查看: 2683|回復: 0
六路搶答器完整的單片機源程序
ID:189450 發表于 2017-4-14 10:33 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
完整的源程序:
#include<reg51.h>
#include<intrins.h>
sbit K1=P1^0;
sbit K2=P1^1;
sbit K3=P1^2;
sbit K4=P1^3;
sbit K5=P1^4;
sbit K6=P1^5;
sbit D6=P2^5;
sbit D5=P2^4;
sbit D4=P2^3;
sbit D3=P2^2;
sbit D2=P2^1;
sbit D1=P2^0;
sbit speak=P2^7; //        蜂鳴器引腳定義
unsigned int table_seg[16]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82};
uchar a;
void delay_1ms(unsigned int ms);
void key();
void display();
void main(void)
unsigned char key_value=0;
uint i=5;
P0=0xff;
delay_1ms(500);
do
        P0=table_seg[i--];
        delay_1ms(1000);
}while(i>0);
speak=0;
delay_1ms(300);
speak=1;
                  key();
                  display();
                unsigned char ns;
                while( ms -- )
                for(ns = 0;ns < 116;ns ++);
void display()
    P0=table_seg[a];
    delay_1ms(5);
void key()
   if(K1==0)
      delay_1ms(10);
      if(K1==0)
              D1=0;
                  a=1;
                  P0=table_seg[a];
                  speak=0;
                  while(!K1);
                  while(1);
    if(K2==0)
       delay_1ms(10);
          if(K2==0)
              D2=0;
                  a=2;
                  P0=table_seg[a];
                  speak=0;
                  while(!K2);
                  while(1);
     if(K3==0)
            delay_1ms(10);
          if(K3==0)
                          D3=0;
                         a=3;
                          P0=table_seg[a];
                          speak=0;
                          while(!K3);
                          while(1);
              if(K4==0)
                  delay_1ms(10);
                  if(K4==0)
                          D4=0;
                          a=4;
                          P0=table_seg[a];
                         speak=0;
                          while(!K4);
                          while(1);
        if(K5==0)
                  delay_1ms(10);
                  if(K5==0)
                          D5=0;
                          a=5;
                          P0=table_seg[a];
                          speak=0;
                          while(!K5);
                          while(1);
   if(K6==0)
                  delay_1ms(10);
                  if(K6==0)
  D6=0;
                          a=6;
                          P0=table_seg[a];
                          speak=0;
                          while(!K6);
                          while(1);
