查看: 3002|回復: 0
stm32代碼升級總結
ID:104126 發表于 2016-1-23 01:05 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
看了那么多stm32代碼升級的教程,有兩個疑點:1,修改中斷向量表偏移是bootloader修還是app代碼要修?
答:app代碼
2:,修改rom的起始地址或RAM的地址在哪里?
答:app代碼
3,bootloader代碼干啥?
答:就寫段程序就行。
intmain(void)
       u8t,key;
       u16oldcount=0;     //老的串口接收數據值
       u16applenth=0;     //接收到的app代碼長度
       u8clearflag=0;
       uart_init(256000);      //串口初始化為256000
       delay_init();               //延時初始化
       LCD_Init();            //液晶初始化
       LED_Init();                 //初始化與LED連接的硬件接口
      KEY_Init();                  //按鍵初始化
POINT_COLOR=RED;//設置字體為紅色
       LCD_ShowString(60,50,200,16,16,"WarshipSTM32");
       LCD_ShowString(60,70,200,16,16,"IAPTEST");
       LCD_ShowString(60,90,200,16,16,"ATOM@ALIENTEK");
       LCD_ShowString(60,110,200,16,16,"2012/9/24");
       LCD_ShowString(60,130,200,16,16,"WK_UP:CopyAPP2FLASH");
       LCD_ShowString(60,150,200,16,16,"KEY1:EraseSRAM APP");
       LCD_ShowString(60,170,200,16,16,"KEY0:RunSRAM APP");
       LCD_ShowString(60,190,200,16,16,"KEY2:RunFLASH APP");
       POINT_COLOR=BLUE;
       //顯示提示信息
       POINT_COLOR=BLUE;//設置字體為藍色
             if(USART_RX_CNT)
                     if(oldcount==USART_RX_CNT)
//新周期內,沒有收到任何數據,認為本次數據接收完成.
                            applenth=USART_RX_CNT;
                            oldcount=0;
                            USART_RX_CNT=0;
                            printf("用戶程序接收完成!\r\n");
                            printf("代碼長度:?ytes\r\n",applenth);
                     }elseoldcount=USART_RX_CNT;
              t++;delay_ms(10);
              if(t==30)
                     LED0=!LED0;t=0;
                     if(clearflag)
                            clearflag--;
                            if(clearflag==0)LCD_Fill(60,210,240,210+16,WHITE);//清除顯示
              key=KEY_Scan(0);
              if(key==KEY_UP)
                     if(applenth)
                            printf("開始更新固件...\r\n");
                            LCD_ShowString(60,210,200,16,16,"CopyingAPP2FLASH...");
                           if(((*(vu32*)(0X20001000+4))&0xFF000000)==0x08000000)
//判斷是否為0X08XXXXXX.
iap_write_appbin(FLASH_APP1_ADDR,USART_RX_BUF,
applenth);//更新FLASH代碼
                                   LCD_ShowString(60,210,200,16,16,"CopyAPP Successed!!");
                                   printf("固件更新完成!\r\n");
                            }else
                                   LCD_ShowString(60,210,200,16,16,"IllegalFLASHAPP!  ");
                                   printf("非FLASH應用程序!\r\n");
                    }else
                            printf("沒有可以更新的固件!\r\n");
                            LCD_ShowString(60,210,200,16,16,"NoAPP!");
                     clearflag=7;//標志更新了顯示,并且設置7*300ms后清除顯示
              if(key==KEY_DOWN)
                     if(applenth)
                            printf("固件清除完成!\r\n");
                            LCD_ShowString(60,210,200,16,16,"APPErase Successed!");
                            applenth=0;
                     }else
                            printf("沒有可以清除的固件!\r\n");
              if(key==KEY_LEFT)
了解完上面的教程以后,開始動手實踐,但問題來了:
1,必須找一個能打開bin文件的軟件,如用ultraedit
2,將純數據的二進制拷出來,然后用串口助手發送給單片機
3,發現升級失敗,后來發現從ultraedit里拷貝出來的數據每一行后面都有一個換行,所以拷貝到word里,將所有的換行去掉,因為一個換行就是一個字節,盡管在用串口助手的HEX方式發送時,看不到那個換行的字節,但是實驗發現,是多一個字節的。
4,具體操作如下:
第一步:按Ctrl + H
第二步:在“查找內容”后面,輸入:^p (注意,^就是數字6上面的那個符號,p是小寫的)
第三步:在“替換為”后面,不輸入任何內容。
第四步:點“全部替換”。
5,發現好使。
