基于FPGA的信號(hào)發(fā)生器
- 三角波
- //clk:時(shí)鐘信號(hào)
- //reset:復(fù)位信號(hào)
- //triangle_out:三角波輸出
- module triangle(clk,reset,triangle_out);
- input clk,reset;
- output[7:0] triangle_out;
- reg[7:0] triangle_out;
- reg[7:0] num; //計(jì)數(shù)器
- reg reg_1; //加減控制器
- always@(posedge clk or posedge rest)
- begin
- if(reset)
- num<=0; //當(dāng)復(fù)位信號(hào)為1時(shí)輸出為0
- else if(reg_1==0)
- begin
- if(num==8’b11111000)
- begin
- num<=255;
- reg_1<=1; //加至最大值,開(kāi)始進(jìn)行減法
- end
- else
- num<=num+8; //進(jìn)行加8運(yùn)算,取出32個(gè)點(diǎn)
- end
- else if(num==8’b00000111)
- begin
- num<=0;
- reg_1<=0; //準(zhǔn)備進(jìn)行加法
- end
- else
- begin
- num<=num-8; //進(jìn)行減8運(yùn)算,需要取出32個(gè)點(diǎn)
- end
- end
- always@(num)
- begin
- triangle_out<=num;//將取出的點(diǎn)輸出,即可實(shí)現(xiàn)三角波
- end
- endmodule
- 正弦波
- //sin_out:正弦波輸出
- Module sin(clk,reset,sin_out);
- Input clk,reset;
- output[7:0]sin_out;
- reg[7:0]sin_out;
- reg[6:0]num;
- always@(posedge clk or posedge reset)
- begin
- if(reset)
- sin_out<=0;
- else if(num==63) //共需要64個(gè)點(diǎn)
- num<=0;
- else
- num<=num+1;
- case(num) //每個(gè)點(diǎn)一一對(duì)應(yīng)的數(shù)據(jù)
- 0:sin_out<=255;
- 1:sin_out<=254;
- 2:sin_out<=252;
- 3:sin_out <=249;
- 4:sin_out <=245;
- 5:sin_out<= 239;
- 6:sin_out <= 23;
- 7:sin_out<= 225;
- 8:sin_out<=217;
- 9:sin_ out <=207;
- 10:sin out<=197;
- 11:sin out<= 186;
- 12:sin out <=174;
- 13:sin_out<=162;
- 14:sin_out<=150;
- 15:sin_out<=137;
- 16:sin_out<=124;
- 17:sin_out<=112;
- 18:sin_out<=99;
- 19:sin_out<=87;
- 20:sin_out<=75;
- 21:sin_out<=64;
- 22:sin_out<=53;
- 23:sin_out<=43;
- 24:sin_out<=34;
- 25:sin_out<=26
- 26:sin_out<=19;
- 27:sin_out<=13;
- 28:sin_out<=8;
- 29:sin_out<=4;
- 30:sin_out<=1;
- 31:sin_out<=0;
- 32:sin_out<=0;
- 33:sin_out<=1;
- 34:sin_out<=4;
- 35:sin_out<=8;
- 36:sin_out<=13;
- 37:sin_out<=19;
- 38:sin_out<=26;
- 39:sin_out<=34;
- 40:sin_out<=43;
- 41:sin_out<=53;
- 42:sin_out<=64;
- 43:sin_out<=75;
- 44:sin_out<=87;
- 45:sin_out<=99;
- 46:sin_out<=112;
- 47:sin_out<=124;
- 48:sin_out<=137;
- 49:sin_out<=150;
- 50:sin_out<=l62;
- 51:sin_out<=174;
- 52:sin_out<=186;
- 53:sin_out<=197;
- 54:sin_out<=207;
- 55:sin_out<=217;
- 56:sin_out<=225;
- 57:sin_out<=233;
- 58:sin_out<=239;
- 59:sin_out<=245;
- 60:sin_out<= 249;
- 61:sin_out <= 252;
- 62:sin_out <= 254;
- 63:sin_out <= 255;
- default:sin_ out<=8 'bx;
- endcase
- end
- endmodule
- //square:方波輸出
- module square( clk,reset,square_out) ;
- input clk,reset;
- output[7:0] square_ out;
- reg[7:0] square_out;
- reg[5:0] num;
- reg reg_2;
- always @( posedge clk or posedge reset)
- begin
- if( reset)
- reg_2<=0; //當(dāng)復(fù)位信號(hào)為1時(shí),輸出為0
- else if(num<31)//分頻
- else
- begin
- num<=0;
- reg 2<=~reg_ 2;
- end
- case(reg_2)
- 1:squae _out<=255;
- 0:square_out <=0;
- endcase
- end
- endmodule
- 控制模式
- //triangle_ctrl:三角波控制信號(hào)
- //sin_ctrl:正弦波控制信號(hào)
- //square_ctrl:方波控制信號(hào)
- // triangle:三角波
- //sin:正弦波
- //square:方波
- //wave_out:輸出波形
- module control( triangle _ctrl ,sin_ ctrl, square_ctrl,triangle,sin, square,wave_out);
- input triangle_ ctrl ,sin _ctrl ,square ctrl;
- input[ 7:0] triangle,sin,square;
- output[ 7:0] wave_out;
- reg[ 7:0] wave_ out;
- reg[2:0]sel;
- reg[9:0] a,b,c,d,e;
- always@( triangle_ctrl or sin_ctrl or square_ctrl or triangle or sin or square)
- begin
- sel={triangle_ctrl,sin_ctrl,sqpuare_ctrl }; //控制信號(hào)
- case(sel)
- 3'b100:wave_out=triangle;
- 3'b010:wave_out=sin;
- 3'b001:wave_out=square;
- 3'b011: //方波和正弦波的線性組合
- begin
- a= triangle + sin;
- wave_out=a[8:1];
- end
- 3'b101: //三角波和方波的線性組合
- begin
- a = triangle + square;
- wave_ out=a[8:1];
- end
- 3 'b110: //三角波和正弦波的線性組合
- begin
- a= square + sin;
- wave_ out=a[8:1];
- end
- 3'b111: //三角波、正弦波和方波的線性組合
- begin
- a= triangle + square;
- b=a + sin;
- c=b[9:2];
- d=a[9:4];
- e=a[9:6];
- a=c +d;
- b=a +e;
- wave_out=b[7:0];
- end
- defalt:wave_ out=8 'bx;
- endcase
- end
- endmodule
- //clk:系統(tǒng)時(shí)鐘信號(hào)
- //p:頻率調(diào)節(jié)信號(hào),p=系統(tǒng)時(shí)鐘頻率/產(chǎn)生頻率/2
- module div_ctrl(clk,p,clk_out,reset)
- input clk,reset;
- input[ 10:0] p ;
- output clk_out;
- reg clk_ out;
- reg temp;
- reg [10:0] count ;
- always@(posedge clk or posedage reset)
- begin
- if( reset)clk_out<=0;//復(fù)位信號(hào)為1時(shí),輸出為0
- else if(temp==0)
- begin
- count<=p-1;
- temp<=1;
- end
- else if(count==1)
- begin
- temp<=0;
- clk_out<=~clk_out;
- end
- else
- begin
- count <= count-1;
- end
- end
- endmodule
- module signal_gennerator(clk,reset,k,triangle,sin,square,wave);
- input clk,reset;
- input[10:0] k;
- input triangle,sin,square;
- output[7:0] wave;
- wire[7:0] triangle_1,sin_1,square_1;
- wire clk_1;
- div_ctrl U1(.clk(clk),.reset(reset),.p(k),.clk_(clk_1));
- control U2(.triangle_ctrl(triangle),.sin_ctrl(sin),.square_ctrl(square),.triangle(triangle_1),
- .sin(sin_1),.square(square_1),.wave_out(wave));
- triangle U3(.clk(clk_1),.reset(reset),.triangle_out(triangle_1));
- sin U4(.clk(clk_1),.reset(reset),.sin_out(sin_1));
- square U5(.clk(clk_1),.reset(reset),.square_out(square_1));
- endmodule
