熱電阻PT10 PT100 Cu50 Cu100電阻轉(zhuǎn)溫度程序
*函數(shù)描述:PT10&PT100 Cu50&Cu100 熱阻轉(zhuǎn)溫度
*輸入變量:R 熱阻阻值
type熱電阻類型 0 PT10
1 PT100
2 Cu50
3 Cu100
*返回變量:float T 溫度
float RtoT(float R, uchar type)
uchar R0; // 熱電阻0度時阻值
float T, tmp, min, mid, max;
float x, y, z;
float d = 3.9083/1e3, b = -5.775/1e7, c = -4.183/1e12;
if(type <= 1)
if(type == 0)
R0 = 10; min = 1.852; mid = 10; max = 39.049; // Pt10
R0 = 100; min = 18.52; mid = 100; max = 390.49; // Pt100
if(R>=mid && R<=max)
y = sqrt(d*d - 4*b*(1-R/R0));
T = (y-d) / (2*b); // 得出溫度
else if(R<mid && R>=min)
x = 0; y = -100; z = -201;
tmp = R0*(1 + d*y + b*y*y + c*(y-100)*y*y*y);
while(fabs(tmp-R)>=0.007)
if(R > tmp)
x = x; z = y;
y = (x+y)/2;
x = y; z = z;
y = (y+z)/2;
T = y; // 得出溫度
if(type == 2) // Cu50
R0 = 50;
else // Cu100
R0 = 100;
x = 150; y = 50; z = -50;
tmp = R0*(1 + 4.289/1e3*y - 2.133/1e7*y*y + 1.233/1e9*y*y*y);
if(R > tmp)
x = x; z = y;
y = (x+y)/2;
x = y; z = z;
y = (y+z)/2;
tmp = R0*(1 + 4.28899/1e3*y - 2.133/1e7*y*y + 1.233/1e9*y*y*y);
T = y;
return T;
