源碼:
- #include <reg52.h>
- * 定時(shí)器初值
- #define T0HIGH 0xec
- #define T0LOWW 0x8a
- typedef unsigned char u8;
- typedef unsigned int u16;
- typedef unsigned long u32;
- typedef bit BOOL;
- * 單片機(jī)管腳定義
- sbit KEY_ON_PIN = P2^0;
- sbit KEY_INC_PIN = P2^1;
- sbit KEY_DEC_PIN = P2^2;
- sbit MOTO_LEFT = P3^6;
- sbit MOTO_RIGHT = P3^7;
- * 按鍵定義
- #define KEY_NULL 0xff
- #define KEY_LONG_PERIOD 25
- #define KEY_CONTINUE_PERIOD 20
- #define KEY_DOWN 0x80
- #define KEY_CONTINUE 0x40
- #define KEY_UP 0x20
- #define KEY_STATE_INIT 0
- #define KEY_STATE_WOBBLE 1
- #define KEY_STATE_PRESS 2
- #define KEY_STATE_LONG 3
- #define KEY_STATE_CONTINUE 4
- #define KEY_STATE_RELEASE 5
- #define KEY_ON_VALUE 1
- #define KEY_INC_VALUE 2
- #define KEY_DEC_VALUE 3
- #define KEY_ON (KEY_ON_VALUE | KEY_DOWN)
- #define KEY_INC (KEY_INC_VALUE | KEY_DOWN)
- #define KEY_INC_CON (KEY_INC_VALUE | KEY_CONTINUE)
- #define KEY_DEC (KEY_DEC_VALUE | KEY_DOWN)
- #define KEY_DEC_CON (KEY_DEC_VALUE | KEY_CONTINUE)
- * 常量定義
- #define true 1
- #define false 0
- #define MOTO_ON MOTO_LEFT = false;\
- MOTO_RIGHT = true
- #define MOTO_OFF MOTO_LEFT = true;\
- MOTO_RIGHT = true
- * 全局變量定義
- code u8 DisCode[] = {0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8, 0x80, 0x90, 0xff};
- u8 PWMpercent = 0;
- u8 DisNum[4] = {0x0a, 0x0a, 0x0a, 0x00};
- u8 DisPosition = 0;
- u8 SecCount = 0;
- u8 u10msNum = 0;
- BOOL b10msEvent = false;
- BOOL b100msEvent = false;
- BOOL b1secEvent = false;
- BOOL MotoStart = false;
- BOOL MotoRun = false;
- void Key_Prosess(void);
- void Dynamic_Display(void);
- void Speed_Display(void);
- * 主函數(shù)
- main()
- TMOD = 0x01;
- TH0 = T0HIGH;
- TL0 = T0LOWW;
- TR0 = 1;
- ET0 = 1;
- EA = 1;
- P1 = 0x00;
- while(1)
- if(true == b10msEvent) //10毫秒定時(shí)標(biāo)志
- b10msEvent = false;
- Key_Prosess(); //按鍵掃描
- Dynamic_Display(); //動(dòng)態(tài)顯示
- if(true == MotoStart) //如果電機(jī)啟動(dòng)
- if(true == MotoRun)
- if(--u10msNum == 0) //如果電機(jī)轉(zhuǎn)動(dòng)時(shí)間到,停止電機(jī)
- MotoRun = false;
- MOTO_OFF;
- if(true == b1secEvent) //PWM周期為1秒,1秒鐘時(shí)間到,開始下一個(gè)周期
- b1secEvent = false;
- MotoRun = true;
- MOTO_ON;
- u10msNum = PWMpercent;
- * 清顯示
- void Num_Clear(void)
- u8 i;
- for(i=0; i<3; i++)
- DisNum[ i] = 0x0a;
- DisNum[3] = 0x00;
- * 讀鍵值
- u8 Key_Scan(void)
- if(KEY_ON_PIN == false)
- return KEY_ON_VALUE;
- if(KEY_INC_PIN == false)
- return KEY_INC_VALUE;
- if(KEY_DEC_PIN == false)
- return KEY_DEC_VALUE;
- return KEY_NULL;
- * 按鍵狀態(tài)掃描
- u8 GetKey(void)
- static u8 KeyState = KEY_STATE_INIT;
- static u8 KeyTimeCount = 0;
- static u8 LastKey = KEY_NULL; //保存按鍵釋放時(shí)候的鍵值
- u8 KeyTemp = KEY_NULL ;
- KeyTemp = Key_Scan();
- switch(KeyState)
- case KEY_STATE_INIT: //初始狀態(tài)
- if(KEY_NULL != KeyTemp) //有鍵按下
- KeyState = KEY_STATE_WOBBLE; //進(jìn)入消抖
- break;
- case KEY_STATE_WOBBLE: //消抖
- KeyState = KEY_STATE_PRESS;
- break;
- case KEY_STATE_PRESS:
- LastKey = KeyTemp; //保存鍵值,以便在釋放按鍵狀態(tài)返回鍵值
- KeyTemp |= KEY_DOWN; //按鍵按下
- KeyState = KEY_STATE_LONG;
- else
- KeyState = KEY_STATE_INIT;
- break;
- case KEY_STATE_LONG:
- if(++KeyTimeCount >= KEY_LONG_PERIOD)
- KeyTimeCount = 0;
- KeyState = KEY_STATE_CONTINUE;
- else
- KeyState = KEY_STATE_RELEASE;
- break;
- case KEY_STATE_CONTINUE:
- if(KEY_NULL != (KeyTemp))
- if(++KeyTimeCount >= KEY_CONTINUE_PERIOD)
- KeyTimeCount = 0;
- KeyTemp |= KEY_CONTINUE; //連擊按鍵事件發(fā)生
- else
- break;
- case KEY_STATE_RELEASE:
- LastKey |= KEY_UP; //按鍵釋放
- KeyTemp = LastKey;
- break;
- default:
- break;
- return KeyTemp;
- * 按鍵功能處理
- u8 KeyData;
- KeyData = GetKey();
- switch(KeyData)
- case KEY_ON: //開關(guān)電機(jī)
- MotoStart = false;
- Num_Clear();
- MOTO_OFF;
- MotoRun = false;
- PWMpercent= 0;
- else
- MotoStart = true;
- MOTO_ON;
- MotoStart = true;
- MotoRun = true;
- u10msNum = PWMpercent = 1;
- break;
- case KEY_INC: //單步增加
- case KEY_INC_CON: //連續(xù)增加
- if((PWMpercent < 100) && MotoStart) //PWM從1%~100%
- PWMpercent++;
- break;
- case KEY_DEC: //單步減小
- case KEY_DEC_CON: //連續(xù)減小
- if((PWMpercent > 1) && MotoStart) //PWM從1%~100%
- PWMpercent--;
- break;
- default:
- break;
- Speed_Display();
- * 速度轉(zhuǎn)換成十進(jìn)制數(shù)
- u8 i;
- DisNum[1] = PWMpercent / 100;
- DisNum[2] = PWMpercent % 100 / 10;
- DisNum[3] = PWMpercent % 10;
- for(i=1; i<3; i++)
- if(DisNum[ i] != 0)
- break;
- * 動(dòng)態(tài)顯示速度百分比
- static u8 DisPinOn = 0x01;
- DisPinOn <<= 1;
- if(DisPinOn == 0x10)
- DisPosition = 0;
- DisPinOn = 0x01;
- P0 = 0xff;
- P1 = DisPinOn;
- P0 = DisCode[DisNum[DisPosition++]];
- * 定時(shí)器0中斷
- void timer0(void) interrupt 1
- TH0 = T0HIGH;
- TL0 = T0LOWW;
- b10msEvent = true; //10毫秒中斷
- if(++SecCount == 100)
- SecCount = 0;
- b1secEvent = true; //1秒到時(shí)
復(fù)制代碼 |
