查看: 5525|回復: 2
LPC11XX驅動1602程序_12MHz
ID:73735 發表于 2015-2-18 23:08 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
LCD.c文件:
#include "LPC11XX.h"
#include "gpio.h"
#include "main.h"
#include "Delay.h"
#include "LCD.h"
/*-----------設置D0-D7為輸出口-------------*/
void Set_GPIO_Output(void)
        LPC_GPIO2->DIR |= (0x1<<0);              //設置D0-D7為輸出
        LPC_GPIO2->DIR |= (0x1<<1);
        LPC_GPIO2->DIR |= (0x1<<2);
        LPC_GPIO2->DIR |= (0x1<<3);
        LPC_GPIO2->DIR |= (0x1<<4);
        LPC_GPIO2->DIR |= (0x1<<5);
        LPC_GPIO2->DIR |= (0x1<<6);
        LPC_GPIO2->DIR |= (0x1<<7);
/*-----------設置D0-D7為輸入口-------------*/
void Set_GPIO_Input(void)
        LPC_GPIO2->DIR        &= ~(0x1<<0);            //設置D0-D7為輸入
        LPC_GPIO2->DIR        &= ~(0x1<<1);
        LPC_GPIO2->DIR        &= ~(0x1<<2);
        LPC_GPIO2->DIR        &= ~(0x1<<3);
        LPC_GPIO2->DIR        &= ~(0x1<<4);
        LPC_GPIO2->DIR        &= ~(0x1<<5);
        LPC_GPIO2->DIR        &= ~(0x1<<6);
        LPC_GPIO2->DIR        &= ~(0x1<<7);
/*-----------LCD端口初始化-------------*/
void LCD_GPIO_Init(void)
        //P2口可以用這種方式設置為GPIO,這種方式較合理正式。
        LPC_IOCON->PIO2_0 &= (~0x07);            //設置P2.0~P2.10為GPIO
        LPC_IOCON->PIO2_1 &= (~0x07);
        LPC_IOCON->PIO2_2 &= (~0x07);
        LPC_IOCON->PIO2_3 &= (~0x07);
        LPC_IOCON->PIO2_4 &= (~0x07);
        LPC_IOCON->PIO2_5 &= (~0x07);
        LPC_IOCON->PIO2_6 &= (~0x07);
        LPC_IOCON->PIO2_7 &= (~0x07);
        LPC_IOCON->PIO2_8 &= (~0x07);
        LPC_IOCON->PIO2_9 &= (~0x07);
        LPC_IOCON->PIO2_10 &=(~0x07);
        LPC_GPIO2->DIR |= (0x1<<8);              //RS 設為輸出
        LPC_GPIO2->DIR |= (0x1<<9);              //R/W 設為輸出
        LPC_GPIO2->DIR |= (0x1<<10);             //EN 設為輸出
        LPC_GPIO3->DIR |= (0x1<<3);              //BackLighting 液晶屏背光設為輸出
        GPIOSetValue( 3, 3, 1 );                 //BackLighting位寫1,開啟液晶屏背光,寫0關閉液晶屏背光
/*-----------寫數據到D0-D7-------------*/
void Write_Data_Port(unsigned char Data)
        LPC_GPIO2->DATA &= ~(0xff);
  LPC_GPIO2->DATA |=Data;
/*-----------讀D0-D7的數據-------------*/
unsigned char Read_Data_Port(void)
        //unsigned char In_Data=0;
        //In_Data=LPC_GPIO2->DATA;
        //return In_Data;
        return(LPC_GPIO2->DATA);
* 函 數 名: uchar Chk_LCD_busy(void)
* 函數功能: 讀液晶忙通道數據
* 入口參數: 無
* 返    回: 無
unsigned char Chk_LCD_busy(void)
  unsigned char gR_data;
  unsigned char gwait_time=0xff;    //設置忙超時數
        Set_GPIO_Input();                 //接收口設為輸入口
  LCD_RS_Low();                     //表示狀態
  LCD_RW_High();                    //選擇讀
  LCD_EN_High();
  Delay_Us(30);
  gR_data=Read_Data_Port();
        Delay_Us(10);
  while(TESTBIT(gR_data,7))         //表示busy
     --gwait_time;
     if(!gwait_time)
                         LCD_EN_Low();
                         Set_GPIO_Output();           //恢復為輸出口
                         return 0;
   LCD_EN_Low();
   return 1;
* 函 數 名: void Write_LCD_command(uchar gcmd,uchar gvalue)
* 函數功能: 寫指令
* 入口參數: gcmd--指令  gvalue--是否查忙
* 返    回: 無
void Write_LCD_command(unsigned char gcmd,unsigned char gvalue)
   if(gvalue)                       //寫命令時大部分情況下是在LCD空閑模式下寫
     if(Chk_LCD_busy())
       LCD_RS_Low();                //選擇指令
       LCD_RW_Low();                //選擇寫
                         LCD_EN_High();               //使能
                         Write_Data_Port(gcmd);       //賦指令
       Delay_Us(15);
       LCD_EN_Low();
     LCD_RW_Low();                  //選擇寫
                 LCD_EN_High();                 //使能
     Delay_Us(10);
     LCD_EN_Low();
* 函 數 名: void Write_LCD_data(uchar gdata)
* 函數功能: 寫數據
* 入口參數: gdata--數據
* 返    回: 無
/*----------- 寫數據 -------------*/
void Write_LCD_data(unsigned char gdata)
   if(Chk_LCD_busy())            //寫數據必須是在LCD空閑模式下才能寫
      LCD_RS_High();             //選擇數據
      LCD_RW_Low();              //選擇寫
                  LCD_EN_High();             //使能
      Write_Data_Port(gdata);
      Delay_Us(15);
      LCD_EN_Low();
* 函 數 名: void INIT_LCD(void)
* 函數功能: 初始化1602LCD
* 入口參數: 無
* 返    回: 無
/*-----------LCD初始化函數-------------*/
void INIT_LCD(void)
        LCD_GPIO_Init();
  Delay_Ms(15);
  Write_LCD_command(0x38,0);    //設置16X2顯示,5X7點陣,8位數據傳送,不檢測忙信號
  Delay_Ms(5);
  Delay_Ms(5);
        Delay_Us(100);
  Write_LCD_command(0x38,1);    //設置16X2顯示,5X7點陣,8位數據傳送,檢測忙信號
  Write_LCD_command(0x08,1);    //關閉顯示、無光標、檢測忙信號
  Write_LCD_command(0x01,1);    //清屏、光標歸位、AC=0、檢測忙信號
        Delay_Ms(2);
  Write_LCD_command(0x06,1);    //顯示光標右移位置、檢測忙信號
  Write_LCD_command(0x0C,1);    //顯示功能開、無光標、檢測忙信號
* 函 數 名: void Display_LCD_string(uchar gadd_start,uchar gline,uchar glength,uchar *pdata)
* 函數功能: 顯示字符串
* 入口參數: gadd_start-列號,uchar gline-行號,glength-數據長度,pdata-數組元素
* 返    回: 無
/*-----------顯示字符串-------------*/
//                                       列號                  行號                數據長度                   數組元素
void Display_LCD_string(unsigned char gadd_start,unsigned char gline,unsigned char glength,const unsigned char *pdata)
   unsigned char gaddress;
   //uchar *pdat;
   unsigned char gcount=0;
   if(!gline)                               //第0行
   { gaddress=0x80+gadd_start; }            //地址對應
   { gaddress=0xc0+gadd_start; }            //第一行
   for(;gcount<glength;gcount++)
      Write_LCD_command(gaddress,1);        //設定數據地址
      Write_LCD_data(*pdata);               //取設定地址里的數據
      gaddress++;
      pdata++;
* 函 數 名: void DispChar_XY_LCD(uchar x,uchar y,uchar gdata)
* 函數功能: 指定位置顯示字符
* 入口參數: x-起始地址橫坐標,y-起始地址縱坐標,gdata-要顯示的字符
* 返    回: 無
void DispChar_XY_LCD(unsigned char x,unsigned char y,unsigned char gdata)
   if(!y)
   { gaddress=0x80+x; }
   { gaddress=0xc0+x; }
   Write_LCD_data(gdata);
* 函 數 名: void DispNum_XY_LCD(uchar x,uchar y,uchar gdata)
* 函數功能: 指定位置顯示數字
* 入口參數: x-起始地址橫坐標,y-起始地址縱坐標,gdata-要顯示的數字
* 返    回: 無
void DispNum_XY_LCD(unsigned char x,unsigned char y,unsigned char gdata)
   if(!y)
   Write_LCD_data(gdata+0x30);
/*-----------清屏-------------*/
void Clear_Display(void)
  Delay_Ms(5);
LCD.h文件:
#ifndef     __LCD_H__
#define     __LCD_H__
#define   TESTBIT(a,b) ((a)&(1<<(b)))
#define                LCD_RS_Low()                 LPC_GPIO2->DATA &=~(1<<8)          //給P2.8位寫0
#define                LCD_RS_High()                 LPC_GPIO2->DATA |=(1<<8)           //給P2.8位寫1
#define                LCD_RW_Low()                 LPC_GPIO2->DATA &=~(1<<9)          //給P2.9位寫0
#define                LCD_RW_High()                 LPC_GPIO2->DATA |=(1<<9)           //給P2.9位寫1
#define                LCD_EN_Low()     LPC_GPIO2->DATA &=~(1<<10)         //給P2.10位寫0
#define                LCD_EN_High()    LPC_GPIO2->DATA |=(1<<10)          //給P2.10位寫1
void Set_GPIO_Output(void);
void Set_GPIO_Input(void);
void LCD_GPIO_Init(void);
void Write_Data_Port(unsigned char Data);
unsigned char Read_Data_Port(void);
unsigned char Chk_LCD_busy(void);
void Write_LCD_command(unsigned char gcmd,unsigned char gvalue);
void Write_LCD_data(unsigned char gdata);
void INIT_LCD(void);
void Display_LCD_string(unsigned char gadd_start,unsigned char gline,unsigned char glength,const unsigned char *pdata);
void DispChar_XY_LCD(unsigned char x,unsigned char y,unsigned char gdata);
void DispNum_XY_LCD(unsigned char x,unsigned char y,unsigned char gdata);
void Clear_Display(void);
#endif
ID:190499 發表于 2017-4-17 16:30 | 只看該作者
能否把其他頭文件也分享一下
ID:190499 發表于 2017-4-17 17:24 | 只看該作者
把其他頭文件也分享一下吧
