2016-2-2 02:55 上傳
- /**********Nokia 5110 LCD 顯示程序***************/
- /**********作者:鄭文 ***************/
- /**********芯片:AT89S52 **************/
- /*功能:支持中文顯示、字符顯示、圖片顯示********/
- #include <reg52.h>
- #include <intrins.h>
- #include "english_6x8_pixel.h"
- #include "picture84x48.h"
- #include "Nokia_5110.h"
- #include "18b20.h"
- #define uchar unsigned char
- #define uint unsigned int
- uchar tem_h,tem_l,tem_f,tem_f1,tem_f2;
- uint tem; //溫度讀取后*10后存儲空間地址
- float tem_read; //溫度讀取保存地址空間
- void Delay1ms(unsigned int count);
- void temperature_read_charge(void);
- void nokia_5110_picture();//寫一屏圖
- /************毫秒延時程序********************/
- unsigned int i,j;
- for(i=0;i<count;i++)
- for(j=0;j<120;j++);
- /*void temperature_read_charge(void)
- tem_read=ReadTemperature();
- tem=tem_read*1000; //溫度精確到小數點后3位
- tem_h=tem/10000+0x30; //溫度高位
- tem_l=( tem-(tem_h-0x30)*10000 )/1000+0x30; //溫度低位
- tem_f=( tem-(tem_h-0x30)*10000-(tem_l-0x30)*1000 )/100+0x30;
- tem_f1=( tem-(tem_h-0x30)*10000-(tem_l-0x30)*1000-(tem_f-0x30)*100 )/10+0x30;
- tem_f2=( tem-(tem_h-0x30)*10000-(tem_l-0x30)*1000-(tem_f-0x30)*100-(tem_f1-0x30)*10 )+0x30;
- Delay1ms(100);
- void nokia_5110_picture()//寫一屏圖
- uchar e;
- uchar t;
- uchar k;
- uint d;
- d=0;
- for(t=0;t<6;t++)
- for(k=0;k<84;k++)
- e=dal[d];
- write_byte(e,1);
- d=d+1;
- /*****************主程序********************/
- void main(void)
- unsigned main_i,x,y;
- unsigned xnum ,ynum;
- float T_temp;
- uchar i;
- uchar moni_temp;
- P2=0X00;
- LED_A =1;
- LCD_VDD =1;
- LCD_GND =0;
- LCD_Init(); //初始化液晶
- LCD_Clear();
- /***********指定地址顯示漢字(x,y,table)*********************/
- /***********取點(x,y,byte數據)*************/
- /*其中X=[0,83] Y=[0,5] byte 顯示是從下到上 */
- nokia_5110_picture();
- LCD_set_XY(42,3);
- LCD_write_char(124);
- LCD_write_char('C');
- /* while(1)
- for(i=0;i<8;i++)
- LCD_set_XY(68,4);
- LCD_write_char(125+i);
- Delay1ms(100);
- for(i=0;i<8;i++)
- LCD_set_XY(68,3);
- Delay1ms(100);
- for(i=0;i<8;i++)
- LCD_set_XY(68,2);
- Delay1ms(100);
- for(i=0;i<8;i++)
- LCD_set_XY(68,1);
- Delay1ms(100);
- for(i=0;i<8;i++)
- LCD_set_XY(68,0);
- Delay1ms(100);
- LCD_set_XY(68,0);
- LCD_write_char(125);
- LCD_set_XY(68,1);
- LCD_set_XY(68,2);
- LCD_set_XY(68,3);
- LCD_set_XY(68,4);
- while(1)
- /********溫度數據的讀取和轉換*************/
- tem=tem_read*1000; //溫度精確到小數點后一位08.1.8
- //Delay1ms(5);
- LCD_set_XY(12,3);
- LCD_write_char(tem_h);
- // Delay1ms(5);
- LCD_write_char(tem_l);
- // Delay1ms(5);
- LCD_write_char('.');
- // Delay1ms(5);
- LCD_write_char(tem_f);
- // Delay1ms(5);
- LCD_write_char(tem_f1);
- //Delay1ms(5);
- moni_temp=((tem_h-0x30)*10+tem_l-0x30)+1;//加1是修正值
- if(moni_temp>0 && moni_temp<8)
- LCD_set_XY(68,3);
- LCD_set_XY(68,2);
- LCD_set_XY(68,1);
- LCD_set_XY(68,0);
- LCD_set_XY(68,4);
- LCD_write_char(125+moni_temp);
- else if(moni_temp>=8 && moni_temp<16)
- LCD_set_XY(68,2);
- LCD_set_XY(68,1);
- LCD_set_XY(68,0);
- LCD_set_XY(68,4);
- LCD_write_char(132);
- LCD_set_XY(68,3);
- LCD_write_char(125+moni_temp-8);
- else if(moni_temp>=16 && moni_temp<24)
- LCD_set_XY(68,1);
- LCD_set_XY(68,0);
- LCD_set_XY(68,4);
- LCD_set_XY(68,3);
- LCD_set_XY(68,2);
- LCD_write_char(125+moni_temp-16);
- else if(moni_temp>=24 && moni_temp<32)
- LCD_set_XY(68,0);
- LCD_set_XY(68,4);
- LCD_set_XY(68,3);
- LCD_set_XY(68,2);
- LCD_set_XY(68,1);
- LCD_write_char(125+moni_temp-24);
- else if(moni_temp>=32 && moni_temp<40)
- LCD_set_XY(68,4);
- LCD_set_XY(68,3);
- LCD_set_XY(68,2);
- LCD_set_XY(68,1);
- LCD_set_XY(68,0);
- LCD_write_char(125+moni_temp-32);
- else
