1.時分秒的正常顯示
2.可單獨調(diào)整時鐘的分十秒
3.鬧鐘功能
4,鍵功能說明
second--正常顯示和鬧鐘狀態(tài)時調(diào)整秒位
minute--正常顯示和鬧鐘狀態(tài)時調(diào)整分位
hour--正常顯示和鬧鐘狀態(tài)時調(diào)整分位
alarm--開啟和關(guān)閉鬧鐘功能(變量alarm_is_ok,1為open,0為close)
stop-set-open-close
顯示該單片機多功能鬧鐘的仿真原理圖:
部分源碼預(yù)覽:
- #include "Key.h"
- #include "led.h"
- uchar timeSetBuff[8]={'0','0',LED_MODE_COUNT,'0','0',LED_MODE_COUNT,'0','0'};//時鐘數(shù)據(jù)緩沖區(qū)
- uchar alarmSetBuff[8]={'0','0',LED_MODE_ALARM,'0','0',LED_MODE_ALARM,'0','0'};//鬧鐘時間數(shù)據(jù)緩沖區(qū)
- uchar timeDisMod=0x24; //00100100
- uchar secondTemp,minuteTemp,hourTemp;
- uchar secondAlarm,minuteAlarm,hourAlarm;
- uchar timer0Temp;
- uchar alarmKeyCount; //鬧鐘起停鍵計數(shù)
- bit alarm_is_ok; //鬧鐘起停狀態(tài)
- bit time_is_ok; //時間是否到
- bit interface_mod; // 顯示界面模式,0為主時間界面,1為設(shè)置界面
- * 函數(shù)名稱:定時器0
- * 功 能:定時器0初始化
- * 入口參數(shù):無
- * 出口參數(shù):無
- void initTimer0(void) //定時10ms
- TMOD |= 0x01; //GATE=0,TR=1運行;C/T=1,counter,0,timer;01十六進制
- TH0 = 0xdc;
- TL0 = 0x00;
- TR0 = 1; //timer0 控制位,為1時啟動timer0
- ET0 = 1; //timer0 中斷使能
- * 函數(shù)名稱:時鐘比較
- * 功 能:比較時鐘和鬧鐘的時間緩沖區(qū),只比較時和分
- * 入口參數(shù):無
- * 出口參數(shù):無
- void timeCompare(void)
- if((minuteTemp == minuteAlarm) && (hourTemp == hourAlarm))
- time_is_ok = 1;
- alarm_is_ok = 0;
- interface_mod = 1;
- * 函數(shù)名稱:主函數(shù)
- * 功 能:調(diào)用并執(zhí)行各個子函數(shù)
- * 入口參數(shù):無
- * 出口參數(shù):無
- void main()
- uchar keyRead;
- init_led();
- init_key();
- initTimer0();
- timer0Temp = 0x00;
- secondTemp = 0x00;
- minuteTemp = 0x00;
- hourTemp = 0x00;
- secondAlarm = 0x00;
- minuteAlarm = 0x00;
- hourAlarm = 0x00;
- alarmKeyCount = 0x02;
- alarm_is_ok = 0; //默認(rèn)狀態(tài)停止
- time_is_ok = 0; //默認(rèn)時間未到
- interface_mod = 0;
- sei();
- while(1)
- if(interface_mod == 1)
- ledSweepDisplay(alarmSetBuff,timeDisMod);
- else
- ledSweepDisplay(timeSetBuff,timeDisMod);
- if(alarm_is_ok == 1)
- timeCompare();
- keyRead = get_key_value();
- if(keyRead == KEY_ALARM)
- if(alarm_is_ok == 1 || time_is_ok == 1)
- alarm_is_ok = 0;
- time_is_ok = 0;
- alarmKeyCount = 0x00;
- else
- if(alarmKeyCount < 0x02)
- alarmKeyCount++;
- else
- if(alarmKeyCount == 0x01)
- if(alarmKeyCount == 0x02)
- alarm_is_ok = 1;
- if(keyRead == KEY_SECOND)
- { if(interface_mod == 1)
- if(secondAlarm < 59)
- secondAlarm++;
- else
- alarmSetBuff[S_L] = secondAlarm % 10 + '0';
- alarmSetBuff[S_H] = secondAlarm / 10 + '0';
- else
- if(secondTemp < 59)
- secondTemp += 1;
- else
- timeSetBuff[S_L] = secondTemp % 10 + '0';
- timeSetBuff[S_H] = secondTemp / 10 + '0';
- if(keyRead == KEY_MINUTE)
- if(minuteAlarm < 59)
- minuteAlarm++;
- else
- minuteAlarm=0x00;
- alarmSetBuff[M_L]=minuteAlarm%10+'0';
- alarmSetBuff[M_H]=minuteAlarm/10+'0';
- else
- if(minuteTemp < 59)
- minuteTemp += 1;
- else
- timeSetBuff[M_L] = minuteTemp % 10 + '0';
- timeSetBuff[M_H] = minuteTemp / 10 + '0';
- if(keyRead == KEY_HOUR)
- if(hourAlarm < 23)
- hourAlarm++;
- else
- hourAlarm = 0x00;
- alarmSetBuff[H_L] = hourAlarm % 10 + '0';
- alarmSetBuff[H_H] = hourAlarm / 10 + '0';
- else
- if(hourTemp < 23)
- hourTemp += 1;
- else
- hourTemp = 0x00;
- timeSetBuff[H_L] = hourTemp%10+'0';
- timeSetBuff[H_H] = hourTemp/10+'0';
- * 函數(shù)名稱:定時器0中斷函數(shù)
- * 功 能:定時器0溢出中斷入口處,定時10ms
- * 入口參數(shù):無
- * 出口參數(shù):無
- void timer0_overflow(void) interrupt 1
- TH0 = 0xdc;
- TL0 = 0x00;
- if(time_is_ok == 1) //報警
- WARN_TRUMPET = ~WARN_TRUMPET;
- if(timer0Temp < 99) //判斷1s是否到
- timer0Temp++;
- else //進中斷100次
- if(secondTemp < 59) //判斷1min是否到
- secondTemp++;
- else
- if(minuteTemp < 59) //判斷1hour是否到
- minuteTemp++;
- else
- if(hourTemp < 23)
- hourTemp++;
- else
- hourTemp = 0x00;
- timeSetBuff[S_L] = secondTemp%10+'0';
- timeSetBuff[S_H] = secondTemp/10+'0';
- timeSetBuff[M_L] = minuteTemp%10+'0';
- timeSetBuff[M_H] = minuteTemp/10+'0';
- sei();
所有資料下載:
電子時鐘系統(tǒng).rar
(41.32 KB, 下載次數(shù): 87)
2017-3-17 22:52 上傳
