查看: 14945|回復: 7
STC15w408AS_ADC10模數轉換程序例子
ID:262 發表于 2016-8-12 17:01 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
//////////////stc15MCU//////////////////////
//  ADC--|P1.2    P1.1|--rs          //
//           --|P1.3    P1.0|--en         //
//      D4--|P1.4    P3.7|--D7         //
//      D5--|P1.5    P3.6|--D6         //
//           --|P5.4    P3.3|--D3         //
//    Vcc--|V+       P3.2|--D2         //
//           --|P5.5    P3.1|--D1         //
//  GND--|V-        P3.0|--D0         //
#include"reg51.h"
#define U16 unsigned int
#define U8 unsigned char
sbit rs=P1^1;
sbit en=P1^0;
U8 dd0[]="shanxi dianzi";
U16 temp;
void delay(U16 us)
  while(us--);
///////////////////////////////////LCD1602///////////////////////////////
//  Vss Vdd   Vo    RS   RW   EN  D0  D1   D2   D3   D4   D5   D6   D7  A   K     //
void w1602(bit w,U8 dat)
ACC=dat;
rs=w;
en=0;
P3 &=~0xcf;       //According to the LCD1602 pin  clear
P3 |=dat & 0xcf;  //For 1602 pin assignment
P1 &=~0x30;       //LCD1602 pin  clear
P1 |=dat & 0x30;  //For 1602 pin assignment
delay(10);
en=1;
delay(10);
en=0;
void init1602()
w1602(0,0x38);
w1602(0,0x06);
w1602(0,0x0c);
w1602(0,0x01);
void initADC()
  P1ASF=0x04;     //ADC_in in P1.2
ADC_RES=0;
ADC_RESL=0;
ADC_CONTR=0xE2;  // 1)ON Power; 2)speed 90 3)ADC in P1.2
delay(15);
U8 n;
init1602();
P1M1=0x04;
P1M0=0x00;
CLK_DIV &=~0x20;
initADC();
 ADC_CONTR =0xea;
 delay(10);
 while(!(ADC_CONTR & 0x10));
 ADC_CONTR &=~0x10;   //clear ADC_flag
 temp =ADC_RES;
 temp =temp<<2;
 temp |=ADC_RESL;
    w1602(0,0x80);
 for(n=0;n<13;n++)
  w1602(1,dd0[n]);
 w1602(0,0xc0);
 w1602(1,(temp/1000+0x30));
w1602(1,((temp%1000)/100+0x30));
w1602(1,(((temp%1000)%100)/10+0x30));
w1602(1,(temp%10+0x30));
///不移動不閃爍的成功程序///+++++++++++++++++++++++OK
#include <REGX51.H>
#include"intrins.h"
sbit rs=P1^1;
sbit en=P1^0;
sbit D0=ACC^0;
sbit D1=ACC^1;
sbit D2=ACC^2;
sbit D3=ACC^3;
sbit D4=ACC^4;
sbit D5=ACC^5;
sbit D6=ACC^6;
sbit D7=ACC^7;
unsigned int temp,temp1;
unsigned char dd0[]=" H:0530;L:0630";
unsigned char dd1[]=" Pow L:";
void delay(unsigned int ms)
{ char i;
  while(ms--)
for(i=0;i<5;i++);
void w1602c(unsigned char dat)
  unsigned char i;
ACC=dat;
P30=D0;
P31=D1;
P32=D2;
P33=D3;
P14=D4;
P15=D5;
P36=D6;
P37=D7;
rs=0;
en=0;
i=20;
while(i--);
en=1;
i=20;
while(i--);
en=0;
i=20;
while(i--);
void w1602d(unsigned char dat)
  unsigned char i;
ACC=dat;
P30=D0;
P31=D1;
P32=D2;
P33=D3;
P14=D4;
P15=D5;
P36=D6;
P37=D7;
rs=1;
en=0;
i=20;
while(i--);
en=1;
i=20;
while(i--);
en=0;
i=20;
while(i--);
void init1602()
w1602c(0x38);
w1602c(0x06);
 w1602c(0x0c);
 w1602c(0x01);
void InitADC()
char n;
  P1ASF =0x04;  //P1.2 ADC_IN
  ADC_RES=0;
  ADC_RESL=0;
  ADC_CONTR =0xE2;//ON_POWER
  for(n=0;n<10;n++);
void disp(unsigned int dd)
char i;
  for(i=0;i<7;i++)
 w1602d(dd0[i]);
 w1602d(0x20);
 w1602d(dd/1000+0x30);
 w1602d((dd%1000)/100+0x30);
 w1602d(((dd%1000)%100)/10+0x30);
 w1602d(dd%10+0x30);
unsigned int nn;
init1602();
P1M1=0x04;
P1M0=0x00;
CLK_DIV &=~0x20;
InitADC();
    ADC_CONTR=0xea;
    nn=10;
while(nn--);
ADC_CONTR &=~0x10;
temp=ADC_RES;
temp=temp<<2;
temp |=ADC_RESL;
w1602c(0x80);
for(nn=0;nn<15;nn++)
w1602d(dd0[nn]);
delay(100);
w1602c(0xc0);
disp(temp-529);
#include <REGX51.H>
#include"intrins.h"
sbit rs=P1^1;
sbit en=P1^0;
unsigned int temp;
unsigned char dd0[]=" Pow H:";
   char i;
  while(ms--)
for(i=0;i<5;i++);
       char i;
P3 &=~0xcf;
P3 |=(dat & 0xcf);
P1 &=~0x30;
P1 |=((dat) & 0x30);
rs=0;
en=0;
i=6;
while(i--);
en=1;
i=8;
while(i--);
en=0;
        char i;
P3 &=~0xcf;
P3 |=(dat & 0xcf);
P1 &=~0x30;
rs=1;
en=0;
i=6;
while(i--);
en=1;
i=8;
while(i--);
en=0;
void InitADC()
char n;
        P1ASF =0x02;  //P10
ADC_RES=0;
ADC_RESL=0;
        for(n=0;n<10;n++);
void init1602()
        w1602c(0x38);
w1602c(0x06);
w1602c(0x0c);
w1602c(0x01);
  unsigned char i,nn;
  init1602();
  CLK_DIV &=~0x20;
    InitADC();   //on exchange power
           ADC_CONTR =0xea; //start exchange
           nn=10;
           while(nn--);
           while(!(ADC_CONTR & 0x10));//wait for AD exchenge end
           ADC_CONTR &=~0x10;
           temp =ADC_RES;  //read high 8bit to temp
           temp =temp<<2;
           temp |=ADC_RESL;//read low 2bit to temp
           temp=temp-400;
           w1602c(0x80);
           for(i=0;i<7;i++)
  w1602d(dd0[i]);
           w1602d(temp/1000+0x30);
           w1602d((temp%1000)/100+0x30);
           w1602d(((temp%1000)%100)/10+0x30);
           w1602d(temp%10+0x30);
           delay(60000);
           delay(60000);
           delay(60000);
           delay(60000);
           w1602c(0x01);
#include <REGX51.H>
#include"intrins.h"
sbit rs=P3^7;
sbit en=P5^4;
unsigned int temp;
{ char i;
  while(ms--)
for(i=0;i<5;i++);
void w1602c(unsigned char dat) //d7 d6 d5 d4 d3 d2 d1 d0
  char i;
P3 &=~0x4c;                //      s7  s6   s5   s4   s3   s2   s1    s0
P3 |=(dat>>3 & 0x0c) |(dat>>1 & 0x40);
                            //     P36  P33  P32  P15  P14  P13  P12   P11
P1 &=~0x3e;                //P1:   x    x   P15  P14  P13  P12   P11   x
P1 |=((dat<<1) & 0x3e);    //P3:   x   P36   x    x    P33  P32   x    x
rs=0;
en=0;
i=6;
while(i--);
en=1;
i=8;
while(i--);
en=0;
  char i;
rs=1;
en=0;
i=6;
while(i--);
en=1;
i=8;
while(i--);
en=0;
void InitADC()
char n;
  P1ASF =0x01;  //P1.0 ADC_IN
ADC_RES=0;
ADC_RESL=0;
  ADC_CONTR =0xE0;//ON_POWER
  for(n=0;n<10;n++);
void init1602()
  w1602c(0x38);
w1602c(0x06);
w1602c(0x0c);
w1602c(0x01);
  unsigned char i,nn;
init1602();
CLK_DIV &=~0x20;
  ADC_CONTR =0xe8; //start exchange
  nn=10;
  while(nn--);
ADC_CONTR &=~0x10;
  temp =temp<<2;
//temp=temp-400;
  w1602c(0x80);
  for(i=0;i<7;i++)
  w1602d(dd0[i]);
for(i=0;i<5;i++)
   w1602d(0x20);
w1602c(0xc0);
  for(i=0;i<16;i++)
   w1602d(dd1[i]);
delay(60000);
  delay(60000);
  delay(60000);
  delay(60000);
  //w1602c(0x01);
收藏收藏3 分享淘帖 頂 踩
ID:839438 發表于 2021-7-12 18:31 | 只看該作者
P1ASF =0x02;  //P10這個是不是錯?0x01因該是正確?
ID:84765 發表于 2018-11-12 10:10 | 只看該作者
初始化都不完整當然編譯不過啦!
ID:400811 發表于 2018-11-11 15:43 | 只看該作者
編譯不通過...
ID:81249 發表于 2016-12-12 19:07 來自觸屏版 | 只看該作者
好資料,學習了。
ID:69481 發表于 2016-12-12 16:45 | 只看該作者
都不做注釋,別看起來不好懂!
ID:98767 發表于 2016-8-16 16:15 | 只看該作者
這是測量電壓的嗎?
