壓力測(cè)試儀
系統(tǒng)描述;輸入 15--115kPA壓力信號(hào)
輸出 00h--ffh數(shù)字信號(hào)(adc0832)
在LCD上顯示實(shí)際的壓力值,如果超限則報(bào)警
線性區(qū)間標(biāo)度變換公式: y=(115-15)/(243-13)*X+15kpa
作者:
單位:
日期:2008.3.7
#include<reg51.h>
#include<intrins.h>
#include <absacc.h>
#include <math.h>
#define BUSY 0x80 //常量定義
#define DATAPORT P0
//ADC0832的引腳
sbit ADCS =P3^5; //ADC0832 chip seclect
sbit ADDI =P3^7; //ADC0832 k in
sbit ADDO =P3^7; //ADC0832 k out
sbit ADCLK =P3^6; //ADC0832 clock signal
sbit LCM_RS=P2^0;
sbit LCM_RW=P2^1;
sbit LCM_EN=P2^2;
uchar ad_data; //采樣值存儲(chǔ)
sbit Alarm_led_red =P3^1; //超過壓力表量程最大值紅色led報(bào)警定義
sbit Alarm_led_green=P3^2; //低于壓力表量程最小值綠色led報(bào)警定義
//adc采樣值存儲(chǔ)單元
char press_data; //標(biāo)度變換存儲(chǔ)單元
unsigned char ad_alarm; //報(bào)警值存儲(chǔ)單元
unsigned char press_ge=0; //顯示值百位
unsigned char press_shifen=0; //顯示值十位
unsigned char press_baifen=0; //顯示值個(gè)位
unsigned char press_qianfen=0; //顯示值十分位
uchar code str0[]={"Weight: . Kg "};
uchar code str1[]={"Make by GUO TAO "};
uchar code str2[]={"Price: "};
uchar code str3[]={"Total: "};
void delay(uint);
void lcd_wait(void);
void delay_LCM(uint); //LCD延時(shí)子程序
void initLCM( void); //LCD初始化子程序
void lcd_wait(void); //LCD檢測(cè)忙子程序
void WriteCommandLCM(uchar WCLCM,uchar BusyC); //寫指令到ICM子函數(shù)
void WriteDataLCM(uchar WDLCM); //寫數(shù)據(jù)到LCM子函數(shù)
void DisplayOneChar(uchar X,uchar Y,uchar DData); //顯示指定坐標(biāo)的一個(gè)字符子函數(shù)
void DisplayListChar(uchar X,uchar Y,uchar code *DData); //顯示指定坐標(biāo)的一串字符子函數(shù)
void keyscan();
void display(void); //系統(tǒng)顯示子函數(shù)
uchar Adc0832(unsigned char channel);
void alarm(void);
void data_pro(void);
/**********main funcation************/
void main(void)
delay(500); //系統(tǒng)延時(shí)500ms啟動(dòng)
// ad_data=0; //采樣值存儲(chǔ)單元初始化為0
initLCM( );
WriteCommandLCM(0x01,1); //清顯示屏
DisplayListChar(0,0,str0);
DisplayListChar(0,1,str2);
ad_data =Adc0832(0); //采樣值存儲(chǔ)單元初始化為0
alarm();
data_pro();
display();
/*********延時(shí)K*1ms,12.000mhz**********/
void delay(uint k)
uint i,j;
for(i=0;i<k;i++)
for(j=0;j<60;j++)
/**********寫指令到ICM子函數(shù)************/
if(BusyC)lcd_wait();
DATAPORT=WCLCM;
LCM_RS=0; // 選中指令寄存器
LCM_RW=0; // 寫模式
LCM_EN=1;
_nop_();
_nop_();
_nop_();
LCM_EN=0;
/**********寫數(shù)據(jù)到LCM子函數(shù)************/
lcd_wait( ); //檢測(cè)忙信號(hào)
DATAPORT=WDLCM;
LCM_RS=1; // 選中數(shù)據(jù)寄存器
LCM_RW=0; // 寫模式
LCM_EN=1;
_nop_();
_nop_();
_nop_();
LCM_EN=0;
/***********lcm內(nèi)部等待函數(shù)*************/
void lcd_wait(void)
DATAPORT=0xff; //讀LCD前若單片機(jī)輸出低電平,而讀出LCD為高電平,則沖突,Proteus仿真會(huì)有顯示邏輯黃色
LCM_EN=1;
LCM_RS=0;
LCM_RW=1;
_nop_();
_nop_();
_nop_();
while(DATAPORT&BUSY)
{ LCM_EN=0;
_nop_();
_nop_();
LCM_EN=1;
_nop_();
_nop_();
LCM_EN=0;
/**********LCM初始化子函數(shù)***********/
void initLCM( )
DATAPORT=0;
delay(15);
WriteCommandLCM(0x38,0); //三次顯示模式設(shè)置,不檢測(cè)忙信號(hào)
delay(5);
delay(5);
delay(5);
WriteCommandLCM(0x38,1); //8bit數(shù)據(jù)傳送,2行顯示,5*7字型,檢測(cè)忙信號(hào)
WriteCommandLCM(0x08,1); //關(guān)閉顯示,檢測(cè)忙信號(hào)
WriteCommandLCM(0x01,1); //清屏,檢測(cè)忙信號(hào)
WriteCommandLCM(0x06,1); //顯示光標(biāo)右移設(shè)置,檢測(cè)忙信號(hào)
WriteCommandLCM(0x0c,1); //顯示屏打開,光標(biāo)不顯示,不閃爍,檢測(cè)忙信號(hào)
/****顯示指定坐標(biāo)的一個(gè)字符子函數(shù)****/
Y&=0x01;
X&=0x0f;
if(Y)X|=0x40; //若y為1(顯示第二行),地址碼+0X40
X|=0x80; //指令碼為地址碼+0X80
WriteCommandLCM(X,1);
WriteDataLCM(DData);
/*******顯示指定坐標(biāo)的一串字符子函數(shù)*****/
uchar ListLength=0;
Y&=0x01;
X&=0x0f;
while(X<16)
DisplayOneChar(X,Y,DData[ListLength]);
ListLength++;
X++;
/*****************系統(tǒng)顯示子函數(shù)*****************/
void display(void)
DisplayOneChar(8,0,press_ge+0x30);
DisplayOneChar(10,0,press_shifen+0x30);
DisplayOneChar(11,0,press_baifen+0x30);
DisplayOneChar(12,0,press_qianfen+0x30);
delay(1000); //穩(wěn)定顯示
讀ADC0832函數(shù)
//采集并返回
uchar Adc0832(unsigned char channel) //AD轉(zhuǎn)換,返回結(jié)果
uchar i=0;
uchar j;
uint dat=0;
uchar ndat=0;
if(channel==0)channel=2;
if(channel==1)channel=3;
ADDI=1;
_nop_();
_nop_();
ADCS=0;//拉低CS端
_nop_();
_nop_();
ADCLK=1;//拉高CLK端
_nop_();
_nop_();
ADCLK=0;//拉低CLK端,形成下降沿1
_nop_();
_nop_();
ADCLK=1;//拉高CLK端
ADDI=channel&0x1;
_nop_();
_nop_();
ADCLK=0;//拉低CLK端,形成下降沿2
_nop_();
_nop_();
ADCLK=1;//拉高CLK端
ADDI=(channel>>1)&0x1;
_nop_();
_nop_();
ADCLK=0;//拉低CLK端,形成下降沿3
ADDI=1;//控制命令結(jié)束
_nop_();
_nop_();
dat=0;
for(i=0;i<8;i++)
dat|=ADDO;//收數(shù)據(jù)
ADCLK=1;
_nop_();
_nop_();
ADCLK=0;//形成一次時(shí)鐘脈沖
_nop_();
_nop_();
dat<<=1;
if(i==7)dat|=ADDO;
for(i=0;i<8;i++)
j=0;
j=j|ADDO;//收數(shù)據(jù)
ADCLK=1;
_nop_();
_nop_();
_nop_();
_nop_();
j=j<<7;
ndat=ndat|j;
if(i<7)ndat>>=1;
ADCS=1;//拉低CS端
ADCLK=0;//拉低CLK端
ADDO=1;//拉高數(shù)據(jù)端,回到初始狀態(tài)
dat<<=8;
dat|=ndat;
return(dat); //return ad k
void data_pro(void)
unsigned int temp;
float press;
if(14<ad_data<243) //當(dāng)壓力值介于15kpa到115kpa之間時(shí),遵循線性變換
int vary=ad_data; //y=(115-15)/(243-13)*X+15kpa
press=((10.0/23.0)*vary)+9.3; //測(cè)試時(shí)補(bǔ)償值為9.3
temp=(int)(press*10); //放大10倍,便于后面的計(jì)算
press_ge=temp/1000; //取壓力值百位
press_shifen=(temp%1000)/100; //取壓力值十位
press_baifen=((temp%1000)%100)/10; //取壓力值個(gè)位
press_qianfen=((temp%1000)%100)%10; //取壓力值十分位
/*****************報(bào)警子函數(shù)*******************/
void alarm(void)
if(ad_data>=243) //如果當(dāng)前壓力值大于115kpa,
{ Alarm_led_red=0; } //則啟動(dòng)red led報(bào)警
{ Alarm_led_red=1; } //關(guān)閉red led 報(bào)警
if(ad_data<=14) //如果當(dāng)前壓力值小于16kpa
{ Alarm_led_green=0; } //則啟動(dòng)green led報(bào)警
{ Alarm_led_green=1; } //關(guān)閉green led 報(bào)警
