查看: 2079|回復(fù): 0
12864顯示程序
ID:108795 發(fā)表于 2016-3-18 15:57 | 顯示全部樓層 |閱讀模式
#include "reg51.h"
/********IO引腳定義***********************************************************/
sbit LCD_RS=P1^0;
sbit LCD_RW=P1^1;
sbit LCD_E=P1^2;
sbit PSB =P1^6;//PSB腳為12864-12系列的串、并通訊功能切換,我們使用8位并行接口,PSB=1
sbit RES = P1^3;
//sbit KEY_ADD=P3^3;         //定義按鍵輸入端口
//sbit KEY_DEC=P3^2;
/********宏定義***********************************************************/
#define LCD_Data P0
#define Busy    0x80 //用于檢測LCD狀態(tài)字中的Busy標(biāo)識
#define Key P2
unsigned char curr,currold,key;//全局變量,當(dāng)前箭頭位置
/********函數(shù)聲明*************************************************************/
void WriteDataLCD(unsigned char WDLCD);
void WriteCommandLCD(unsigned char WCLCD,BuysC);
unsigned char ReadDataLCD(void);
unsigned char ReadStatusLCD(void);
void LCDInit(void);
void LCDClear(void);
void LCDFlash(void);
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData);
void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData);
void DisplayImage (unsigned char code *DData);
void Delay5Ms(void);
void Delay400Ms(void);
void CGRAM();
void DisplayCGRAM(unsigned char x,unsigned char y);
void LCD_PutString(unsigned char x,unsigned char y,unsigned char code *s);
void DisplayUpdata(void);
void DelayUs2x(unsigned char t);
void displaycaidan();
void denglu1();
void keyscan();
void shianshi();
/********數(shù)據(jù)定義*************************************************************/
code unsigned char  uctech[] = {"  呷哺  呷哺"};
code unsigned char  net[] = {"    餐  飲  "};
code unsigned char  mcu[] = {"  美食的首選"};
code unsigned char  qq[] = {"  QQ: 1111111  "};
code unsigned char  denglu[] = {"  歡迎登陸"};
code unsigned char  ID[] = {"ID:"};
unsigned char code user16x16[]={ //箭頭圖片
0x00,0x00,0x20,0x00,0x30,0x00,0x38,0x00,0x3C,0x00,0x3E,0x00,0x3F,0x00,0x3F,0x80,
0x3F,0xC0,0x3F,0x80,0x3F,0x00,0x3E,0x00,0x3C,0x00,0x38,0x00,0x30,0x00,0x20,0x00,
unsigned char code *MainMenu[]=
{"  1.雞蛋"},
{"  2.番茄"},
{"  3.番茄炒蛋"},
{"  4.蛋餃"},
{"  5.煎包"},
{"  6.獅子頭"},
{"  7.尖椒炒肉"},
{"  8.手撕包菜"},
{"  9.酸菜魚"},
{"  10. 回鍋肉"},
{"  11. 螞蟻上樹"},
{"  12. 紅燒肉"},
{"  13. 紅燒豬蹄"},
{"  14: 辣子雞丁"},
{"  15: 雞丁米線"},
{"  16. 麻辣雞翅"}
code unsigned char tmp[]={//128*64點(diǎn)陣圖形數(shù)據(jù)
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x07,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x01,0xF1,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x04,0x01,0xFF,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0xF8,0x01,0xFF,0x80,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x00,0x04,0x00,
      0x00,0x04,0x00,0x02,0xFF,0xE0,0x00,0x00,0x00,0x01,0x10,0x00,0x00,0x00,0x04,0x40,
      0x00,0x00,0x00,0x02,0xFF,0xE0,0x00,0x1F,0x80,0x01,0x38,0x00,0x7E,0x00,0x04,0xE0,
      0x00,0x00,0x00,0x0C,0xFF,0xF0,0x03,0x3C,0xC0,0x01,0xF8,0x0C,0xF3,0x00,0x07,0xE0,
      0x00,0x00,0x00,0x71,0xFF,0xF8,0x07,0xC8,0xC0,0xEF,0x80,0x1F,0x23,0x03,0xBE,0x00,
      0x00,0x40,0x00,0x01,0xFF,0xFC,0x19,0x7E,0x84,0xFB,0x00,0x65,0xFA,0x13,0xEC,0x00,
      0x03,0x00,0x00,0x1F,0xFF,0xFC,0x1B,0x7D,0x83,0xE7,0xC0,0x6D,0xF6,0x0F,0x9F,0x00,
      0x0C,0x00,0x00,0xFF,0xFF,0xFE,0x1F,0xC9,0x03,0x67,0x30,0x7F,0x24,0x0D,0x9C,0xC0,
      0x10,0x00,0x01,0xFF,0xFF,0xFE,0x1E,0x7E,0x03,0xCD,0x90,0x79,0xF8,0x0F,0x36,0x40,
      0x10,0x40,0x07,0xFF,0xFF,0xCF,0x08,0x38,0x03,0x4F,0xD0,0x20,0xE0,0x0D,0x3F,0x40,
      0x10,0x40,0x0F,0xFF,0xFF,0xCF,0x00,0x08,0x01,0x09,0x90,0x00,0x20,0x04,0x26,0x40,
      0x0D,0x80,0x0F,0xFF,0xFF,0xC7,0x00,0x08,0x00,0x0B,0xD0,0x00,0x20,0x00,0x2F,0x40,
      0x06,0x00,0x0F,0xFF,0xFF,0xE7,0x00,0x08,0x00,0x0B,0x10,0x00,0x20,0x00,0x2C,0x40,
      0x00,0x00,0x07,0xFF,0xFF,0xFF,0x80,0x08,0x00,0x09,0x10,0x00,0x20,0x00,0x24,0x40,
      0x00,0x00,0x07,0xFF,0xE7,0xFF,0x80,0x08,0x00,0x09,0xF0,0x00,0x20,0x00,0x27,0xC0,
      0x00,0x00,0x03,0xFF,0xE3,0xFF,0x00,0x08,0x00,0x00,0x70,0x00,0x20,0x00,0x01,0xC0,
      0x00,0x00,0x01,0xFF,0xE3,0xFF,0x00,0x08,0x00,0x00,0x30,0x00,0x20,0x00,0x00,0xC0,
      0x00,0x00,0x00,0xFF,0xE1,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x7F,0xF3,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x40,0x00,0x3F,0xFF,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x40,0x00,0x1F,0xFF,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x18,0x1F,0xFF,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x24,0x18,0x1F,0xFF,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x16,0x18,0x1F,0xFF,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x16,0x08,0x7F,0xFF,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x12,0x00,0x7F,0xFF,0xFC,0x00,0x00,0x00,0x0E,0xE0,0x02,0x14,0x00,0x00,0x00,
      0x00,0x10,0x01,0xF7,0xFF,0xFC,0x00,0x00,0x00,0x0E,0x70,0x03,0x14,0x00,0x00,0x00,
      0x00,0x08,0x0F,0xEB,0xFF,0xFC,0x00,0x00,0x00,0x09,0xE0,0x07,0x1C,0x00,0x00,0x00,
      0x00,0x07,0xFF,0xC0,0xFF,0xFC,0x00,0x00,0x00,0x3E,0xF0,0x06,0x28,0x00,0x00,0x00,
      0x00,0x01,0xFF,0x84,0x3F,0xFE,0x00,0x00,0x00,0x2B,0x80,0x0F,0xAF,0x00,0x00,0x00,
      0x00,0x01,0xFE,0x00,0x3F,0xFE,0x00,0x00,0x00,0x3F,0x60,0x0F,0xDF,0x80,0x00,0x00,
      0x00,0x00,0x88,0x00,0x7F,0xFE,0x00,0x00,0x00,0x3F,0xB0,0x1F,0xDD,0x00,0x00,0x00,
      0x00,0x00,0xE8,0x22,0x7F,0xFE,0x00,0x00,0x00,0xCF,0xDC,0x1D,0xBA,0x00,0x00,0x00,
      0x00,0x00,0x48,0x22,0x7F,0xFF,0x00,0x00,0x00,0x1E,0xCF,0x35,0xAC,0x00,0x00,0x00,
      0x00,0x00,0x40,0x20,0x7F,0xFF,0x00,0x00,0x00,0x27,0xC1,0x66,0x88,0x00,0x00,0x00,
      0x00,0x00,0x60,0x20,0xFF,0xFF,0x00,0x00,0x00,0x46,0x80,0x64,0x9C,0x00,0x00,0x00,
      0x00,0x01,0x00,0x21,0xFF,0xFF,0x00,0x00,0x01,0x8F,0xC0,0x45,0x17,0x00,0x00,0x00,
      0x00,0x01,0x00,0x01,0xFF,0xFF,0x80,0x00,0x00,0x0D,0xE0,0x05,0x73,0x80,0x00,0x00,
      0x00,0x00,0x00,0x42,0xFF,0xFF,0x80,0x00,0x00,0x0B,0xE0,0x07,0x61,0xC0,0x00,0x00,
      0x00,0x00,0x00,0x44,0xFF,0xFF,0x80,0x00,0x00,0x09,0xF0,0x06,0x00,0x40,0x00,0x00,
      0x00,0x02,0x00,0x84,0xFF,0xFF,0x80,0x00,0x00,0x0F,0x10,0x02,0x00,0x00,0x00,0x00,
      0x00,0x02,0x00,0x88,0xFF,0xFF,0xC0,0x00,0x00,0x04,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x02,0x00,0xF8,0xFF,0xFF,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x04,0xF8,0xFF,0xEF,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x04,0x08,0xF8,0xFF,0xFF,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x08,0x00,0xC1,0x7F,0xFF,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x30,0x20,0xC1,0xFF,0xFF,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x20,0x80,0xF3,0xFF,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x10,0x40,0xFF,0xFF,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x08,0x40,0x7F,0x8F,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
/***********主函數(shù)開始********************************************************/
void main(void)
        Delay400Ms();         //啟動等待,等LCD講入工作狀態(tài)
        LCDInit();                 //LCD初始化
        Delay5Ms();
        LCDClear();
                DisplayImage(tmp);                                //顯示圖形
                Delay400Ms();
                Delay400Ms();
                Delay400Ms();
                Delay400Ms();
                Delay400Ms();
                Delay400Ms();
                LCDClear();
                DisplayListChar(0,1,uctech);        //顯示字庫中的中文數(shù)字
                DisplayListChar(0,2,net);                //顯示字庫中的中文數(shù)字
                DisplayListChar(0,3,mcu);                //顯示字庫中的中文
                DisplayListChar(0,4,qq);                //顯示字庫中的中文數(shù)字
                Delay400Ms();
                Delay400Ms();
                //LCDFlash();                                                //閃爍效果        //延時(shí)片刻(可不要)
             LCDInit();   //初始化
        CGRAM();     //寫入自定義字符
        DisplayUpdata();
                //denglu1();
    shianshi();
        //displaycaidan();
/*********************菜單顯示主程序**************************************/
if(curr!=currold) //光標(biāo)位置變化,則更新顯示
    DisplayUpdata();
        currold=curr;
if(key==54)  //如果檢測到低電平,說明按鍵按下
         //Delay5Ms(); //延時(shí)去抖,一般10-20ms
        // keyscan();
    // if(key==54)     //再次確認(rèn)按鍵是否按下,沒有按下則退出
        //while(key==54);//如果確認(rèn)按下按鍵等待按鍵釋放,沒有釋放則一直等待
                   if(curr<sizeof(MainMenu)/sizeof(MainMenu[0])-1)//判斷數(shù)組中數(shù)值個(gè)數(shù)
                          curr++;
                          key=16;
if(key==55)  //如果檢測到低電平,說明按鍵按下
         //keyscan();
     //if(key==55)     //再次確認(rèn)按鍵是否按下,沒有按下則退出
        //while(key==55);//如果確認(rèn)按下按鍵等待按鍵釋放,沒有釋放則一直等待
               if(curr>0)
                          curr--;
           key=16;
/**********************登陸界面*******************************/
void denglu1()
unsigned char num;
LCDClear();
DisplayListChar(0,1,denglu);
DisplayListChar(0,2,ID);
DisplayListChar(0,4,"確定        取消");
num=2;
while(key!=51)
if(num<=7)
DelayUs2x(10);
keyscan();
switch(key)
case 15:DisplayOneChar(num,2,0x31);num++;key=16;break;
case 14:DisplayOneChar(num,2,0x34);num++;key=16;break;
case 11:DisplayOneChar(num,2,0x32);num++;key=16;break;
case 10:DisplayOneChar(num,2,0x35);num++;key=16;break;
case 9:DisplayOneChar(num,2,0x38);num++;key=16;break;
case 13:DisplayOneChar(num,2,0x37);num++;key=16;break;
case 7:DisplayOneChar(num,2,0x33);num++;key=16;break;
case 6:DisplayOneChar(num,2,0x36);num++;key=16;break;
case 5:DisplayOneChar(num,2,0x39);num++;key=16;break;
if(key==51)
LCDClear();
num=2;
/*************************點(diǎn)菜*************************************/
void shianshi()
unsigned char num;
displaycaidan();
num=2;
keyscan();
while(key!=51)
DelayUs2x(10);
keyscan();
switch(key)
case 0:DisplayOneChar(num,4,0x30);num++;key=16;break;
case 1:DisplayOneChar(num,4,0x31);num++;key=16;break;
case 4:DisplayOneChar(num,4,0x34);num++;key=16;break;
case 2:DisplayOneChar(num,4,0x32);num++;key=16;break;
case 5:DisplayOneChar(num,4,0x35);num++;key=16;break;
case 8:DisplayOneChar(num,4,0x38);num++;key=16;break;
case 7:DisplayOneChar(num,4,0x37);num++;key=16;break;
case 3:DisplayOneChar(num,4,0x33);num++;key=16;break;
case 6:DisplayOneChar(num,4,0x36);num++;key=16;break;
case 9:DisplayOneChar(num,4,0x39);num++;key=16;break;
case 54:displaycaidan();break;
case 55:displaycaidan();break;
if(num==4)
num=2;
if(key==51)
num=2;
displaycaidan();
/**************************鍵盤掃描***************************************/
/*void keyscan()
        unsigned char temp;
        P2=0xfe;
        temp=P2;
        temp=temp&0xf0;
        if(temp!=0xf0)
                Delay5Ms();
                temp=P2;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        temp=P2;
                                switch(temp)
                                   case        0xee:
                                                key=0;
                                                        break;
                                   case 0xde:
                                                key=1;
                                                        break;
                                        case 0xbe:
                                                key=2;
                                                        break;
                                        case 0x7e:
                                                key=3;
                                                        break;
                  while(temp!=0xf0)
                                        temp=P2;
                                        temp=temp&0xf0;
        P2=0xfd;
        temp=P2;
        temp=temp&0xf0;
        if(temp!=0xf0)
                Delay5Ms();
                temp=P2;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        temp=P2;
                                switch(temp)
                                   case        0xed:
                                                key=4;
                                                        break;
                                   case 0xdd:
                                                key=5;
                                                        break;
                                        case 0xbd:
                                                key=6;
                                                        break;
                                        case 0x7d:
                                                key=7;
                                                        break;
                  while(temp!=0xf0)
                                        temp=P2;
                                        temp=temp&0xf0;
        P2=0xfb;
        temp=P2;
        temp=temp&0xf0;
        if(temp!=0xf0)
                Delay5Ms();
                temp=P2;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        temp=P2;
                                switch(temp)
                                   case        0xeb:
                                                key=8;
                                                        break;
                                   case 0xdb:
                                                key=9;
                                                        break;
                                        case 0xbb:
                                                key=10;
                                                        break;
                                        case 0x7b:
                                                key=11;
                                                        break;
                  while(temp!=0xf0)
                                        temp=P2;
                                        temp=temp&0xf0;
        P2=0xf7;
        temp=P2;
        temp=temp&0xf0;
        if(temp!=0xf0)
                Delay5Ms();
                temp=P2;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        temp=P2;
                                switch(temp)
                                   case        0xe7:
                                                key=12;
                                                        break;
                                   case 0xd7:
                                                key=13;
                                                        break;
                                        case 0xb7:
                                                key=14;
                                                        break;
                                        case 0x77:
                                                key=15;
                                                        break;
                  while(temp!=0xf0)
                                        temp=P2;
                                        temp=temp&0xf0;
void keyscan()
        unsigned char temp;
        key=16;
                 P2=0xfe;
                        temp=P2;
                        temp=temp&0xf0;
                        if(temp!=0xf0)
                                        Delay5Ms();
                                        temp=P2;
                                        temp=temp&0xf0;
                                        if(temp!=0xf0)
                                                temp=P2;
                                        switch(temp)
                                                        case 0xee:key=1;
        break;
                                                        case 0xde:key=2;
        break;
                                                        case 0xbe:key=3;
        break;
                                                        case 0x7e:key=50; //用A用50表示
        break;
                                        while(temp!=0xf0)
                                                        temp=P2;
                                                        temp=temp&0xf0;     //等待按鍵釋放//*
                                //send(key);
                        P2=0xfd;
                        temp=P2;
                        temp=temp&0xf0;
                        if(temp!=0xf0)
                                        Delay5Ms();
                                        temp=P2;
                                        temp=temp&0xf0;
                                        if(temp!=0xf0)
                                                temp=P2;
                                        switch(temp)
                                                        case 0xed:key=4;
        break;
                                                        case 0xdd:key=5;
        break;
                                                        case 0xbd:key=6;
        break;
                                                        case 0x7d:key=51;
        break;
                                        while(temp!=0xf0)
                                                        temp=P2;
                                                        temp=temp&0xf0;
                                //send(key);
                        P2=0xfb;
                        temp=P2;
                        temp=temp&0xf0;
                        if(temp!=0xf0)
                                        Delay5Ms();
                                        temp=P2;
                                        temp=temp&0xf0;
                                        if(temp!=0xf0)
                                                temp=P2;
                                        switch(temp)
                                                        case 0xeb:key=7;
        break;
                                                        case 0xdb:key=8;
        break;
                                                        case 0xbb:key=9;
        break;
                                                        case 0x7b:key=52;
        break;
                                        while(temp!=0xf0)
                                                        temp=P2;
                                                        temp=temp&0xf0;
                                //send(key);
                        P2=0xf7;
                        temp=P2;
                        temp=temp&0xf0;
                        if(temp!=0xf0)
                                        Delay5Ms();
                                        temp=P2;
                                        temp=temp&0xf0;
                                        if(temp!=0xf0)
                                                temp=P2;
                                        switch(temp)
                                                        case 0xe7:key=54;//*
        break;
                                                        case 0xd7:key=0;
        break;
                                                        case 0xb7:key=55; //'#'
        break;
                                                        case 0x77:key=53;
        break;
                                        while(temp!=0xf0)
                                                        temp=P2;
                                                        temp=temp&0xf0;
                                //send(key);
/***********寫數(shù)據(jù)********************************************************/
        ReadStatusLCD(); //檢測忙
        LCD_RS = 1;
        LCD_RW = 0;
        LCD_E = 1;LCD_Data = WDLCD;
        LCD_E = 1;
        LCD_E = 1;
        LCD_E = 0;
/***********寫指令********************************************************/
void WriteCommandLCD(unsigned char WCLCD,BuysC) //BuysC為0時(shí)忽略忙檢測
        if (BuysC) ReadStatusLCD(); //根據(jù)需要檢測忙
        LCD_RS = 0;
        LCD_RW = 0;
        LCD_E = 1; LCD_Data = WCLCD;
        LCD_E = 1;
        LCD_E = 1;
        LCD_E = 0;
/***********讀數(shù)據(jù)********************************************************/
        unsigned char LCDDA;
        LCD_RS = 1;
        LCD_RW = 1;
        LCD_E = 1;
        LCD_E = 1;
        LCDDA=LCD_Data;
        LCD_E = 0;
        return(LCDDA);
/***********讀狀態(tài)*******************************************************/
        LCD_Data = 0xFF;
        LCD_RS = 0;
        LCD_RW = 1;
        LCD_E = 1;
        LCD_E = 1;
        while (LCD_Data & Busy); //檢測忙信號
        LCD_E = 0;
        return(1);
/***********初始化********************************************************/
void LCDInit(void)
        Delay5Ms();           //大于40MS的延時(shí)程序
    PSB=1;                 //設(shè)置為8BIT并口工作模式
    RES=0;                 //復(fù)位
    RES=1;                 //復(fù)位置高
    Delay5Ms();
    WriteCommandLCD(0x30,1);      //選擇基本指令集
    Delay5Ms();         //延時(shí)大于100us
    WriteCommandLCD(0x30,1);     //選擇8bit數(shù)據(jù)流
    Delay5Ms();         //延時(shí)大于37us
    WriteCommandLCD(0x0C,1);       //開顯示(無游標(biāo)、不反白)
    WriteCommandLCD(0x01,1);      //清除顯示,并且設(shè)定地址指針為00H
    Delay5Ms();           //延時(shí)大于10ms
    WriteCommandLCD(0x06,1);      //指定在資料的讀取及寫入時(shí),設(shè)定游標(biāo)的移動方向及指定顯示的移位,光標(biāo)從右向左加1位移動
/***********清屏********************************************************/
void LCDClear(void)
        WriteCommandLCD(0x01,1); //顯示清屏
        //WriteCommandLCD(0x34,1); // 顯示光標(biāo)移動設(shè)置
        //WriteCommandLCD(0x30,1); // 顯示開及光標(biāo)設(shè)置
/***********閃爍效果********************************************************/
void LCDFlash(void)
        WriteCommandLCD(0x08,1); //顯示清屏
        Delay400Ms();
        WriteCommandLCD(0x0c,1); // 顯示開及光標(biāo)設(shè)置
        Delay400Ms();
        Delay400Ms();
        Delay400Ms();
        Delay400Ms();
/***********按指定位置顯示一個(gè)字符*******************************************/
        if(Y<1)
                Y=1;
        if(Y>4)
                Y=4;
        X &= 0x0F;                         //限制X不能大于16,Y不能大于1
        switch(Y){
        case 1:X|=0X80;break;
        case 2:X|=0X90;break;
        case 3:X|=0X88;break;
        case 4:X|=0X98;break;
        WriteCommandLCD(X, 0); //這里不檢測忙信號,發(fā)送地址碼
        WriteDataLCD(DData);
/***********按指定位置顯示一串字符*****************************************/
        switch(Y)
          case 1: WriteCommandLCD((0x80+X),1);break;
          case 2: WriteCommandLCD((0x90+X),1);break;
          case 3: WriteCommandLCD((0x88+X),1);break;
          case 4: WriteCommandLCD((0x98+X),1);break;
      default:break;
while(*DData>0)
      WriteDataLCD(*DData);
      DData++;
      Delay5Ms();
/********輸出128*64圖形數(shù)據(jù)************************************************/
void DisplayImage (unsigned char code *DData){
        unsigned char x,y,i;
        unsigned int tmp=0;
        for(i=0;i<9;){                                                //分兩屏,上半屏和下半屏,因?yàn)槠鹗嫉刂凡煌枰珠_
        for(x=0;x<32;x++){                                        //32行
                WriteCommandLCD((0x80+x),1);        //列地址
                WriteCommandLCD((0x80+i),1);        //行地址,下半屏,即第三行地址0X88
                for(y=0;y<16;y++)
                        WriteDataLCD(DData[tmp+y]);//讀取數(shù)據(jù)寫入LCD
                tmp+=16;
        i+=8;
        WriteCommandLCD(0x36,1);                        //擴(kuò)充功能設(shè)定
/***********短延時(shí)********************************************************/
void Delay5Ms(void)
        unsigned int TempCyc = 5552;
        while(TempCyc--);
while(--t);
/***********長延時(shí)********************************************************/
        unsigned char TempCycA = 5;
        unsigned int TempCycB;
        while(TempCycA--){
                  TempCycB=7269;
                  while(TempCycB--);
                   用戶自定義字符
void CGRAM()
     int i;
     WriteCommandLCD(0x40,1);
     for(i=0;i<16;i++)
            WriteDataLCD(user16x16[i*2]);
        WriteDataLCD(user16x16[i*2+1]);
                   顯示用戶自定義字符
switch(y)
          case 1: WriteCommandLCD((0x80+x),1);break;
          case 2: WriteCommandLCD((0x90+x),1);break;
          case 3: WriteCommandLCD((0x88+x),1);break;
          case 4: WriteCommandLCD((0x98+x),1);break;
      default:break;
    WriteDataLCD(00);
    WriteDataLCD(00);
                   顯示字符串
x:橫坐標(biāo)值,范圍0~8
y:縱坐標(biāo)值,范圍1~4
switch(y)
      default:break;
while(*s>0)
      WriteDataLCD(*s);
      s++;
      DelayUs2x(10);
                 調(diào)用顯示更新
    unsigned char num;
        LCDClear();
        num=sizeof(MainMenu)/sizeof(MainMenu[0]);//判斷數(shù)組中數(shù)值個(gè)數(shù)
        if((0+(curr/4)*4)<num)
      LCD_PutString(0,1,MainMenu[0+(curr/4)*4]);
        else //如果超出數(shù)組最大元素,則寫空信息,不判斷此信息可能會出現(xiàn)亂碼
          LCD_PutString(0,1,"");
        if((1+(curr/4)*4)<num)
          LCD_PutString(0,2,MainMenu[1+(curr/4)*4]);
          LCD_PutString(0,2,"");
        if((2+(curr/4)*4)<num)
          LCD_PutString(0,3,MainMenu[2+(curr/4)*4]);
          LCD_PutString(0,3,"");
        if((3+(curr/4)*4)<num)
          LCD_PutString(0,4,MainMenu[3+(curr/4)*4]);
          LCD_PutString(0,4,"");
        DisplayCGRAM(0,curr%4+1);
參與人數(shù) 2黑幣 +54 收起 理由
yangqijun + 4 共享資料的黑幣獎勵!
