要求能實現(xiàn)年、月、日、星期、時、分、秒的顯示; 2.能實現(xiàn)調(diào)時功能; 3.能實現(xiàn)12/24小時制切換; 4.能實現(xiàn)8:00—22:00整點報時功能 錯誤信息Build target 'Target 1' assembling STARTUP.A51...
compiling 3333.c...
3333.C(1): error C251: illegal octal digit
3333.C(1): error C141: syntax error near '0c'
3333.C(1): error C129: missing ';' before 'year'
Target not created
程序如下:
0char year,month,day,week,miao,shi,fen,pshi;
uchar code table[]=" 20 - - ";//定義初始上電時液晶默認顯示狀態(tài)
void delay(uint z) //延時函數(shù)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void zhuanhuan()
if(shi==0)
pshi=12;
if(shi<=12&&shi>=1)
pshi=shi;
if(shi>12)
pshi=shi-12;
void di()//蜂鳴器發(fā)聲函數(shù)
beep=0;
delay(300);
beep=1;
delay(300);
void write_com(uchar com)//液晶寫命令函數(shù)
lcdrs=0;
lcden=0;
P0=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_date(uchar date)//液晶寫數(shù)據(jù)函數(shù)
lcdrs=1;
lcden=0;
P0=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
void _shi() //寫"AM"、"PM"函數(shù)
if(shi>=12)
write_com(0x80+0x40+1);//寫出"PM"
write_date('P');
write_date('M');
write_com(0x80+0x40+1);//寫出"AM"
write_date('A');
write_date('M');
void write_ymd(uchar add1,uchar date1)//寫年月日函數(shù)
uchar shi,ge;
shi=date1/10;//分解一個2位數(shù)的十位和個位
ge=date1%10;
write_com(0x80+add1);//設置顯示位置
write_date(0x30+shi);//送去液晶顯示十位
write_date(0x30+ge); //送去液晶顯示個位
void write_sfm(uchar add,uchar date)//寫時分秒函數(shù)
uchar shi,ge;
shi=date/10;//分解一個2位數(shù)的十位和個位
ge=date%10;
write_com(0x80+0x40+add);//設置顯示位置
void write_week(char week) //寫液晶星期顯示函數(shù)
write_com(0x80+12);
switch(week)
case 1: write_date('M');delay(5);
write_date('O');delay(5);
write_date('N');
break;
case 2: write_date('T');delay(5);
write_date('U');delay(5);
write_date('E');
break;
case 3: write_date('W');delay(5);
write_date('E');delay(5);
write_date('D');
break;
case 4: write_date('T');delay(5);
write_date('H');delay(5);
write_date('U');
break;
case 5: write_date('F');delay(5);
write_date('R');delay(5);
write_date('I');
break;
case 6: write_date('S');delay(5);
write_date('A');delay(5);
write_date('T');
break;
case 7: write_date('S');delay(5);
write_date('N');
break;
void writeym()
day=1;
month++;
if(month==13)
month=1;
year++;
if(year==100)
year=0;
write_ymd(3,year);//年若變化則重新寫入
write_ymd(6,month);//月若變化則重新寫入
void init()//初始化函數(shù)
129行 uchar num;
lcden=0;
year=13;//初始化種變量值
month=6;
day=21;
week=5;
shi=13;
fen=59;
miao=58;
count=0;
s1num=0;
s4num=0;
write_com(0x38);//初始化1602液晶
錯誤行 write_com(0x0c);
write_com(0x06);
write_com(0x01);
write_com(0x80);//設置顯示初始坐標
for(num=0;num<15;num++)//顯示年月日星期
write_date(table[num]);
delay(5);
delay(5);
write_com(0x80+0x40+6);//寫出時間顯示部分的兩個":"
write_date(':');
delay(5);
write_com(0x80+0x40+9);
write_date(':');
delay(5);
write_week(week);
write_ymd(3,year);//分別送去液晶顯示
write_ymd(6,month);
write_ymd(9,day);
write_sfm(10,miao);//分別送去液晶顯示
write_sfm(7,fen);
write_sfm(4,shi);
TMOD=0x01;//設置定時器0工作模式1
TH0=(65536-50000)/256;//定時器裝初值
TL0=(65536-50000)%256;
EA=1; //開總中斷
ET0=1; //開定時器0中斷
TR0=1; //啟動定時器0
void keyscan()//按鍵掃描函數(shù)
if(s1==0)
delay(5);
if(s1==0)//確認功能鍵被按下
s1num++;//功能鍵按下次數(shù)記錄
while(!s1);//釋放確認
if(s1num==1)//第一次被按下時
TR0=0; //關(guān)閉定時器
write_com(0x80+3);//光標定位到年位置
write_com(0x0f); //光標開始閃爍
if(s1num==2)//第二次按下光標閃爍定位到月位置
write_com(0x80+6);
if(s1num==3)//第三次按下光標閃爍定位到日位置
write_com(0x80+9);
if(s1num==4)//第四次按下光標閃爍定位到星期位置
write_com(0x80+12);
if(s1num==7)//第七次被按下時光標定位到秒位置
write_com(0x80+0x40+10);
if(s1num==6)//第六次按下光標閃爍定位到分位置
write_com(0x80+0x40+7);
if(s1num==5)//第五次按下光標閃爍定位到時位置
write_com(0x80+0x40+4);
if(s1num==8)//第七次按下
s1num=0;//記錄按鍵數(shù)清零
write_com(0x0c);//取消光標閃爍
TR0=1; //啟動定時器使時鐘開始走
if(s1num!=0)//只有功能鍵被按下后,增加和減小鍵才有效
if(s2==0)
delay(5);
if(s2==0)//增加鍵確認被按下
while(!s2);//按鍵釋放
if(s1num==1)//若功能鍵第一次按下
year++; //則調(diào)整年加1
if(year==100)//若滿100后將清零
year=0;
write_ymd(3,year);//每調(diào)節(jié)一次送液晶顯示一下
write_com(0x80+3);//顯示位置重新回到調(diào)節(jié)處
if(s1num==2)//若功能鍵第二次按下
month++;//則調(diào)整月加1
if(month==13)//若滿12后將置一
month=1;
write_ymd(6,month);//每調(diào)節(jié)一次送液晶顯示一下
write_com(0x80+6);//顯示位置重新回到調(diào)節(jié)處
251行錯誤 }
if(s1num==3)//若功能鍵第三次按下
day++;//則調(diào)整日加1
if(year%4==0&&month==2)
if(day==30)//若滿29后將置一
day=1;
if(year%4!=0&&month==2)
if(day==29)//若滿28后將置一
day=1;
if(month!=2&&month!=4&&month!=6&&month!=9&&month!=11)
if(day==32)//若滿31后將置一
day=1;
if(month==4||month==6||month==9||month==11)
if(day==31)//若滿30后將置一
day=1;
write_ymd(9,day);;//每調(diào)節(jié)一次送液晶顯示一下
write_com(0x80+9);//顯示位置重新回到調(diào)節(jié)處
if(s1num==4)//若功能鍵第四次按下
week++;//則調(diào)整星期加1
if(week==8)//若滿8后將置一
week=1;
write_week(week);//每調(diào)節(jié)一次送液晶顯示一下
write_com(0x80+12);//顯示位置重新回到調(diào)節(jié)處
if(s1num==7)//若功能鍵第七次按下
miao++; //則調(diào)整秒加1
if(miao==60)//若滿60后將清零
miao=0;
write_sfm(10,miao);//每調(diào)節(jié)一次送液晶顯示一下
write_com(0x80+0x40+10);//顯示位置重新回到調(diào)節(jié)處
if(s1num==6)//若功能鍵第二次按下
fen++;//則調(diào)整分鐘加1
if(fen==60)//若滿60后將清零
fen=0;
write_sfm(7,fen);//每調(diào)節(jié)一次送液晶顯示一下
write_com(0x80+0x40+7);//顯示位置重新回到調(diào)節(jié)處
if(s1num==5)//若功能鍵第五次按下
shi++;
if(shi==24)//若滿24后將清零
shi=0;
if(s4num==0)
write_sfm(4,shi);;//每調(diào)節(jié)一次送液晶顯示一下
write_com(0x80+0x40+4);//顯示位置重新回到調(diào)節(jié)處
if(s4num==1)
zhuanhuan();
_shi();
write_sfm(4,pshi);;//每調(diào)節(jié)一次送液晶顯示一下
if(s3==0)
delay(5);
if(s3==0)//確認減小鍵被按下
while(!s3);//按鍵釋放
year--;//則調(diào)整秒減1
if(year==-1)//若減到負數(shù)則將其重新設置為99
year=99;
month--;//則調(diào)整分鐘減1
if(month==0)//若減到負數(shù)則將其重新設置為59
month=12;
if(s1num==3)//若功能鍵第二次按下
day--;//則調(diào)整日加1
if(day==0)//若滿29后將置一
day=29;
if(day==0)//若滿28后將置一
day=28;
if(day==0)//若滿31后將置一
day=31;
if(day==0)//若滿30后將置一
day=30;
if(s1num==4)//若功能鍵第二次按下
week--;//則調(diào)整小時減1
if(week==0)//若減到負數(shù)則將其重新設置為23
week=7;
if(s1num==7)//若功能鍵第一次按下
miao--;//則調(diào)整秒減1
if(miao==-1)//若減到負數(shù)則將其重新設置為59
miao=59;
fen--;//則調(diào)整分鐘減1
if(fen==-1)//若減到負數(shù)則將其重新設置為59
fen=59;
if(s1num==5)//若功能鍵第二次按下
shi--;
if(shi==-1)//若滿24后將清零
shi=23;
if(s4num==0)
if(s4num==1)
zhuanhuan();
_shi();
if(s1num==0)
if(s4==0)
delay(5);
if(s4==0)//確認功能鍵被按下
s4num++;//功能鍵按下次數(shù)記錄
while(!s4);//釋放確認
if(s4num==1)//第一次被按下時
zhuanhuan();
_shi();
write_sfm(4,pshi);
if(s4num==2)//第二次按下
s4num=0;//記錄按鍵數(shù)清零
write_date(' ');
write_date(' ');
write_sfm(4,shi);
void main()//主函數(shù)
init();//首先初始化各數(shù)據(jù)
while(1)//進入主程序大循環(huán)
keyscan();//不停的檢測按鍵是否被按下
if(s1num!=0)
led=0;
led=miao%2;
if((shi>7&&shi<23)&&(fen==0)&&(miao==0))
di();
void timer0() interrupt 1//定時器0中斷服務程序
TH0=(65536-50000)/256;//再次裝定時器初值
count++; //中斷次數(shù)累加
if(count==20) //20次50毫秒為1秒
count=0;
miao++;
if(miao==60)//秒加到60則進位分鐘
miao=0;//同時秒數(shù)清零
fen++;
if(fen==60)//分鐘加到60則進位小時
fen=0;//同時分鐘數(shù)清零
shi++;
if(shi==24)//小時加到24則小時清零
shi=0;
week++;
if(week==8)
week=1;
write_week(week);//星期若變化則重新寫入
day++;
if(year%4==0&&month==2)//判斷是否為閏年的2月
if(day==30)
writeym();
write_ymd(9,day);//日若變化則重新寫入
if(year%4!=0&&month==2)//判斷是否為平年的2月
if(day==29)
writeym();
if(day==32)
writeym();
if(day==31)
writeym();
if(s4num==1)
zhuanhuan();
_shi();
write_sfm(4,pshi);//12小時制小時若變化則重新寫入
else write_sfm(4,shi);//24小時制小時若變化則重新寫入
write_sfm(7,fen);//分鐘若變化則重新寫入
write_sfm(10,miao);//秒若變化則重新寫入
