查看: 3118|回復(fù): 5
關(guān)于STM32單片機(jī)ADC模塊的時(shí)鐘配置
ID:1095470 發(fā)表于 2023-10-9 11:03 | 顯示全部樓層 |閱讀模式
大佬們,幫忙看看:STM32f070的芯片,ADC換了專用的14MHz時(shí)鐘源后,它的寄存器在配置時(shí)就寫不了了,這是什么原因呀?
程序如下:
#include "main.h"
uint32_t Buffer_adc[3];
uint32_t ISENA;
uint32_t ISENB;
uint32_t DC_ADC;
int main(void)
        GPIO_InitTypeDef GPIO_InitStructure ;
        ADC_InitTypeDef ADC_InitStructure ;
        DMA_InitTypeDef DMA_InitStructure ;
        NVIC_InitTypeDef NVIC_InitStructure;
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA,ENABLE);
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1,ENABLE);
        ADC_ClockModeConfig(ADC1,ADC_ClockMode_AsynClk);                                        //ADC專用14MHz時(shí)鐘
//        RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE);
        RCC_HSI14Cmd(ENABLE);
        RCC_HSI14ADCRequestCmd(ENABLE);
//        RCC_ADCCLKConfig(RCC_ADCCLK_HSI14);
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN ;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_3|GPIO_Pin_5 ;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
        GPIO_Init(GPIOA,&GPIO_InitStructure);
        NVIC_InitStructure.NVIC_IRQChannel = ADC1_IRQn ;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE ;
        NVIC_InitStructure.NVIC_IRQChannelPriority = 0 ;
        NVIC_Init(&NVIC_InitStructure);
        ADC_DeInit(ADC1);
        ADC_StructInit(&ADC_InitStructure);
        ADC_InitStructure.ADC_ContinuousConvMode = ENABLE ;
        ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right ;
        ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None  ;
        ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b ;
        ADC_InitStructure.ADC_ScanDirection = ADC_ScanDirection_Upward ;
        ADC_Init(ADC1,&ADC_InitStructure);
        ADC1->CFGR1 |= (1<<13);
//        ADC_ClockModeConfig(ADC1,ADC_ClockMode_SynClkDiv4);
        ADC_ChannelConfig(ADC1,ADC_Channel_1|ADC_Channel_3|ADC_Channel_5,ADC_SampleTime_55_5Cycles);//選擇ADC通道和采樣時(shí)間
        ADC_GetCalibrationFactor(ADC1);//開始校準(zhǔn)
//        ADC_ClockModeConfig(ADC1,ADC_ClockMode_AsynClk);                                        //ADC專用14MHz時(shí)鐘
        ADC_AutoPowerOffCmd(ADC1,DISABLE);        //失能低功耗自關(guān)斷模式
        DMA_DeInit(DMA1_Channel1);
        DMA_InitStructure.DMA_BufferSize = 3 ;
        DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC ;
        DMA_InitStructure.DMA_M2M = DMA_M2M_Disable ;
        DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)Buffer_adc ;
        DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Word ;
        DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable ;
        DMA_InitStructure.DMA_Mode = DMA_Mode_Circular ;
        DMA_InitStructure.DMA_PeripheralBaseAddr = 0x40012440 ;
        DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word ;
        DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable ;
        DMA_InitStructure.DMA_Priority = DMA_Priority_High ;
        DMA_Init(DMA1_Channel1,&DMA_InitStructure) ;
//        ADC_ITConfig(ADC1,ADC_IT_ADRDY,ENABLE);
//        ADC_ITConfig(ADC1,ADC_IT_EOSMP,ENABLE);
//        ADC_ITConfig(ADC1,ADC_IT_EOC,ENABLE);
        ADC_DMARequestModeConfig(ADC1, ADC_DMAMode_Circular);//循環(huán)轉(zhuǎn)換模式
        ADC_DMACmd(ADC1,ENABLE);//使能ADC的DMA請(qǐng)求
        ADC_Cmd(ADC1,ENABLE);//打開ADC
        while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_ADRDY)); //ADC轉(zhuǎn)換準(zhǔn)備完成
        ADC_StartOfConversion(ADC1);//軟件控制ADC開始轉(zhuǎn)換
        DMA_Cmd(DMA1_Channel1, ENABLE);//打開DMA通道
                while((DMA_GetFlagStatus(DMA1_FLAG_TC1)) == RESET ); //當(dāng)產(chǎn)生傳輸完成的事件時(shí)
                ISENA = Buffer_adc[0]*3300/0xfff ;
                ISENB = Buffer_adc[1]*3300/0xfff ;
                DC_ADC = Buffer_adc[2]*3300/0xfff ;
                DMA_ClearFlag(DMA1_FLAG_TC1);        //清除DMA通道1傳輸完成標(biāo)志TCIFx,由硬件設(shè)置,軟件清零
時(shí)鐘樹
時(shí)鐘樹
ADC寄存器
ADC寄存器
RCC寄存器
RCC寄存器
時(shí)鐘控制寄存器RCC_CR2
時(shí)鐘控制寄存器RCC_CR2
ID:1095470 發(fā)表于 2023-10-9 11:38 | 顯示全部樓層
本來用的是HSE外部高速時(shí)鐘源,程序可以實(shí)現(xiàn)AD功能,換成HSI14時(shí)鐘源后就這樣了。
修改的部分程序如下:
屏蔽了 RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE);//使能APB2時(shí)鐘
          上面這一句。
添加了ADC_ClockModeConfig(ADC1,ADC_ClockMode_AsynClk); //選擇ADC的時(shí)鐘來源于HSI14
         RCC_HSI14Cmd(ENABLE);//使能HSI14時(shí)鐘源
         RCC_HSI14ADCRequestCmd(ENABLE);//使能來自于ADC的HSI14時(shí)鐘源請(qǐng)求
         ADC_AutoPowerOffCmd(ADC1,DISABLE);//失能低功耗自關(guān)斷模式
         以上這四句。
ID:1095470 發(fā)表于 2023-10-9 11:22 | 顯示全部樓層
大佬們快來幫忙解答一下小白的小小問題
ID:891041 發(fā)表于 2023-10-9 14:56 | 顯示全部樓層
txx111 發(fā)表于 2023-10-9 11:38
修改的部分程序如下:
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE); 這句不能屏蔽 屏蔽就無法配置寄存器了。
這一句是開ADC時(shí)鐘  和設(shè)置ADC時(shí)鐘源是不是異步無關(guān)。想配置ADC寄存器必須要開的。
ID:1095470 發(fā)表于 2023-10-9 18:13 | 顯示全部樓層
abob 發(fā)表于 2023-10-9 14:56
這一句 ...
原來是這樣,終于解決了,太感謝你了,大佬!
ID:1093723 發(fā)表于 2023-10-11 20:34 | 顯示全部樓層
TM32的ADC模塊應(yīng)用與配置方法詳解 “ADC時(shí)鐘配置: ADC模塊需要一個(gè)時(shí)鐘源來進(jìn)行工作。通過RCC寄存器配置,選擇適當(dāng)?shù)臅r(shí)鐘源,并設(shè)置ADC的預(yù)分頻系數(shù),以確保ADC工作在適當(dāng)?shù)臅r(shí)鐘頻率下。
