit c_send = P3^2; //超聲波發(fā)射
- sbit c_recive = P3^3; //超聲波接收
- sbit beep = P2^3; //蜂鳴器IO口定義
- uchar smg_i = 3; //顯示數(shù)碼管的個(gè)位數(shù)
- bit flag_300ms ;
- long distance; //距離
- uint set_d; //距離
- uchar flag_csb_juli; //超聲波超出量程
- uint flag_time0; //用來保存定時(shí)器0的時(shí)候的
- uchar menu_1; //菜單設(shè)計(jì)的變量
- /*sfr WDT_CONTR=0xe1;*/ //看門狗(watch-dog-Timer)控制器
- /***********************小延時(shí)函數(shù)*****************************/
- void delay_uint(uint q)
- while(q--);
- /***********************1ms延時(shí)函數(shù)*****************************/
- void delay_1ms(uint q)
- uint i,j;
- for(i=0;i<q;i++)
- for(j=0;j<120;j++);
- /***********************處理距離函數(shù)****************************/
- void smg_display()
- dis_smg[0] = smg_du[distance % 10];
- dis_smg[1] = smg_du[distance / 10 % 10];
- dis_smg[2] = smg_du[distance / 100 % 10] & 0xdf; ;
- /********************獨(dú)立按鍵程序*****************/
- uchar key_can; //按鍵值
- void key() //獨(dú)立按鍵程序
- static uchar key_new;
- key_can = 20; //按鍵值還原
- P2 |= 0x07;
- if((P2 & 0x07) != 0x07) //按鍵按下
- delay_1ms(1); //按鍵消抖動(dòng)
- if(((P2 & 0x07) != 0x07) && (key_new == 1))
- { //確認(rèn)是按鍵按下
- key_new = 0;
- switch(P2 & 0x07)
- case 0x06: key_can = 3; break; //得到k2鍵值
- case 0x05: key_can = 2; break; //得到k3鍵值
- case 0x03: key_can = 1; break; //得到k4鍵值
- else
- key_new = 1;
- /****************按鍵處理顯示函數(shù)***************/
- void key_with()
- if(key_can == 1) //設(shè)置鍵
- menu_1 ++;
- if(menu_1 >= 3)
- menu_1 = 0;
- smg_i = 3; //只顯示3位數(shù)碼管
- if(menu_1 == 1)
- smg_i = 4; //只顯示4位數(shù)碼管
- if(menu_1 == 1) //設(shè)置報(bào)警
- if(key_can == 2)
- set_d ++ ; //加1
- if(set_d > 400)
- set_d = 400;
- if(key_can == 3)
- set_d -- ; //減1
- if(set_d <= 1)
- set_d = 1;
- dis_smg[0] = smg_du[set_d % 10]; //取小數(shù)顯示
- dis_smg[1] = smg_du[set_d / 10 % 10] ; //取個(gè)位顯示
- dis_smg[2] = smg_du[set_d / 100 % 10] & 0xdf ; //取十位顯示
- dis_smg[3] = 0x60; //a
- /***********************18b20初始化函數(shù)*****************************/
- void init_18b20()
- bit q;
- dq = 1; //把總線拿高
- delay_uint(1); //15us
- dq = 0; //給復(fù)位脈沖
- delay_uint(80); //750us
- dq = 1; //把總線拿高 等待
- delay_uint(10); //110us
- q = dq; //讀取18b20初始化信號(hào)
- delay_uint(20); //200us
- dq = 1; //把總線拿高 釋放總線
- /*************寫18b20內(nèi)的數(shù)據(jù)***************/
- void write_18b20(uchar dat)
- uchar i;
- for(i=0;i<8;i++)
- { //寫數(shù)據(jù)是低位開始
- dq = 0; //把總線拿低寫時(shí)間隙開始
- dq = dat & 0x01; //向18b20總線寫數(shù)據(jù)了
- delay_uint(5); // 60us
- dq = 1; //釋放總線
- dat >>= 1;
- /*************讀取18b20內(nèi)的數(shù)據(jù)***************/
- uchar read_18b20()
- uchar i,value;
- for(i=0;i<8;i++)
- dq = 0; //把總線拿低讀時(shí)間隙開始
- value >>= 1; //讀數(shù)據(jù)是低位開始
- dq = 1; //釋放總線
- if(dq == 1) //開始讀寫數(shù)據(jù)
- value |= 0x80;
- delay_uint(5); //60us 讀一個(gè)時(shí)間隙最少要保持60us的時(shí)間
- return value; //返回?cái)?shù)據(jù)
- /*************讀取溫度的值 讀出來的是小數(shù)***************/
- uint read_temp()
- uint value;
- uchar low; //在讀取溫度的時(shí)候如果中斷的太頻繁了,就應(yīng)該把中斷給關(guān)了,否則會(huì)影響到18b20的時(shí)序
- init_18b20(); //初始化18b20
- write_18b20(0xcc); //跳過64位ROM
- write_18b20(0x44); //啟動(dòng)一次溫度轉(zhuǎn)換命令
- delay_uint(50); //500us
- write_18b20(0xbe); //發(fā)出讀取暫存器命令
- EA = 0;
- low = read_18b20(); //讀溫度低字節(jié)
- value = read_18b20(); //讀溫度高字節(jié)
- EA = 1;
- value <<= 8; //把溫度的高位左移8位
- value |= low; //把讀出的溫度低位放到value的低八位中
- value *= 0.0625; //轉(zhuǎn)換到溫度值
- return value; //返回讀出的溫度
- /****************報(bào)警函數(shù)***************/
- void clock_h_l()
- static uchar value;
- if(distance <= set_d)
- value ++; //消除實(shí)際距離在設(shè)定距離左右變化時(shí)的干擾
- if(value >= 2)
- beep = ~beep; //蜂鳴器報(bào)警
- else
- value = 0;
- beep = 1; //取消報(bào)警
- /***********************數(shù)碼位選函數(shù)*****************************/
- void smg_we_switch(uchar i)
- switch(i)
- case 0: smg_we1 = 0; smg_we2 = 1; smg_we3 = 1; smg_we4 = 1; break;
- case 1: smg_we1 = 1; smg_we2 = 0; smg_we3 = 1; smg_we4 = 1; break;
- case 2: smg_we1 = 1; smg_we2 = 1; smg_we3 = 0; smg_we4 = 1; break;
- case 3: smg_we1 = 1; smg_we2 = 1; smg_we3 = 1; smg_we4 = 0; break;
- /***********************數(shù)碼顯示函數(shù)*****************************/
- void display()
- static uchar i;
- i++;
- if(i >= smg_i)
- i = 0;
- smg_we_switch(i); //位選
- P1 = dis_smg[i]; //段選
- /******************小延時(shí)函數(shù)*****************/
- void delay()
- _nop_(); //執(zhí)行一條_nop_()指令就是1us
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- /*********************超聲波測距程序*****************************/
- void send_wave()
- c_send = 1; //10us的高電平觸發(fā)
- delay();
- c_send = 0;
- TH0 = 0; //給定時(shí)器0清零
- TL0 = 0;
- TR0 = 0; //關(guān)定時(shí)器0定時(shí)
- while(c_recive); //當(dāng)c_recive為1等待
- TR0=1;
- while(!c_recive) //當(dāng)c_recive為0等待
- flag_time0 = TH0 * 256 + TL0;
- if((flag_time0 > 40000)) //當(dāng)超聲波超過測量范圍時(shí),顯示3個(gè)888
- TR0 = 0;
- flag_csb_juli = 2;
- distance = 888;
- break ;
- else
- flag_csb_juli = 1;
- if(flag_csb_juli == 1)
- TR0=0; //關(guān)定時(shí)器0定時(shí)
- distance =flag_time0; //讀出定時(shí)器0的時(shí)間
- if(temperature <= 45)
- distance *= wendu_buchang1[temperature] / 2.0 * 0.0001; // 0.017 = 340M / 2 = 170M = 0.017M 算出來是米
- else
- distance *= 358 / 2.0 * 0.0001; // 0.017 = 340M / 2 = 170M = 0.017M 算出來是米
- if((distance > 500)) //距離 = 速度 * 時(shí)間
- distance = 888; //如果大于5.0m就超出超聲波的量程
- /*********************定時(shí)器0、定時(shí)器1初始化******************/
- void time_init()
- EA = 1; //開總中斷
- TMOD = 0X11; //定時(shí)器0、定時(shí)器1工作方式1
- ET0 = 0; //關(guān)定時(shí)器0中斷
- TR0 = 1; //允許定時(shí)器0定時(shí)
- ET1 = 1; //開定時(shí)器1中斷
- TR1 = 1; //允許定時(shí)器1定時(shí)
- /***************主函數(shù)*****************/
- void main()
- beep = 0; //開機(jī)叫一聲
- delay_1ms(150);
- P0 = P1 = P2 = P3 = 0xff; //初始化單片機(jī)IO口為高電平
- time_init(); //定時(shí)器初始化程序
- init_18b20();
- /*send_wave();
- smg_display(); //處理距離顯示函數(shù)
- /*time_init(); //定時(shí)器初始化程序
- send_wave(); //測距離函數(shù)
- send_wave();*/ //測距離函數(shù)
- do
- if(flag_300ms == 0)
- flag_300ms = 0;
- clock_h_l(); //報(bào)警函數(shù)
- temperature = read_temp(); //先讀出溫度的值
- if(beep == 1)
- if(menu_1 == 0)
- if(menu_1 == 2) //顯示溫度
- dis_smg[0] = 0xf0;
- dis_smg[1] = smg_du[temperature % 10]; //取溫度的個(gè)位顯示
- dis_smg[2] = smg_du[temperature / 10 % 10] ; //取溫度的十位顯示
- dis_smg[3] = 0xFF;
- smg_display();
- key(); //按鍵函數(shù)
- if(key_can < 10)
- key_with(); //按鍵處理函數(shù)
- }while(1);
- /*********************定時(shí)器1中斷服務(wù)程序************************/
- void time1_int() interrupt 3
- static uchar value; //定時(shí)2ms中斷一次
- TH1 = 0xf8;
- TL1 = 0x30; //2ms
- display(); //數(shù)碼管顯示函數(shù)
- value++;
- if(value >= 150)
- value = 0;
- flag_300ms = 1;
