單片機自動換擋電壓表設計的仿真電路原理圖(工程文件清晰版請下載本帖最后的附件)采用adc0808 ad芯片采集電壓
下面是單片機自動換擋電壓表設計部分源程序:
- #include <AT89X52.H>
- #define LEDDATA P0
- #define v20_on {s3=0;s2=0;s1=1;} //宏定義不同量程,不同的開關狀態
- #define v2_on {s3=0;s2=1;s1=0;}
- #define v02_on {s3=1;s2=0;s1=0;}
- unsigned char code dispcode[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00};
- unsigned char dispbuf[8]={0,0,0,0,0,0,0,0};
- unsigned char getdata;
- unsigned long temp;
- unsigned char i,k,l,m;
- unsigned char code mytable0[]=" Welcome to use ";
- unsigned char code mytable1[]="Auto Voltmeter!";
- unsigned char code line0[]=" Voltmeter "; //初始化顯示
- unsigned char code line1[]=" Value: V ";
- //引腳定義
- sbit lcdrs=P2^0;
- sbit lcden=P2^1;
- sbit s3=P3^7;
- sbit s2=P3^6;
- sbit s1=P3^5;
- sbit OE=P3^0;
- sbit EOC=P3^1;
- sbit ST=P3^2;
- void delay(unsigned int z) //延時子函數 z*1ms
- unsigned int x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- void write_com(unsigned char c) //寫命令子函數
- lcdrs=0; //低電平選擇為 寫指令
- lcden=0;
- LEDDATA=c; //把指令寫入P0口
- delay(5); //參考時序圖
- lcden=1; //開使能
- delay(5); //讀取指令
- lcden=0; //關閉使能
- void write_data(unsigned char d) //寫數據子函數
- lcdrs=1; //高電平選擇為 寫數據
- LEDDATA=d; //把數據寫入P0口
- delay(5); //參考時序圖
- lcden=1; //開使能
- delay(5); //讀取數據
- lcden=0; //關閉使能
- void initialize() //LCD初始化函數
- unsigned char num;
- lcden=0;
- write_com(0x38); //設置16x2顯示,5x7點陣顯示,8位數據接口
- write_com(0x0c); //00001DCB,D(開關顯示),C(是否顯示光標),B(光標閃爍,光標不顯示)
- write_com(0x06); //000001N0,N(地址指針+-1)
- write_com(0x01); //清屏指令 每次顯示下一屏內容時,必須清屏
- write_com(0x80+0x10); //第一行,頂格顯示
- for(num=0;num<17;num++)
- write_data(mytable0[num]);
- delay(10);
- write_com(0x80+0x50); //第二行,從第一格開始顯示
- for(num=0;num<15;num++)
- write_data(mytable1[num]);
- delay(10);
- for(num=0;num<16;num++)
- write_com(0x1c); //0001(S/C)(R/L)**; S/C:高電平移動字符,低電平移動光標; R/L:高電平左移,低電平右移
- delay(300);
- delay(1000);
- write_com(0x80);
- for(num=0;num<14;num++)
- write_data(line0[num]);
- delay(10);
- write_com(0x80+0x40);
- write_data(line1[num]);
- delay(10);
- void value(unsigned char add,unsigned char dat)
- write_com(0x80+0x47+add);
- if(l==3&&add==2||l!=3&&add==1)
- write_data(0x2e);
- else
- write_data(0x30+dat);
- main()
- initialize();
- while(1)
- _20v:
- v20_on;
- ST=0;
- ST=1;
- ST=0;
- while(EOC==0);
- OE=1;
- getdata=P1;
- OE=0;
- if(getdata<21)
- goto _2v;
- l=3;
- temp=getdata;
- temp=(temp*1000/51)/2;
- goto disp;
- _2v:
- v2_on;
- ST=0;
- ST=1;
- ST=0;
- while(EOC==0);
- OE=1;
- getdata=P1;
- OE=0;
- if(getdata<21)
- goto _02v;
- else if(getdata>204)
- goto _20v;
- l=2;
- temp=getdata;
- goto disp;
- _02v:
- v02_on;
- ST=0;
- ST=1;
- ST=0;
- while(EOC==0);
- OE=1;
- getdata=P1;
- OE=0;
- if(getdata>204)
- goto _2v;
- l=1;
- temp=getdata;
- m=temp%10;
- if(m>5){temp=temp/10+1;}
- else{temp=temp/10;}
- goto disp;
- disp: for(i=0;i<=3;i++)
- dispbuf[i]=temp%10;
- temp=temp/10;
- if(l==3)
- for(i=4;i>=3;i--)
- dispbuf[i]=dispbuf[i-1];
- else
- dispbuf[4]=dispbuf[3];
- for(k=0;k<5;k++)
- value(k,dispbuf[4-k]);
- if(l==2){goto _2v;}
- else if(l==1){goto _02v;}
單片機自動換擋電壓表設計的全部資料下載:http://www.raoushi.com/bbs/dpj-54940-1.html
