基于51單片機定時器的1602液晶顯示器時鐘顯示(帶年月日)。
下載:
基于51單片機定時器的1602液晶顯示器時鐘顯示(帶年月日).doc
(74 KB, 下載次數: 117)
2017-3-28 16:13 上傳
下載積分: 黑幣 -5
- #include<reg52.h>
- #define uchar unsigned char
- #define uint unsigned int
- uchar a,count,S1num,xqnum;
- char yue,ri,shi,fen,miao;
- int nian;
- sbit lcdrs=P2^5;
- sbit lcdrw=P2^4;
- sbit lcden=P2^3;
- sbit S1=P3^0; //定義鍵——進入設置
- sbit S2=P3^1; //定義鍵——增大
- sbit S3=P3^2; //定義鍵——減小
- sbit S4=P3^3; //定義鍵——退出設置
- uchar code table0[]="2014-08-13 WED";
- uchar code table1[]="00:00:00";
- uchar code xingqi[][3]={"MON","TUE","WED","THU","FRI","SAT","SUN"};
- void delay(uint z)
- uint x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- 1602液晶顯示器模塊
- sbit lcdrs=P2^5;
- sbit lcdrw=P2^4;
- sbit lcden=P2^3;
- void write_com(uchar com) //液晶寫指令
- lcdrw=0;
- lcdrs=0;
- P0=com;
- delay(5);
- lcden=1;
- delay(5);
- lcden=0;
- void write_data(uchar dat) //液晶寫數據
- lcdrw=0;
- lcdrs=1;
- P0=dat;
- delay(5);
- lcden=1;
- delay(5);
- lcden=0;
- 年月日寫入1602函數
- void write_sfm(uchar add,uchar dat) //寫時分秒函數
- uchar shi,ge;
- shi=dat/10;
- ge=dat%10;
- write_com(0x80+0x40+add);
- write_data(0x30+shi);
- write_data(0x30+ge);
- void write_yr(uchar add,uchar dat) //寫月日函數
- uchar shi,ge;
- shi=dat/10;
- ge=dat%10;
- write_com(0x80+add);
- void write_nian(uchar add,uint dat) //寫年函數
- uint qian,bai,shi,ge;
- qian=dat/1000;
- bai=dat%1000/100;
- shi=dat%100/10;
- ge=dat%10;
- write_data(0x30+qian);
- write_data(0x30+bai);
- 初始化
- void init_lcd() //液晶初始化
- lcden=0;
- nian=2014;
- yue=8;
- ri=13;
- shi=0; //初始shi、fen、miao
- fen=0;
- miao=0;
- write_com(0x38); //設置16x2顯示,5x7點陣,8位數據口
- write_com(0x0c); //設置開顯示,不顯示光標
- write_com(0x06); //寫一個字符后地址指針加1
- write_com(0x01); //顯示清0,數據指針清0
- void init() //初始化函數
- init_lcd(); //液晶初始化
- write_com(0x80); //設置顯示初始坐標
- for(a=0;a<14;a++) //顯示年月日初始值
- write_data(table0[a]);
- delay(5);
- write_com(0x80+0x40); //設置顯示初始坐標
- for(a=0;a<8;a++) //顯示時分秒初始值
- write_data(table1[a]);
- delay(5);
- write_nian(0,nian);
- write_sfm(6,miao); //分別將shi、fen、miao送去液晶顯示
- write_sfm(3,fen);
- write_sfm(0,shi);
- count=0;
- xqnum=0;
- S1num=0; //初始化全局變量count
- TMOD=0x01; //設置定時器0工作模式1
- TH0=(65535-50000)/256; //定時器裝初始值
- TL0=(65535-50000)%256;
- EA=1; //開總中斷
- ET0=1; //開定時器0中斷
- TR0=1; //啟動定時器0
- 獨立鍵盤
- 獨立鍵盤已接地
- void keyscan()
- if(S1==0)
- delay(5); //確認定義鍵被按下
- if(S1==0)
- S1num++; //定義鍵S1按下次數記錄
- while(!S1); //釋放按鍵確認
- if(S1num==1) //S1按下一次時
- TR0=0; //關閉定時器
- write_com(0xc0+7); //光標定位到秒位置
- write_com(0x0f); //光標閃爍
- if(S1num==2) //S1按下兩次時
- write_com(0xc0+4); //光標定位到分位置
- if(S1num==3) //S1按下三次時
- write_com(0xc0+1); //光標定位到時位置
- if(S1num==4) //S1按下四次時
- write_com(0x80+13); //光標定位到星期位置
- if(S1num==5) //S1按下五次時
- write_com(0x80+9); //光標定位到日位置
- if(S1num==6) //S1按下六次時
- write_com(0x80+6); //光標定位到月位置
- if(S1num==7) //S1按下七次時
- write_com(0x80+3); //光標定位到年位置
- if(S1num==8) //S1按下八次時
- S1num=0; //S1記錄按鍵次數清零
- TR0=1; //開啟定時器
- write_com(0x0c); //取消光標閃爍
- if(S1num!=0) //只有定義鍵按下后S2、S3、S4才有效
- if(S2==0)
- delay(5); //防抖
- if(S2==0) //確認按鍵被按下
- while(!S2); //釋放按鍵確認
- miao++; //調整秒加1
- if(miao==60) //滿60清零
- miao=0;
- write_sfm(6,miao); //每調節一次送液晶顯示一次
- write_com(0x80+0x40+6); //顯示位置重新回到調節處
- fen++; //調整分加1
- if(fen==60)
- fen=0;
- write_sfm(3,fen);
- write_com(0x80+0x40+3);
- shi++; //調整時加1
- if(shi==24)
- shi=0;
- write_sfm(0,shi);
- if(S1num==4) //星期加調整
- xqnum++;
- if(xqnum==7)
- xqnum=0;
- write_com(0x80+0x0b);
- for(a=0;a<3;a++)
- write_data(xingqi[xqnum][a]);
- delay(5);
- if(S1num==5) //日加調整
- ri++;
- if(yue==2)
- if(nian%400==0)
- if(ri==30)
- ri=1;
- if(nian%400!=0)
- if(ri==29)
- ri=1;
- else if(yue<=7)
- if(yue%2==0&yue!=2)
- if(ri==31)
- ri=1;
- else if(yue%2!=0&yue!=2)
- if(ri==32)
- ri=1;
- else if(yue>=8)
- if(yue%2==0)
- if(ri==32)
- ri=1;
- else if(yue%2!=0)
- if(ri==31)
- ri=1;
- write_yr(8,ri);
- if(S1num==6) //月加調整
- yue++;
- if(yue==13)
- yue=1;
- write_yr(5,yue);
- if(S1num==7) //年加調整
- nian++;
- if(nian==2019)
- nian=2014;
- if(S3==0)
- delay(5);
- if(S3==0) //確認按鍵被按下
- while(!S3);
- if(S1num==1)
- miao--; //調整秒減1
- if(miao==-1) //減到00后再減重新設置為59
- miao=59;
- if(S1num==2)
- fen--; //調整分減1
- if(fen==-1)
- fen=59;
- write_sfm(3,fen);
- if(S1num==3)
- shi--; //調整時減1
- if(shi==-1)
- shi=23;
- write_sfm(0,shi);
- if(S1num==4)
- xqnum--; //調整星期減一
- if(xqnum==-1)
- xqnum=6;
- for(a=0;a<3;a++)
- delay(5);
- if(S1num==5) //調整日
- ri--;
- if(yue==2)
- if(nian%400==0)
- if(ri==0)
- ri=29;
- if(nian%400!=0)
- if(ri==0)
- ri=28;
- else if(yue<=7)
- if(ri==0)
- ri=30;
- if(ri==0)
- ri=31;
- else if(yue>=8)
- if(yue%2==0)
- if(ri==0)
- ri=31;
- else if(yue%2!=0)
- if(ri==0)
- ri=30;
- write_yr(8,ri);
- if(S1num==6) //調整月
- yue--;
- if(yue==0)
- yue=12;
- write_yr(5,yue);
- if(S1num==7) //調整年
- nian--;
- if(nian==2013)
- nian=2018;
- if(S4==0) //退出設置、開啟中斷
- delay(5);
- if(S4==0)
- S1num=0;
- TR0=1;
- write_com(0x0c);
- 定時器0
- void timer0() interrupt 1 //定時器0中斷服務程序
- TH0=(65535-50000)/256; //重裝定時器初始值
- count++; //中斷次數累加
- if(count==20) //20次50毫秒即一秒
- count=0;
- miao++;
- if(miao==60) //秒加到60時分進位
- miao=0;
- fen++;
- if(fen==60) //分加到60時時進位
- fen=0;
- shi++;
- if(shi==24) //時加到24時清0
- shi=0;
- xqnum++;
- ri++;
- if(yue==2) //如果是二月
- if(nian%400==0) //閏年判斷
- if(ri==30)
- ri=1;
- yue++;
- write_yr(5,yue);
- if(nian%400!=0) //平年判斷
- if(ri==29)
- ri=1;
- yue++;
- write_yr(5,yue);
- else if(yue<=7&yue!=2) //一月到七月
- if(yue%2==0) //偶數月(除二月)
- if(ri==31)
- ri=1;
- yue++;
- else if(yue%2!=0) //奇數月
- if(ri==32)
- ri=1;
- yue++;
- write_yr(5,yue);
- else if(yue>=8) //八月到12月
- if(ri==32)
- ri=1;
- yue++;
- if(yue==13) //如果判斷月份為12月,則加一后重新定義月份為1
- yue=1;
- nian++;
- write_yr(5,yue);
- if(ri==31)
- ri=1;
- yue++;
- write_yr(5,yue);
- write_yr(8,ri);
- if(xqnum==7) //星期寫入
- xqnum=0;
- for(a=0;a<3;a++)
- delay(5);
- write_sfm(0,shi); //重新寫入數據
- write_sfm(3,fen); //重新寫入數據
- write_sfm(6,miao); //重新寫入數據
- 主函數
- void main()
- init();
- while(1)
- keyscan(); //不停的檢測按鍵是否被按下
