定時器T0被四次調(diào)用,控制led燈
2017-4-14 20:42 上傳
- #include<reg52.h> //頭文件
- #define MY_TIMER_MAX (4) //最多四個定時器
- #define NULL (0)
- typedef void (*pFun)(void); //callback 函數(shù)指針類型
- typedef struct myTimer
- char on; //開關(guān)
- char is_period; //是否周期循環(huán)
- unsigned short int time_out; //定時時間,單位ms
- unsigned short int count; //定時計數(shù)用
- MY_TIMER;
- pFun callback[MY_TIMER_MAX] = {NULL}; //定時器回調(diào)函數(shù)數(shù)組
- MY_TIMER myTimerList[MY_TIMER_MAX] = {0}; //定時器結(jié)構(gòu)數(shù)組
- int gMyTimerMessage[MY_TIMER_MAX] = {0}; //定時器消息數(shù)組
- sbit LED1=P1^0;
- sbit LED2=P1^1;
- sbit LED3=P1^2;
- sbit LED4=P1^3;
- #define ALL_ON {LED1=0;LED2=0;LED3=0;LED4=0;} //燈全開
- //創(chuàng)建定時器,簡化版本。
- int CreatTimer(int index,unsigned short int time_out,char is_period,pFun callbackFun)
- if(index >= MY_TIMER_MAX) return -1;
- myTimerList[index].on = 1;
- myTimerList[index].is_period = is_period;
- myTimerList[index].time_out = time_out;
- myTimerList[index].count = 0;
- callback[index] = callbackFun;
- return index;
- //四個LED控制函數(shù),on初始是0,第一次調(diào)用on變?yōu)?,是關(guān)燈。
- void led_1_ctrl(void)
- static char on = 0;
- on = !on;
- LED1 = on;
- void led_2_ctrl(void)
- on = !on;
- LED2 = on;
- void led_3_ctrl(void)
- on = !on;
- LED3 = on;
- void led_4_ctrl(void)
- on = !on;
- LED4 = on;
- void Init_Timer0(void) //初始化定時器0
- TMOD=0x01; //定時器0,使用模式1,16位定時器
- TH0=(65536-1000)/256; //給定初值
- TL0=(65536-1000)%256;
- EA=1; //打開總中斷
- ET0=1; //打開定時器中斷
- TR0=1; //開定時器
- void main() //主函數(shù)
- unsigned int i;
- ALL_ON;
- CreatTimer(0,250,1,led_1_ctrl);
- CreatTimer(1,500,1,led_2_ctrl);
- CreatTimer(2,1000,1,led_3_ctrl);
- CreatTimer(3,2000,1,led_4_ctrl);
- Init_Timer0();//初始化定時器0
- while(1)
- for(i = 0; i<MY_TIMER_MAX; ++i)
- if(gMyTimerMessage[i]) //定時器消息來到,啟動。
- gMyTimerMessage[i] = 0; //消息清除
- if(callback[i] != NULL)
- (*callback[i])(); //調(diào)用回調(diào)函數(shù)
- //定時器中斷函數(shù),1ms 定時。
- void Timer0_isr(void) interrupt 1
- unsigned int i = 0;
- TH0=(65536-1000)/256;//重新賦值 1ms
- EA = 0;
- if(myTimerList[i].on)
- ++(myTimerList[i].count); //計數(shù)
- if(myTimerList[i].count >= myTimerList[i].time_out) //定時到
- gMyTimerMessage[i] = 1; //發(fā)消息
- if(myTimerList[i].is_period) //是否周期循環(huán)
- myTimerList[i].count = 0; //計數(shù)重置
下載:
四個led燈.zip
(20.83 KB, 下載次數(shù): 14)
2017-4-14 11:19 上傳
定時器 下載積分: 黑幣 -5
