只需一步,快速開(kāi)始
查看: 4914|回復(fù): 1
msp430g2553的串口發(fā)送程序
ID:164961 發(fā)表于 2017-2-16 17:03 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include <msp430g2553.h>
#include <intrinsics.h>
#include <msp430.h>
#define LCD_EN_PORT P1OUT    //以下2個(gè)要設(shè)為同一個(gè)口
#define LCD_EN_DDR P1DIR
#define LCD_RS_PORT P1OUT    //以下2個(gè)要設(shè)為同一個(gè)口
#define LCD_RS_DDR P1DIR
#define LCD_DATA_PORT P2OUT  //以下3個(gè)要設(shè)為同一個(gè)口
#define LCD_DATA_DDR P2DIR   //一定要用高4
#define LCD_RS BIT6
#define LCD_EN BIT7
#define LCD_DATA    BIT7|BIT6|BIT5|BIT4 //4位數(shù)據(jù)線連接模式
void LCD_init(void);
void LCD_init_first(void);
void LCD_en_write1(void);  //上升沿使能
void LCD_en_write2(void);  //下降沿使能
void LCD_write_command(unsigned charcommand);
void LCD_write_data(unsigned char data);
void LCD_set_xy (unsigned char x, unsignedchar y);
void LCD_write_string(unsigned charX,unsigned char Y, unsigned char s);
void LCD_write_char(unsigned charX,unsigned char Y, unsigned char data);
void delay_1ms(void);
void delay_nus(unsigned int n);
void delay_nms(unsigned int n);
unsigned char rev;
void putchar(unsigned char c)    //發(fā)送字符函數(shù)
   while (!(IFG2&UCA0TXIFG));  // USCI_A0 TX buffer ready? 等待TX buffer為空
   UCA0TXBUF = c;      // TX ->RXed character  發(fā)送字符c
void putstr(char *s)  //發(fā)送字符串函數(shù)
   IE2 &= ~UCA0RXIE;  //發(fā)送時(shí)先關(guān)閉接收中斷,不接收
   while((*s)!='\0')  //如果沒(méi)有發(fā)完,就繼續(xù)循環(huán)發(fā)送
     putchar(*s);
     putchar('\n');  //發(fā)送換行符
     s++;
   IE2 |= UCA0RXIE;    //發(fā)送完了打開(kāi)接收中斷
void Init_USTAR(void)
BCSCTL1 =CALBC1_1MHZ;   // Set DCO1MHz
DCOCTL =CALDCO_1MHZ;
P1SEL = BIT1 + BIT2;    // P1.1 =RXD, P1.2=TXD
P1SEL2 = BIT1 + BIT2;   //第二外圍模式選擇
UCA0CTL1 |= UCSSEL_2;   // SMCLK 其他默認(rèn):軟件復(fù)位使能 USCI邏輯保持在復(fù)位狀態(tài),用于設(shè)置串口
UCA0BR0 = 8;            // SMCLK1MHz 115200    8
UCA0BR1 = 0;            // 1MHz115200
UCA0MCTL = UCBRS2 + UCBRS0;
UCA0CTL1 &= ~UCSWRST;
  IE2|= UCA0RXIE;            //  接收中斷使能
void main()//主函數(shù)
WDTCTL = WDTPW + WDTHOLD;     // 關(guān)閉看門狗
LCD_init_first();
LCD_init();
Init_USTAR();
_BIS_SR(LPM3_bits+GIE); // Enter LPM0, interrupts enabled
// LCD液晶操作函數(shù)
void LCD_init_first(void)     //LCD1602液晶初始化函數(shù)(熱啟動(dòng))
    delay_nms(500);
    LCD_DATA_DDR|=LCD_DATA;   //數(shù)據(jù)口方向?yàn)檩敵?/font>
    LCD_EN_DDR|=LCD_EN;       //設(shè)置EN方向?yàn)檩敵?/font>
    LCD_RS_DDR|=LCD_RS;       //設(shè)置RS方向?yàn)檩敵?/font>
    delay_nms(50);
    LCD_write_command(0x30);
    delay_nms(50);
    delay_nms(5);
    delay_nms(500);
void LCD_init(void)
   delay_nms(500);
   delay_nms(500);
   LCD_write_command(0x28);  //4位數(shù)據(jù)接口
   delay_nms(50);
   delay_nms(50);
   delay_nms(50);
   LCD_en_write2();
   delay_nms(50);
    delay_nms(500);
   LCD_write_command(0x01); //清屏
   LCD_write_command(0x0c); //顯示開(kāi),關(guān)光標(biāo),不閃爍
   LCD_write_command(0x06); //設(shè)定輸入方式,增量不移位
   delay_nms(50);
//液晶使能上升沿
   LCD_EN_PORT&=~LCD_EN;
   delay_nus(10);
   LCD_EN_PORT|=LCD_EN;
//液晶使能下降沿
  delay_nus(10);
//寫(xiě)指令函數(shù)
  delay_nus(16);
  P2SEL=0x00;
  LCD_RS_PORT&=~LCD_RS; //RS=0
  LCD_en_write1();
  LCD_DATA_PORT&=0X0f; //清高四位
  LCD_DATA_PORT|=command&0xf0; //寫(xiě)高四位
  delay_nus(16);
  LCD_en_write2();
  command=command<<4; //低四位移到高四位
  LCD_en_write1();
  LCD_DATA_PORT&=0x0f; //清高四位
  LCD_DATA_PORT|=command&0xf0; //寫(xiě)低四位
  LCD_en_write2();
//寫(xiě)數(shù)據(jù)函數(shù)
  delay_nus(16);
  P2SEL=0x00;
  LCD_RS_PORT|=LCD_RS;      //RS=1
  LCD_en_write1();          //E上升沿
  LCD_DATA_PORT|=data&0xf0; //寫(xiě)高四位
  delay_nus(16);
  LCD_en_write2();
  data=data<<4;             //低四位移到高四位
  LCD_en_write1();
  LCD_DATA_PORT|=data&0xf0; //寫(xiě)低四位
  LCD_en_write2();
//寫(xiě)地址函數(shù)
void LCD_set_xy( unsigned char x, unsignedchar y )
  unsigned char address;
   if (y == 0) address = 0x80 + x;
  else address = 0xc0 + x;
  LCD_write_command( address);
//LCD在任意位置寫(xiě)字符串,列x=0~15,y=0,1
void LCD_write_string(unsigned charX,unsigned char Y,unsigned char s)
LCD_set_xy( X, Y ); //寫(xiě)地址
LCD_write_data( s );
//LCD在任意位置寫(xiě)字符,x=0~15,y=0,1
void LCD_write_char(unsigned charX,unsigned char Y,unsigned char data)
  LCD_write_data( data);
//1us延時(shí)函數(shù)
void delay_1us(void)
  asm("nop");
//N us延時(shí)函數(shù)
  unsigned int i;
  for(i=0;i<n;i++)
  delay_1us();
//1ms延時(shí)函數(shù)
  unsigned int i;
  for (i=0;i<1140;i++);
//N ms延時(shí)函數(shù)
  unsigned int i=0;
  for (i=0;i<n;i++)
  delay_1ms();
#pragma vector=USCIAB0RX_VECTOR
__interrupt void USCI0RX_ISR(void)
UCA0TXBUF = UCA0RXBUF;         //TX -> RXed character  發(fā)送接收到是數(shù)據(jù)
rev=UCA0RXBUF;
putchar(rev);
LCD_write_string(0,0,rev);
  delay_nms(10);
ID:165166 發(fā)表于 2017-2-17 20:28 | 只看該作者
學(xué)習(xí)了
