先附程序:
#include <STC12C5a60s2.h>
#include <stdio.h>
#include <intrins.H>
#define u8 char
#define u16 int
#define AD_SPEED 0x60
u8 tab[16] ={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};
sbit DAT=P1^1;
sbit CLK=P1^0;
u8 u82;// u81,
u16 u80;
u16 n=2,l=40,sec=0,min=0;
u16 temp;
u8 Time_10ms=0,Time_flag=0;
void delay(u8 t)
{ u16 j;
for(;t>0;t--)
for(j=200;j>0;j--)
void send164(u8 data1,u8 data2);
u8 get_AD_result(u8 channel)
u8 AD_finished=0; //存儲(chǔ) A/D 轉(zhuǎn)換標(biāo)志
u16 adc;
ADC_RES = 0;
ADC_RESL = 0;
channel &= 0x07; //0000,0111 清0高5位
ADC_CONTR = AD_SPEED;
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
ADC_CONTR |= channel; //選擇 A/D 當(dāng)前通道
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
ADC_CONTR |= 0x80; //啟動(dòng) A/D 電源
_nop_();
_nop_();
_nop_();
_nop_();
//使輸入電壓達(dá)到穩(wěn)定
ADC_CONTR |= 0x08; //0000,1000 令 ADCS = 1, 啟動(dòng)A/D轉(zhuǎn)換,
_nop_();
_nop_();
_nop_();
_nop_();
AD_finished = 0;
while (AD_finished ==0 ) //等待A/D轉(zhuǎn)換結(jié)束
AD_finished = (ADC_CONTR & 0x10); //0001,0000 測(cè)試A/D轉(zhuǎn)換結(jié)束否
ADC_CONTR &= 0xE7; //1111,0111 清 ADC_FLAG 位, 關(guān)閉A/D轉(zhuǎn)換,
_nop_();
_nop_();
_nop_();
_nop_();
adc=ADC_RES;
return adc ; //返回 A/D 高 8 位轉(zhuǎn)換結(jié)果ADC_RES
void init_time0()
TMOD = 0x01; //16位定時(shí)器
TL0 = 0x3C; //50ms定時(shí)
TH0 = 0xB0;
ET0 = 1; //允許T0中斷
EA = 1; //開(kāi)放中斷
TR0 = 1;
void Time0(void) interrupt 1
TL0 = 0x3C;
TH0 = 0xB0;
send164(tab[u82%10],tab[u82/10]);
delay(200);
void adc_init()
P1ASF|=0x04;
AUXR1 &= ~0x04;
ADC_CONTR=0X80;
delay(4);
{ u82=0;
u80=0;
init_time0();
adc_init();
delay(20);
u80=get_AD_result(2);
delay(10);
u82=u80*49/256;
delay(10);
delay(0x1);
//L H
void send164(u8 udata1,u8 udata2)
u8 i;
u8 j;
for(i=0;i<8;i++)
if ((udata1&0x80)==0x80)
DAT=1;
DAT=0;
CLK=0;
udata1 = udata1<<1;
CLK=1;
for(j=0;j<8;j++)
if ((udata2&0x80)==0x80)
DAT=1;
DAT=0;
CLK=0;
udata2 = udata2<<1;
CLK=1;
硬件部分是采用P1^2作為ADC采集入口,采用的接法與官方一致
說(shuō)下問(wèn)題吧:
在電壓值在0~23.4v的時(shí)候數(shù)碼管顯示正常,在將電壓調(diào)高后數(shù)碼管顯示全亮或非正常數(shù)字。想請(qǐng)問(wèn)下這是因?yàn)槭裁此鶎?dǎo)致的?
