51單片機呼吸燈仿真
51單片機呼吸燈源程序如下
- #include <AT89X52.h>
- #define MAX 0x50 //定時上限定義
- #define MIN 0x00 //定時下限定義
- #define TIMELINE 11 //時間分頻常數
- #define TRUE 1
- #define FALSE 0 //標志位常數
- unsigned int TimeCounter;
- bit ArrowFlg = 0; //方向標志位
- unsigned char upCounter,downCounter; //增加計數器和減少計數器
- sbit LED=P2^0;
- //T0的中斷服務子函數
- void T0Deal() interrupt 1 using 0
- TH0=0xf1;
- TL0=0xf1;
- TR0=1;
- TimeCounter++; //定時計數器增加
- if(TimeCounter == TIMELINE)
- if((upCounter == MAX)&&(downCounter == MIN)) //計數方向標志位切換
- ArrowFlg = FALSE;
- if((upCounter == MIN)&&(downCounter == MAX))
- ArrowFlg= TRUE;
- if(ArrowFlg == 1) //如果是增加計數
- upCounter++;
- downCounter--;
- else //如果是減少計數
- upCounter--;
- downCounter++;
- TimeCounter=0;
- //延時函數
- void Delay(unsigned int i)
- unsigned int j;
- while(i--)
- for(j=0;j<32;j++); //延時
- void main()
- upCounter = MIN;
- downCounter = MAX; //計數器初始化
- TMOD = 0x01; //設置定時器工作方式
- TH0 = 0xF0;
- TL0 = 0xF0 ; //T0初始化值
- EA = 1;
- ET0 = 1; //開中斷
- TR0 = 1; //啟動T0
- while(1)
- LED=0; //輸出變化的PWM波形
- Delay(downCounter);
- LED=1;
- Delay(upCounter);
51單片機呼吸燈電路原理圖
所有資料下載:http://www.raoushi.com/bbs/dpj-54940-1.html
