查看: 8084|回復: 0
msp430和51單片機rc522射頻卡讀寫卡程序及原理圖
51單片機和msp430單片機讀寫射頻卡程序的原理圖和例程都有
文檔包含:
ISO14443\
ISO14443-2.pdf
ISO14443-3.pdf
ISO14443-4.pdf
Mifare卡片資料\
Design of MF RC500 Matching Circuits and Antennas.PDF
M01811.PDF
M112120_FSpec_RC522_20050801.pdf
MF1 S50.pdf
51單片機源程序如下:
  1. #include "lpcreg.h"
  2. #include "main.h"
  3. #include "mfrc522.h"
  4. unsigned char code data1[16] = {0x12,0x34,0x56,0x78,0xED,0xCB,0xA9,0x87,0x12,0x34,0x56,0x78,0x01,0xFE,0x01,0xFE};
  5. //M1卡的某一塊寫為如下格式,則該塊為錢包,可接收扣款和充值命令
  6. //4字節金額(低字節在前)+4字節金額取反+4字節金額+1字節塊地址+1字節塊地址取反+1字節塊地址+1字節塊地址取反
  7. unsigned char code data2[4]  = {0x12,0,0,0};
  8. unsigned char code DefaultKey[6] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
  9. unsigned char g_ucTempbuf[20];
  10. void main( )
  11. {
  12.      unsigned char status;
  13.      InitializeSystem( );
  14.      PcdReset();
  15.      PcdAntennaOff(); //關閉天線
  16.      PcdAntennaOn();  //開啟天線
  17.      while ( 1 )
  18.      {
  19.          status = PcdRequest(PICC_REQALL, g_ucTempbuf);       #define PICC_REQIDL 0x26    //尋天線區內未進入休眠狀態
  20. ////////////////////////////////////////////////////////////////////////////////
  21.          if (status != MI_OK)
  22.          {
  23.               LED_GREEN = 1;
  24.               continue;
  25.          }
  26. /////////////////////////////////////////////////////////////////////
  27.          LED_GREEN = 0;
  28.          status = PcdAnticoll(g_ucTempbuf);
  29. //////////////////////////////////////////////////////////////////////
  30.          if (status != MI_OK)
  31.          {
  32.              continue;
  33.          }
  34. /////////////////////////////////////////////////////////////////////
  35.          status = PcdSelect(g_ucTempbuf);
  36.          if (status != MI_OK)
  37.          {
  38.             continue;
  39.          }
  40. ////////////////////////////////////////////////////////////////////////////
  41.          status = PcdAuthState(PICC_AUTHENT1A, 1, DefaultKey, g_ucTempbuf);
  42.          if (status != MI_OK)
  43.          {
  44.              continue;
  45.          }
  46. /////////////////////////////////////////////////////////////////////////////
  47.          status = PcdWrite(1, data1);
  48.          if (status != MI_OK)
  49.          {
  50.             continue;
  51.          }
  52. /////////////////////////////////////////////////////////////////////////////////
  53.          status = PcdValue(PICC_DECREMENT,1,data2);
  54.          if (status != MI_OK)
  55.          {
  56.            continue;
  57.          }
  58. /////////////////////////////////////////////////////////////////////////////////
  59.          status = PcdBakValue(1, 2);
  60.          if (status != MI_OK)
  61.          {
  62.              continue;
  63.          }
  64. /////////////////////////////////////////////////////////////////////////////
  65.          status = PcdRead(2, g_ucTempbuf);
  66.          if (status != MI_OK)
  67.          {
  68.             continue;
  69.          }
  70.           PcdHalt();   //命令卡片進入休眠狀態
  71.     }
  72. }
  73. /////////////////////////////////////////////////////////////////////
  74. //系統初始化
  75. /////////////////////////////////////////////////////////////////////
  76. void InitializeSystem()
  77. {
  78.     P0M1 = 0x0; P0M2 = 0x0;
  79.     P1M1 = 0x0;        P1M2 = 0x0;
  80.     P3M1 = 0x0; P3M2 = 0xFF;
  81.     P0 = 0xFF; P1 = 0xFF; P3 = 0xFF;
  82. }
  83. /////////////////////////////////////////////////////////////////////
  84. //功    能:復位RC522
  85. //返    回: 成功返回MI_OK
  86. /////////////////////////////////////////////////////////////////////
  87. char PcdReset(void)
  88. {
  89.     MF522_RST=1;
  90.     _nop_();
  91.     MF522_RST=0;
  92.     _nop_();
  93.     MF522_RST=1;
  94.      _nop_();
  95.     WriteRawRC(CommandReg,PCD_RESETPHASE);
  96.     _nop_();
  97.
  98.     WriteRawRC(ModeReg,0x3D);            //和Mifare卡通訊,CRC初始值0x6363
  99.     WriteRawRC(TReloadRegL,30);
  100.     WriteRawRC(TReloadRegH,0);
  101.     WriteRawRC(TModeReg,0x8D);
  102.     WriteRawRC(TPrescalerReg,0x3E);
  103.
  104.     return MI_OK;
  105. }
  106. /////////////////////////////////////////////////////////////////////
  107. //功    能:寫RC632寄存器
  108. //參數說明:Address[IN]:寄存器地址
  109. //          value[IN]:寫入的值
  110. /////////////////////////////////////////////////////////////////////
  111. void WriteRawRC(unsigned char Address, unsigned char value)
  112. {
  113.     unsigned char i, ucAddr;
  114.     MF522_SCK = 0;
  115.     MF522_NSS = 0;
  116.     ucAddr = ((Address<<1)&0x7E);
  117.     for(i=8;i>0;i--)
  118.     {
  119.         MF522_SI = ((ucAddr&0x80)==0x80);
  120.         MF522_SCK = 1;
  121.         ucAddr <<= 1;
  122.         MF522_SCK = 0;
  123.     }
  124.     for(i=8;i>0;i--)
  125.     {
  126.         MF522_SI = ((value&0x80)==0x80);
  127.         MF522_SCK = 1;
  128.         value <<= 1;
  129.         MF522_SCK = 0;
  130.     }
  131.     MF522_NSS = 1;
  132.     MF522_SCK = 1;
  133. }
  134. /////////////////////////////////////////////////////////////////////
  135. //功    能:讀RC632寄存器
  136. //參數說明:Address[IN]:寄存器地址
  137. //返    回:讀出的值
  138. /////////////////////////////////////////////////////////////////////
  139. unsigned char ReadRawRC(unsigned char Address)
  140. {
  141.      unsigned char i, ucAddr;
  142.      unsigned char ucResult=0;
  143.      MF522_SCK = 0;
  144.      MF522_NSS = 0;
  145.      ucAddr = ((Address<<1)&0x7E)|0x80;
  146.      for(i=8;i>0;i--)
  147.      {
  148.          MF522_SI = ((ucAddr&0x80)==0x80);
  149. ……………………
  150. …………限于本文篇幅 余下代碼請從51黑下載附件…………
51單片機rc522 射頻的程序和與電路圖.rar (2.66 MB, 下載次數: 92)
