- #include<reg51.h>
- #define uint unsigned int
- #define uchar unsigned char
- sbit VFD_REM = P1^7;
- sbit VFD_CLK = P1^6;
- sbit VFD_STB = P1^5;
- sbit VFD_DIN = P1^4;
- sbit DS1302_IO=P2^6;
- sbit DS1302_CLK=P2^5;
- sbit DS1302_RST=P2^7;
- sbit k1=P3^4;//功能鍵
- sbit k2=P3^5;//增加鍵
- sbit k3=P3^6;//減小鍵
- sbit k4=P3^7;//查看鍵
- sbit VFD_DIN = P1^7;
- sbit k1=P3^0;//功能鍵
- sbit k2=P3^1;//增加鍵
- sbit k3=P3^2;//減小鍵
- sbit k4=P3^6;//鬧鐘查看鍵
- sbit DS1302_IO=P1^0;
- sbit DS1302_CLK=P3^7;
- sbit DS1302_RST=P1^1;
- bit r=1; //用來顯示秒點
- uchar code vfdmap[]={0xfc, 0x60, 0xda, 0xf2, 0x66, 0xb6, 0xbe, 0xe0, 0xfe, 0xf6, 0x00};//0-9,-,全滅
- uchar code tab[]={0x00,0x10,0x20,0x40,0x80,0x01,0x02,0x04};//用于星期的
- uchar sec,min,hour,year,month,day,week,s1num,flag,shu;
- unsigned char vfdbuf[]={0,0,0,0,0,0,0};
- uchar time[7];
- void vfd_cmd (uchar vfd_cmd0); /* 寫命令*/
- void vfd_wrdata (uchar vfd_wrdata0); /* 寫數(shù)據 */
- void vfd_init (void); /*16312初始化 */
- void vfd_cmd (uchar vfd_cmd0) /* VFD 寫控制命令子程序 */
- unsigned char i;
- VFD_STB=1;
- VFD_CLK=1;
- for ( i=0;i<8;i++ )
- VFD_STB=0;
- VFD_CLK=0;
- VFD_DIN = vfd_cmd0&0x01;
- VFD_CLK=1;
- vfd_cmd0>>=1;
- VFD_STB=1;
- VFD_CLK=1;
- void vfd_wrdata (uchar vfd_wrdata0) /* VFD 寫數(shù)據子程序 */
- unsigned char i;
- for(i=0;i<8;i++)
- VFD_CLK=1;
- VFD_STB=0;
- VFD_CLK=0;
- VFD_DIN=vfd_wrdata0&0x01;
- VFD_CLK=1;
- vfd_wrdata0>>=1;
- VFD_STB=0;
- VFD_CLK=1;
- void vfd_init(void)
- vfd_cmd ( 0x02 ); /* 6柵X16段顯示模式 */
- vfd_cmd ( 0x40 ); /* 顯示正常模式,數(shù)據地址遞增 */
- vfd_wrdata ( 0xc0 ); /* 設置地址從00H開始 */
- void delay_ms(int z)
- int x,y;
- for(x=z;x>0;x--)
- for(y=150;y>0;y--);
- void vfd_time_disp(uchar t_sec,t_min,t_hour,t_week) //顯示
- uchar min_ge,sec_shi,sec_ge,min_shi,hour_ge,hour_shi,week;
- sec_shi=(t_sec>>4)&0x0f;
- sec_ge=t_sec&0x0f;
- min_shi=(t_min>>4)&0x0f;
- min_ge=t_min&0x0f;
- hour_shi=(t_hour>>4)&0x0f;
- hour_ge=t_hour&0x0f;
- week=t_week&0x0f;
- vfdbuf[0]=vfdmap[hour_shi];
- vfdbuf[1]=vfdmap[hour_ge];
- vfdbuf[2]=vfdmap[min_shi];
- vfdbuf[3]=vfdmap[min_ge];
- vfdbuf[4]=vfdmap[sec_shi];
- vfdbuf[5]=vfdmap[sec_ge];
- vfdbuf[6]=tab[week]; //星期
- vfd_init( );
- vfd_wrdata (vfdbuf[1]); //C0 第1柵
- vfd_wrdata (vfdbuf[0]); //C1
- vfd_wrdata (0x08); //C2 第2柵
- vfd_wrdata (0); //C3
- vfd_wrdata (vfdbuf[3]|r); //C4 第3柵
- vfd_wrdata (vfdbuf[2]|0x01); //C5
- vfd_wrdata (vfdbuf[5]); //C6 第4柵
- vfd_wrdata (vfdbuf[4]|0x01); //C7
- vfd_wrdata (0x10); //C8 第5柵
- vfd_wrdata (0x10); //C9
- vfd_wrdata (0); //CA
- vfd_wrdata (vfdbuf[6]);//CB
- VFD_STB=1;
- delay_ms(10);
- vfd_cmd ( 0x8f ); // 顯示開,14/16脈寬
- delay_ms(1);
- void vfd_date_disp(uchar t_day,t_month,t_year,t_week) //顯示
- uchar day_shi,day_ge,month_shi,month_ge,year_ge,year_shi,week;
- day_shi=(t_day>>4)&0x0f;
- day_ge=t_day&0x0f;
- month_shi=(t_month>>4)&0x0f;
- month_ge=t_month&0x0f;
- year_shi=(t_year>>4)&0x0f;
- year_ge=t_year&0x0f;
- week=t_week&0x0f;
- vfdbuf[0]=vfdmap[year_shi];
- vfdbuf[1]=vfdmap[year_ge];
- vfdbuf[2]=vfdmap[month_shi];
- vfdbuf[3]=vfdmap[month_ge];
- vfdbuf[4]=vfdmap[day_shi];
- vfdbuf[5]=vfdmap[day_ge];
- vfd_init( );
- vfd_wrdata (vfdbuf[3]); //C4 第3柵
- vfd_wrdata (vfdbuf[2]); //C5
- vfd_wrdata (vfdbuf[4]); //C7
- VFD_STB=1;
- delay_ms(10);
- delay_ms(1);
- void wdayte_byte(uchar dat) //寫1字節(jié)數(shù)據到1302,低位在前。
- uchar i;
- for(i=0;i<8;i++)
- DS1302_IO=0;
- if(dat&0x01)
- DS1302_IO=1;
- else
- DS1302_IO=0;
- dat=dat>>1;
- DS1302_CLK=0;
- DS1302_CLK=1;
- DS1302_CLK=0;
- uchar read_byte() //從DS1302中讀1字節(jié)數(shù)據,讀出時高位在前。
- uchar i,dat;
- for(i=0;i<8;i++)
- dat=dat>>1;
- if(DS1302_IO)
- dat=dat|0x80;
- DS1302_CLK=1;
- DS1302_CLK=0;
- DS1302_CLK=0;
- return(dat);
- void wdayte_ds1302(uchar add,uchar dat) //向DS1302的add地址中寫入dat數(shù)據
- DS1302_RST=0;
- DS1302_CLK=0;
- DS1302_RST=1;
- wdayte_byte(add);
- wdayte_byte(dat);
- DS1302_CLK=0;
- DS1302_RST=0;
- uchar read_ds1302(uchar add) //從DS1302的add地址中讀出數(shù)據
- uchar time ;
- DS1302_RST=0;
- DS1302_CLK=0;
- DS1302_RST=1;
- wdayte_byte(add);
- time=read_byte();
- DS1302_CLK=0;
- DS1302_RST=0;
- return(time);
- void init_ds1302() //時間初始化函數(shù),不進行初始化DS1302不能正常工作
- wdayte_ds1302(0x8e,0x00);
- wdayte_ds1302(0x8c,time[0]); //寫入年數(shù)據
- wdayte_ds1302(0x88,time[1]); //寫入月數(shù)據
- wdayte_ds1302(0x86,time[2]); //寫入日數(shù)據
- wdayte_ds1302(0x84,time[3]); //寫入時數(shù)據
- wdayte_ds1302(0x82,time[4]); //寫入分數(shù)據
- wdayte_ds1302(0x80,time[5]); //寫入秒數(shù)據
- wdayte_ds1302(0x8a,time[6]); //寫入星期數(shù)據
- wdayte_ds1302(0x90,0xa5); //充電(因用的是法拉電容,所以選一個二極管,2K電阻)
- wdayte_ds1302(0x8e,0x80);
- void read_time() //時間讀取函數(shù)
- sec=read_ds1302(0x81);
- min=read_ds1302(0x83);
- hour=read_ds1302(0x85);
- week=read_ds1302(0x8b);
- day=read_ds1302(0x87);
- month=read_ds1302(0x89);
- year=read_ds1302(0x8d);
- time[0]=year;
- time[1]=month;
- time[2]=day;
- time[3]=hour;
- time[4]=min;
- time[5]=sec;
- time[6]=week;
- void keyscan() //鍵盤檢測函數(shù),用于時間的調節(jié)
- if(k4==0) //K4在沒有調整時間時按下顯示日期,有調時按下先保存退出再顯示日期
- delay_ms(1);
- if(k4==0)
- if(flag==1)
- init_ds1302();
- vfd_date_disp(day,month,year,week);
- delay_ms(2000);
- flag=0;
- s1num=0;
- if(k1==0)
- delay_ms(1);
- if(k1==0)
- while(!k1);
- s1num++;
- flag=1;
- if(s1num==7)
- init_ds1302();
- flag=0;
- s1num=0;
- if(s1num!=0)
- if(k2==0)//加鍵按下
- delay_ms(1);
- if(k2==0)
- switch(s1num)
- case 1: min=((min/16)*10)+(min%16);
- min++;
- if(min==60)
- min=0;
- time[4]=(((min/10)<<4)&0xf0)|((min%10)&0x0f);
- time[5]=0x00;
- break;
- case 2: hour=((hour/16)*10)+(hour%16);
- hour++;
- if(hour==24)
- hour=0;
- time[3]=(((hour/10)<<4)&0xf0)|((hour%10)&0x0f);
- break;
- case 3: day=((day/16)*10)+(day%16);
- day++;
- if(day==32)
- day=1;
- time[2]=(((day/10)<<4)&0xf0)|((day%10)&0x0f);
- break;
- case 4: month=((month/16)*10)+(month%16);
- month++;
- if(month==13)
- month=1;
- time[1]=(((month/10)<<4)&0xf0)|((month%10)&0x0f);
- break;
- case 5: year=((year/16)*10)+(year%16);
- year++;
- if(year>99)
- year=0;
- time[0]=(((year/10)<<4)&0xf0)|((year%10)&0x0f);
- break;
- case 6: week=week%16;
- week++;
- if(week>7)
- week=1;
- time[6]=((week%10)&0x0f);
- break;
- if(k3==0)//減鍵按下
- delay_ms(1);
- if(k3==0)
- switch(s1num)
- min--;
- if(min==-1)
- min=59;
- time[5]=0x00;
- break;
- hour--;
- if(hour==-1)
- hour=23;
- break;
- day--;
- if(day==0)
- day=31;
- break;
- month--;
- if(month==-1)
- month=12;
- break;
- year--;
- if(year==-1)
- year=99;
- break;
- week--;
- if(week==0)
- week=7;
- break;
- void set_time_disp(s1num,flag) //時間調節(jié)顯示函數(shù)
- uchar i;
- if((s1num==1)&&(flag==1))
- read_time();
- for(i=0;i<10;i++)
- vfd_time_disp(sec,min,hour,week);
- for(i=0;i<10;i++)
- vfd_time_disp(sec,0xaa,hour,week);
- if((s1num==2)&&(flag==1))
- read_time();
- for(i=0;i<10;i++)
- for(i=0;i<10;i++)
- vfd_time_disp(sec,min,0xaa,week);
- if((s1num==3)&&(flag==1))
- read_time();
- for(i=0;i<10;i++)
- for(i=0;i<10;i++)
- vfd_date_disp(0xaa,month,year,week);
- if((s1num==4)&&(flag==1))
- read_time();
- for(i=0;i<10;i++)
- for(i=0;i<10;i++)
- vfd_date_disp(day,0xaa,year,week);
- if((s1num==5)&&(flag==1))
- read_time();
- for(i=0;i<10;i++)
- for(i=0;i<10;i++)
- vfd_date_disp(day,month,0xaa,week);
- if((s1num==6)&&(flag==1))
- read_time();
- for(i=0;i<10;i++)
- for(i=0;i<10;i++)
- vfd_date_disp(day,month,year,0x00);
- void main()
- TMOD=0x01; //設定定時器0為方式1
- TH0=(65536-50000)/256; //定時時間設置,時間設為50毫秒
- TL0=(65536-50000)%256;
- EA=1; //開總中斷
- ET0=1; //開定時器0中斷
- TR0=1; //啟動定時器0
- while(1)
- keyscan();
- read_time(); //按鍵檢測
- if(flag==0) //如果沒有按鍵進入這里
- if(flag==1) //如果有按鍵進入這里
- set_time_disp(s1num,flag);
- void T0_time() interrupt 1 //中斷函數(shù)用于秒點的閃爍,周期1秒
- shu++; //用于時間的計數(shù)10次500MS
- if(shu==10)
- shu=0;
- r=~r; //每500毫秒led取反一次
