數碼管顯示部分的原理圖:http://www.raoushi.com/f/51hei-5.pdf
源代碼如下:
- #include<reg51.h>
- #define uchar unsigned char
- #define uint unsigned int
- bit write=0;
- sbit sda=P2^0;
- sbit scl=P2^1;
- sbit wela=P2^7;
- sbit dula=P2^6;
- uchar sec,tcnt;
- uchar smg_change[6]={10,10,10,10,10,10};
- unsigned char code duanma[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00};
- unsigned char code weima[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf};
- void delay()
- void delay1ms(uchar t)
- uchar i,j;
- for(i=t;i>0;i--)
- for(j=110;j>0;j--);
- void init()
- sda=1;
- delay();
- scl=1;
- delay();
- void start()
- sda=1;
- delay();
- scl=1;
- delay();
- sda=0;
- delay();
- scl=0;
- void stop()
- sda=0;
- delay();
- scl=1;
- delay();
- sda=1;
- delay();
- scl=0;
- void respons()
- uchar i;
- sda=1;
- scl=1;
- delay();
- while((sda==1)&&(i<250))
- i++;
- scl=0;
- delay();
- void no_ack()
- sda=1;
- scl=1;
- scl=0;
- void write_byte(uchar date)
- uchar i;
- for(i=0;i<8;i++)
- date=date<<1;
- scl=0;
- delay();
- sda=CY;
- delay();
- scl=1;
- delay();
- scl=0;
- uchar read_byte()
- uchar i,k;
- for(i=0;i<8;i++)
- k<<=1;
- scl=1;
- delay();
- sda=1;
- if(sda)
- k|=0x01;
- scl=0;
- delay();
- return k;
- void write_add(uchar address,uchar date)
- start();
- write_byte(0xa0);
- respons();
- write_byte(address);
- respons();
- write_byte(date);
- respons();
- stop();
- uchar read_add(uchar address)
- uchar date;
- start();
- write_byte(0xa0);
- respons();
- respons();
- start();
- write_byte(0xa1);
- respons();
- date=read_byte();
- no_ack();
- stop();
- return date;
- void display(uchar bai,uchar shi)
- dula=0;
- P0=duanma[bai];
- dula=1;
- dula=0;
- wela=0;
- P0=weima[0];
- wela=1;
- wela=0;
- delay1ms(5);
- dula=0;
- P0=duanma[shi];
- dula=1;
- dula=0;
- wela=0;
- P0=weima[1];
- wela=1;
- wela=0;
- delay1ms(5);
- void init_time()
- TMOD=0x01;
- TH0=(65536-50000)/256;
- TL0=(65536-50000)%256;
- ET0=1;
- TR0=1;
- EA=1;
- void main()
- init();
- init_time();
- sec=read_add(0);
- if(sec>60)
- sec=sec-250;
- while(1)
- display(sec/10,sec%10);
- ET0=0;
- write_add(0,sec);
- ET0=1;
- void timer0() interrupt 1
- tcnt++;
- if(tcnt==20)
- tcnt=0;
- sec++;
- write=1;
- if(sec==60)
- sec=0;
