查看: 2980|回復: 3
單片機數字電壓表
ID:196031 發表于 2017-5-3 15:32 | 顯示全部樓層 |閱讀模式
#include <AT89X51.H>
unsigned char code dispbitcode[]={0xfe,0xfd,0xfb,0xf7, 0xef,0xdf,0xbf,0x7f};
unsigned char code dispcode[]={0x3f,0x06,0x5b,0x4f,0x66, 0x6d,0x7d,0x07,0x7f,0x6f,0x00};
unsigned char dispbuf[8]={10,10,10,10,10,0,0,0};
unsigned char dispcount;
unsigned char getdata;
unsigned int temp;
long int  i;
unsigned int R1;
sbit ST=P3^0;
sbit OE=P3^1;
sbit EOC=P3^2;
sbit CLK=P3^3;
void main(void)
  ST=0;
  OE=0;
  ET0=1;
  ET1=1;
  EA=1;
  TMOD=0x12;
  TH0=216;
  TL0=216;
  TH1=(65536-5000)/256;
  TL1=(65536-5000)%256;
  TR1=1;
  TR0=1;
  ST=1;
  ST=0;
      if(EOC==1)
          OE=1;
          getdata=P0;
          OE=0;
                    i=getdata*1960;
                        dispbuf[5]=i/10000;
                        i=i%10000;
                        dispbuf[6]=i/1000;
                        i=i%1000;
                        dispbuf[7]=i/100;
          ST=1;
          ST=0;
void t0(void) interrupt 1 using 0
  CLK=~CLK;
void t1(void) interrupt 3 using 0
  TH1=(65536-6000)/256;
  TL1=(65536-6000)%256;
  P2=0xff;
  P1=dispcode[dispbuf[dispcount]];
  P2=dispbitcode[dispcount];
  if(dispcount==5)
      P1=P1 | 0x80;
  dispcount++;
  if(dispcount==8)
      dispcount=0;
參與人數 2黑幣 +4 收起 理由
ywwimmortals + 1 很給力!
crt123 + 3
ID:192926 發表于 2017-5-3 16:00 | 顯示全部樓層
你這個是基于什么AD芯片的,然后通過什么輸出顯示的呢???
ID:195456 發表于 2017-5-3 17:24 | 顯示全部樓層
懂了,謝謝
ID:203923 發表于 2017-6-4 16:23 | 顯示全部樓層
有點懂了、謝謝
