只需一步,快速開(kāi)始
查看: 2343|回復(fù): 1
煙霧報(bào)警器程序
ID:143603 發(fā)表于 2016-10-20 15:59 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
#include<I2C.H>
#define SET 20
#define PCF8591 0X90
//PCF8591地址
code unsigned char t[]={
0xc0,0xf9,0xa4,0xb0,0x99,0x92,
0x82,0xf8,0x80,0x90,0x88,0x83,
0xc6,0xa1,0x86,0x8e
sbit D1=P2^0;
sbit D2=P2^1;
sbit D3=P2^2;
sbit D4=P2^3;
sbit BEEP=P1^7
void delayms(unsigned char);
void display(unsigned char);
void adc(void);
bit ISendByte(unsugned char sla,unsignedchar c);
unsigned char IRcvByte(unsigned char sla);
void warning(void);
unsigned char n;
{while(1)
  adc();
  display(n);
  warning();
Start_I2c();
SendByte(sla);
if(ack == 0) return 0;
SendByte(c);
Stop_I2c();
return 1;
unsignedchar c;
Start_I2c();
SendByte(sla+1);
c=RcvByte();
Ack_I2c(1);
Stop_I2c();
return c;
void adc(void)
ISendByte(PCF8591,0x00|2);
n=IRcvByte(PCF8591);
void delayms(unsigned char x){
unsigned char i,j;
for(i = 0;I < x;i++)
for(j = 0;j < 123;j++);
void display(unsigned char x){
unsinged char bai,shi,ge;
bai=x/100;
shi=x%100/10;
ge=x%10;
D3=1;
D1=0;
P0=t[bai];
delayms(5);
P0=0xff;
D1=1;
D2=0;
P0=t[shi];
delayms(5);
P0=0xff;
D1=1;
D3=0;
P0=t[ge];
delayms(5);
P0=0xff;
void warning(void){
if(n> SET) BEEP = 1;
elseBEEP = 0;
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
相關(guān)帖子
ID:378568 發(fā)表于 2018-10-27 18:38 | 顯示全部樓層
那個(gè)I2c.h
