名稱:AD9854并口驅動
編寫:
日期:2014.3
修改:無
內容:
#include "AD9854_Parallel.h"
//uchar Freq1Word[6] = {0x01, 0x00, 0x00, 0x00, 0x00, 0x00};
void Init_9854(void) //INIT 9854
{// uint i;
WRB = 0;
UDCLK = 0;
// FSK_D = 0;
RESET = 1;
RESET = 0;
//1.先寫控制字
//Bit5-Bit7為任意;Bit4為比較器PD;Bit3保留.一般為低;Bit2為QDAC的PD(Power-down);Bit1為DAC的PD;Bit0為DIG PD
Write_9854(0x1d,0x00);//10
//Bit7為任意;Bit6為PLL range;Bit5為旁路PLL;bit4-bit0為倍頻數////30晶振*10=300MHz系統(tǒng)
Write_9854(0x1e,0x4a);
//bit7為清零ACC1;bit6為清零ACC2(一般必須為低);bit5為三角掃頻;bit4為外用QDAC;bit3-bit1為模式選擇;bit0為使用內/外更新時鐘
Write_9854(0x1f,0x00);
//Bit7為任意;bit6為旁路反正弦;bit5為OSK使能(默認為1,單頻模式下無輸出);bit4為OSK INT;bit3-2為任意;bit1為設置串行模式下低位先傳;bit0為設置串行模式下SDO可用
Write_9854(0x20,0x60);//0x20,0x00
//2.寫頻率
Write_frequence(Frequence);
//3.寫幅度
Write_Amplitude(0,Amplitude[0]);
Write_Amplitude(1,Amplitude[1]);
// UDCLK = 1;
// UDCLK = 0;
void Write_9854(unsigned char address,unsigned char DATA)
WRB = 1;
ADDR = address;
PDATA = DATA;
WRB = 0;
//==============更新頻率====================================
void Write_frequence(unsigned long x)
WRB = 0;
UDCLK = 0;
Write_9854(0x08,0);
Write_9854(0x09,0);
x *= (429.4967296/Ref_Frequence); // 控制字 = 頻率(HZ) 2^48 /(2^16)/(300*10^6)
Write_9854(0x07,(unsigned char)x);
Write_9854(0x06,(unsigned char)(x>>8));
Write_9854(0x05,(unsigned char)(x>>16));
Write_9854(0x04,(unsigned char)(x>>24));
UDCLK = 1;
UDCLK = 0;
//==============更新幅度====================================
void Write_Amplitude(bit Channel,unsigned int Ampli)
WRB = 0;
UDCLK = 0;
if(Channel)
{ Write_9854(0x23,(Ampli>>8));
Write_9854(0x24,Ampli);
{ Write_9854(0x21,(Ampli>>8));
Write_9854(0x22,Ampli);
UDCLK = 1;
UDCLK = 0;
//函數名稱:void AD9854_SetSine(ulong Freq,uint Shape)
//函數功能:AD9854正弦波產生程序
//入口參數:Freq 頻率設置,取值范圍0—(1/2)*SYSCLK
// Shape 幅度設置,為12Bit,取值范圍為(0—4095),取值越大,幅度越大
//出口參數:無
uchar count;
uchar Adress;
Adress=0x04; //選擇頻率控制字地址的處值
Freq_convert(Freq); //頻率轉換
for(count=6;count>0;) //寫入6字節(jié)的頻率控制字
AD9854_WR_Byte(Adress++,FreqWord[--count]);
AD9854_WR_Byte(0x21,Shape>>8); //設置I通道幅度
AD9854_WR_Byte(0x22,(uchar)(Shape&0xff));
AD9854_WR_Byte(0x23,Shape>>8); //設置Q通道幅度
AD9854_WR_Byte(0x24,(uchar)(Shape&0xff));
AD9854_UDCLK=1; //更新AD9854輸出
AD9854_UDCLK=0;
本文轉自:http://www.xiaovdiy.cn/?post=99
