手里有一塊12864的液晶顯示器,今天拿起來用stm32F103做了一個(gè)工程,方便大家參考,希望對(duì)大家能夠有用。PDF文檔僅共參考,我使用的LCD的核心與pdf上的有所不同。
- #include "12864.h"
- GPIO_InitTypeDef GPIO_InitStructure;
- void Delay(__IO uint32_t nCount)
- for(; nCount != 0; nCount--);
- void send_dat(unsigned char dat)
- unsigned char i;
- //GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- for(i=0;i<8;i++)
- if((dat&0x80)==0x80) SID_1;
- if((dat&0x80)==0x00) SID_0;
- CLK_0;
- Delay(35);
- CLK_1;
- dat<<=1;
- unsigned char get_byte()
- unsigned char i,temp1=0,temp2=0;
- //GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
- for(i=0;i<8;i++)
- temp1=temp1<<1;
- CLK_0;
- Delay(25);
- CLK_1;
- Delay(20);
- CLK_0;
- if(GPIO_ReadOutputDataBit(GPIOE,GPIO_Pin_3)) temp1++;
- for(i=0;i<8;i++)
- temp2=temp2<<1;
- CLK_0;
- Delay(25);
- CLK_1;
- Delay(25);
- CLK_0;
- if(GPIO_ReadOutputDataBit(GPIOE,GPIO_Pin_3)) temp2++;
- return ((0xf0&temp1)+(0x0f&temp2));
- void check_busy()
- do
- send_dat(0xfc);
- while((get_byte()&0x8000)==0x8000);
- void send_cmd(unsigned char cmd)
- check_busy();
- send_dat(0xf8); //
- send_dat(cmd&0xf0); //
- send_dat((cmd&0x0f)<<4); //
- void write_char(unsigned char dat)
- check_busy();
- send_dat(0xfa);//rw=0;rs=1
- send_dat(dat&0xf0);
- send_dat((dat&0x0f)<<4);
- void lcd_clear() //清除顯示
- send_cmd(0x01);
- void lcd_pos(unsigned char y_add , unsigned char x_add)
- switch(y_add)
- case 1:
- send_cmd(0X80|x_add);break;
- case 2:
- send_cmd(0X90|x_add);break;
- case 3:
- send_cmd(0X88|x_add);break;
- case 4:
- send_cmd(0X98|x_add);break;
- default:break;
- void lcd_wstr(unsigned char y_add , unsigned char x_add , unsigned char *str) //
- unsigned char i;
- lcd_pos(y_add , x_add);
- for(i=0;str[i]!='\0';i++)
- write_char(str[i]);
- void write_figer(unsigned char y_add , unsigned char x_add , unsigned int figer)//在任何位置寫數(shù)字
- unsigned char d[5],i,j;
- d[4]=figer%10;
- d[3]=figer%100/10;
- d[2]=figer%1000/100;
- d[1]=figer%10000/1000;
- d[0]=figer/10000;
- for(i=0;i<5;i++)
- if(d[i]!=0)break;
- if(i==5)i--;
- if(i==4)send_dat(0x30);//數(shù)據(jù)裝完,準(zhǔn)備發(fā)送
- for(j=i;j<5;j++)
- send_dat(d[j]|0x30);//取得的數(shù)字加上0x30也即得到該數(shù)字的ASCII碼,再將該數(shù)字發(fā)送去顯示
- void lcd_init() //
- Delay(0xfff);
- send_cmd(0x30);
- send_cmd(0x0C);//0000,1100 整體顯示,游標(biāo)off,游標(biāo)位置off
- send_cmd(0x01);//0000,0001 清DDRAM
- send_cmd(0x02);//0000,0010 DDRAM地址歸位
- send_cmd(0x80);//1000,0000 設(shè)定DDRAM 7位地址000,0000到地址計(jì)數(shù)器A
- /******************* (C) COPYRIGHT 2011 奮斗STM32 *****END OF FILE****/
12864.zip
2016-6-17 13:26 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
1.16 MB, 下載次數(shù): 828, 下載積分: 黑幣 -5
評(píng)分
查看全部評(píng)分
