查看: 1957|回復: 0
1602顯示程序
ID:117256 發表于 2016-4-28 11:37 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg51.h>
#include<intrins.h>
typedef unsigned char  U8;       /* defined for unsigned 8-bits integer variable           無符號8位整型變量  */
typedef signed   char  S8;       /* defined for signed 8-bits integer variable                  有符號8位整型變量  */
typedef unsigned int   U16;      /* defined for unsigned 16-bits integer variable           無符號16位整型變量 */
typedef signed   int   S16;      /* defined for signed 16-bits integer variable           有符號16位整型變量 */
typedef unsigned long  U32;      /* defined for unsigned 32-bits integer variable           無符號32位整型變量 */
typedef signed   long  S32;      /* defined for signed 32-bits integer variable           有符號32位整型變量 */
typedef float          F32;      /* single precision floating point variable (32bits) 單精度浮點數(32位長度) */
typedef double         F64;      /* double precision floating point variable (64bits) 雙精度浮點數(64位長度) */
sbit LCD_RS = P0^7;
sbit LCD_RW = P0^6;
sbit LCD_EN = P0^5;
sbit LED = P1^0;
#define Data P2
#define   Data_0_time    4
//獨立按鍵接口 可自行修改
函數名稱:delay();
函數功能:粗略延時
void delay1(U16 i)
        U16 j,k;
        for(j=i;j>0;j--)
        for(k=125;k>0;k--);
void DelayUs2x(U8 t)
        while(--t);
void DelayMs(U8 t)
    while(t--)
     //大致延時1mS
       DelayUs2x(245);
       DelayUs2x(245);
void Delay(U16 j)
         U8 i;
         for(;j>0;j--)
                for(i=0;i<27;i++);
void  Delay_10us(void)
   U8 i;
   i--;
   i--;
   i--;
   i--;
   i--;
   i--;
函數名稱:bit lcd_busy()
函數功能:檢查LCD忙狀態
輸入值  :無
返回值  :
bit lcd_busy()
    bit result;
    LCD_RS = 0;
    LCD_EN = 1;
    delay1(1);
    result = (bit)(Data&0x80);
    LCD_EN = 0;
    return(result);
函數名稱:void LCD1602_WriteCmd(unsigned char cmd)
函數功能:寫指令數據到LCD
輸入值  :指令
返回值  :無
    LCD_RS = 0;
    LCD_EN = 0;
    delay1(1);
    Data = cmd;
    delay1(5);
    LCD_EN = 1;
    delay1(5);
    LCD_EN = 0;
    delay1(10);
函數名稱:void LCD1602_WriteData(unsigned char dat)
函數功能:寫顯示數據到LCD
輸入值  :數據
返回值  :無
void LCD1602_WriteData(U8 dat)
    LCD_RS = 1;
    LCD_EN = 0;
    Data = dat;
    delay1(1);
    LCD_EN = 1;
    delay1(1);
    LCD_EN = 0;
    delay1(10);
函數名稱:void lcd_init(void)
函數功能:LCD1602初始化函數
輸入值  :無
返回值  :無
void lcd_init(void)
    LCD_RW = 0;
    delay1(15);
    LCD1602_WriteCmd(0x01);      //清除LCD的顯示內容
    LCD1602_WriteCmd(0x38);      //16*2顯示,5*7點陣,8位數據
    delay1(5);
    delay1(5);
    delay1(5);
    LCD1602_WriteCmd(0x0c);      //開顯示,不顯示光標
    delay1(5);
    delay1(5);
函數名稱:void LCD1602_WriteChar(unsigned char x,unsigned char y,unsigned char Dat)
函數功能:寫單個字符到指定坐標
輸入值  :x:行 (可取0~1) y:列 (可取0~15) Dat:為要顯示的數據
返回值  :無
void LCD1602_WriteChar(U8 x,U8 y,U8 Dat)
  if(x==0)
    LCD1602_WriteCmd(0x80+y);
    LCD1602_WriteData(Dat);
    delay1(5);
  if(x != 0)
    LCD1602_WriteCmd(0x80+0x40+y);
    delay1(5);
函數功能:寫字符串到指定坐標    (x,y)為首個字符的顯示位置
返回值  :無
void LCD1602_WriteString(U8 x,U8 y,U8 *String)
  U8 i;
  for(i=0;String[i]!='\0';i++)
    LCD1602_WriteChar(x,y++,String[i]);
void init(void)
    TMOD = 0x20;          //定時器T1使用工作方式2
        TH1 = 253;        // 設置初值
        TL1 = 253;
        TR1 = 1;          // 開始計時
        SCON = 0x50;          //工作方式1,波特率9600bps,允許接收
        ES = 1;
        EA = 1;           // 打開所以中斷
void main(void)
        int a;
        lcd_init();
        init();
        while (1)
           LCD1602_WriteString(0,0,"GangBanHou:");
           LCD1602_WriteString(1,3,"mm");
           LCD1602_WriteChar(1,0,'f');
           a++;
           DelayMs(500);
           LCD1602_WriteChar(1,1,a+'0');
1602顯示程序.zip
39.58 KB, 下載次數: 6, 下載積分: 黑幣 -5
1602顯示程序
