查看: 7610|回復: 21
基于51單片機定時器的時鐘,關于程序按鍵不受控制問題?
ID:102056 發表于 2016-11-2 11:15 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最后由 king@ 于 2016-11-2 11:15 編輯
#include <reg52.h>
sbit WEI = P1^6;
sbit DU = P1^7;
sbit BEEP = P1^4;
sbit KEY1 = P3^4;
sbit KEY2 = P3^5;
sbit KEY3 = P3^6;
sbit KEY4 = P3^7;
void xiaoying();
void di();
void keyscan();
// 宏定義
#define uInt32 unsigned  long  int
#define uInt16 unsigned int
uInt16 s=0;m=0;h=0;
uInt32        num=0;
void DelayMS(uInt16 ValMS)
                uInt16 uiVal,ujVal;
                for(uiVal = 0; uiVal < ValMS; uiVal++)
                        for(ujVal = 0; ujVal < 113; ujVal++);
unsigned char Bit_Tab[] =
{0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};                //位選數組
unsigned char  DISP_smg[10] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
// 函數名稱:Timer0Init()
// 函數功能:定時器0初始化設置
// 入口參數:無
// 出口參數:無
void Timer0Init(void)
        TMOD = 0x01;        // 設置定時器1工作在模式1下
        TH0 = 0xDC;
        TL0 = 0x00;                // 賦初始值
        EA = 1;                        // 開總中斷
        ET0 = 1;                // 開定時器1中斷
        TR0 = 1;                // 開定時器0
// 函數名稱:main()
// 函數功能:定時器初始化后進入死循環,等定時器中斷
// 入口參數:無
// 出口參數:無
void main(void)
        Timer0Init();
           void keyscan();
            h= num /3600;
            m=(num%3600)/60;
            s=(num%3600)%60;
                   if(s>59)
                di();
                   s=0;
                m=m+1;
           if(m>59)
                di();
                   m=0;
                h=h+1;
           if(h>23)
           h=0;
          xiaoying();
          WEI = 1;
          P0 = Bit_Tab[5];
          WEI = 0;
          DU = 1;
          P0 = 0x40;
          DelayMS(2);
          xiaoying();
          WEI = 1;
          P0 = Bit_Tab[2];
          WEI = 0;
          DU = 1;
          P0 = 0x40;
          DelayMS(2);
          xiaoying();
          WEI = 1;
          P0 = Bit_Tab[7];
          WEI = 0;
          DU = 1;
          P0 = DISP_smg[s%10];
          DelayMS(2);
          xiaoying();
          WEI = 1;
          P0 = Bit_Tab[6];
          WEI = 0;
          DU = 1;
          P0 = DISP_smg[s/10];
          DelayMS(2);
          xiaoying();
          WEI = 1;
          P0 = Bit_Tab[4];
          WEI = 0;
          DU = 1;
          P0 = DISP_smg[m%10];
          DelayMS(2);
          xiaoying();
          WEI = 1;
          P0 = Bit_Tab[3];
          WEI = 0;
          DU = 1;
          P0 = DISP_smg[m/10];
          DelayMS(2);
          xiaoying();
          WEI = 1;
          P0 = Bit_Tab[1];
          WEI = 0;
          DU = 1;
          P0 = DISP_smg[h%10];
          DelayMS(2);
          xiaoying();
          WEI = 1;
          P0 = Bit_Tab[0];
          WEI = 0;
          DU = 1;
          P0 = DISP_smg[h/10];
          DelayMS(2);
// 函數名稱:Timer0_ISR()
// 函數功能:定時器中斷服務,控制LED閃爍
// 入口參數:無
// 出口參數:無
void Timer0_ISR(void) interrupt 1
        static uInt16 uiCounter = 0;         //只做一次定義
        TH0 = 0xDC;
        TL0 = 0x00;                                                //定時器賦初值
        uiCounter++;                                        //記錄中斷次數
        if(100 == uiCounter)
                uiCounter = 0;
                num=num+1;
void xiaoying()
  DU=1;
  P0=0x00;
  DU=0;
void di()
  BEEP=0;
  DelayMS(100);
  BEEP=1;
void keyscan()
   unsigned char flag;
   if(KEY1==0)
         DelayMS(5);
         if(KEY1==0)
              di();
                  TR0=~TR0;
                  flag=~flag;
                     while(!KEY1);
   if(flag)
         if(KEY2==0)
         DelayMS(5);
         if(KEY2==0)
                  di();
                 s=s+1;
                 if(s==60)
                 s=0;
                  while(!KEY1);
         if(KEY3==0)
         DelayMS(5);
         if(KEY3==0)
                  di();
                 m=m+1;
                 if(m==60)
                 m=0;
                  while(!KEY3);
         if(KEY4==0)
         DelayMS(5);
         if(KEY4==0)
                  di();
                 h=h+1;
                 if(h==24)
                 s=0;
                  while(!KEY4);
不知道為什按鍵不受控,達不到效果,想要按鍵KEY1第一次按數碼暫停,KEY2控制秒加,KEY3控制分加,KEY4控制時加,第二次按KEY1數碼管繼續計時,按鍵這部分程序寫到這里不知道為什么數碼管不受按鍵控制?求大神指導一下。
相關帖子
ID:111634 發表于 2016-11-2 11:57 | 只看該作者
這個問題以前好像拿出來過,有許多人解答了,怎么又拿出來?
ID:102056 發表于 2016-11-2 13:34 | 只看該作者
zl2168 發表于 2016-11-2 11:57
我以前又不會按鍵,應該不會發過用按鍵控制數碼管類似的問題
ID:102056 發表于 2016-11-2 14:31 | 只看該作者
king@ 發表于 2016-11-2 13:34
之前是沒用中斷,現在這個新寫的程序應該是不一樣的。
ID:145717 發表于 2016-11-2 16:09 | 只看該作者
好文章
ID:145717 發表于 2016-11-2 16:10 | 只看該作者
好文章!
ID:145719 發表于 2016-11-2 16:12 | 只看該作者
if(100 == uiCounter)   這個是什么鬼。明顯錯誤啊。
ID:102056 發表于 2016-11-2 17:48 | 只看該作者
1281280722 發表于 2016-11-2 16:12
T0定時器中斷的時間0.01S,累計100次也就是1S數碼管計數一次.
ID:144789 發表于 2016-11-3 14:15 | 只看該作者
程序中間可能有問題
ID:144789 發表于 2016-11-3 14:16 | 只看該作者
程序中間可能有問題
ID:102056 發表于 2016-11-3 16:50 來自觸屏版 | 只看該作者
xiaokaixin 發表于 2016-11-3 14:15
程序中間可能有問題
能不能再具體一點?
ID:111634 發表于 2016-11-3 17:17 | 只看該作者
錯到沒錯,但易被人疑成“鬼”。有人說如果寫成if( uiCounter ==100) ,有可能會誤寫成if( uiCounter =100)。
ID:111634 發表于 2016-11-3 17:21 | 只看該作者
多認真研讀正確的程序,有利于打好基礎,少寫出問題程序。
ID:111634 發表于 2016-11-3 17:26 | 只看該作者
正確的程序很多,看看中斷、鍵盤、顯示,正確的的鏈接方法和思路,可避免出錯,少走彎路。不要老是糾結于錯誤的程序,忙于讓“大神”診斷,浪費時間。
ID:111634 發表于 2016-11-3 18:04 | 只看該作者
學習的過程是研讀、理解、模仿、創新。前3個階段,未扎實基礎,就想步入創新階段,反而欲速而不達。
ID:111634 發表于 2016-11-3 18:07 | 只看該作者
本帖最后由 zl2168 于 2016-11-3 18:29 編輯
給你介紹2本能達到上述要求的書,張志良編著的:
80C51單片機實用教程——基于Keil CProteus》高等教育出版社ISBN 978-7-04-044532-9, 用于學習51單片機原理,便于閱讀理解,便于自學。
80C51單片機仿真設計實例教程——基于Keil CProteus》清華大學出版社ISBN 978-7-302-41682-1,內有常用的單片機應用100案例,用于仿真實驗操作,電路與程序真實可靠可信可行
51單片機仿真設計實例教程仿真文件.rar (4.88 MB, 下載次數: 13)
100案例幾乎能覆蓋你學習單片機的絕大部分問題。
看看100案例目錄吧!肯定有你可參考模仿的電路與程序。
注意!這100案例,每個都可演示觀看,程序句句有注釋,而且簡潔,易于理解,便于自學。
你自己模仿的程序,再keil+proteus仿真,能看到出錯在哪里,不用求“大神”診斷。
目錄.rar (11.45 KB, 下載次數: 15)
ID:111634 發表于 2016-11-3 18:20 | 只看該作者
真誠地希望廣大單片機初學者改變學習方法,少走彎路,增強效果。
ID:140489 發表于 2016-12-15 14:19 | 只看該作者
這是我做時鐘的按鍵程序,你可以參考一下。主要是選擇按鍵的次數要用一個變量來表示,比如knum=0,knum=2。
void keyscan()        //按鍵掃描函數
        if(s3==0)        //選擇按鍵按下
                delay(10);
                if(s3==0)
                        while(!s3)
                                display(shi,fen,miao);        //加上這句,按鍵按下就不會閃
                        knum++;
                        if(knum==1)                                                  //分閃爍
                                 write_1302(0x8e,0x00);                //保護取消
                                 write_1302(write_miao,0x80);
                        if(knum==3)                                                   //時鐘啟動
                                knum=0;
                                write_1302(write_miao,0x00);
                                write_1302(0x8e,0x80);                //保護啟動
        if(knum==1)        //分鐘調節
                if(s1==0)                                                        //加
                        delay(10);
                        if(s1==0)
                                while(!s1)
                                fen++;
                                fen=fen/10*16+fen%10;                //轉為16進制
                                if(fen==0x60)
                                        fen=0x00;
                                write_1302(write_fen,fen);        //寫入1302
                                read_sf();                                        //讀出時間,然后顯示
                if(s2==0)
                        delay(10);
                        if(s2==0)
                                while(!s2)
                                fen--;
                                if(fen==-1)
                                        fen=0x59;
                                read_sf();
        if(knum==2)
                if(s1==0)
                        delay(10);
                        if(s1==0)
                                while(!s1)
                                shi++;
                                shi=shi/10*16+shi%10;                //轉為16進制
                                if(shi==0x24)
                                        shi=0x00;
                                write_1302(write_shi,shi);
                                read_sf();
                if(s2==0)
                        delay(10);
                        if(s2==0)
                                while(!s2)
                                shi--;
                                if(shi==-1)
                                        shi=0x23;
                                read_sf();
ID:155060 發表于 2016-12-15 17:13 | 只看該作者
好文章
ID:135369 發表于 2016-12-15 21:38 來自觸屏版 | 只看該作者
我感覺問題在于flag變量,
uchar flag初值確定就是0?
你試試bit flag=0;
ID:155134 發表于 2016-12-15 21:59 來自觸屏版 | 只看該作者
同求學習
ID:260250 發表于 2018-1-23 10:52 | 只看該作者
學習時鐘、中斷,也遇到此問題。
