查看: 37505|回復: 52
STC15F204EA 白光T12控制器
ID:85764 發表于 2015-7-18 14:20 | 顯示全部樓層 |閱讀模式
0-500℃ 0.000-16.748mv
單片機ADC參考電壓等于VCC約5v
代碼中按照放大器269倍增益計算既在500度時4505.212mv
只要放大器滿足此條件可以用別的也可以改變電路
關于布線
建議預留P30,P31用來升級調試
*ADC只能在P1.0-P1.7之間
T12_CTRL不能變更連接
DPY_A-DP盡量安排在一個完整的端口
DPY_DIG最好安排在相連的端口
編碼器本來是想用中斷做驅動 但是204EA版有bug 外部中斷不可用 所以可以修改到其它端口
當然能動最好了:) 有需要變動的我重新編譯固件
正常版本最近一兩天放出
電路可能存在bug 希望高手指正
已知D4虛焊可能燒掉單片機IO或單片機, 這部分可以改3r33輸出8v 然后7805或者串二極管到mcu
8v給lm358供電
設計可控溫度在150-450℃
有自動冷端補償
元件清單
"Part Type","Designator","Footprint","Description"
"0.1-10uf","C9","","Capacitor"
"1K","R19","",""
"1N4004","D5","","Diode"
"1N4148","D3","","Diode"
"1k","R21","",""
"1k","R20","",""
"1k","R22","",""
"4.7k","R26","",""
"4.7k","R25","",""
"4.7k","R27","",""
"4.7k","R23","",""
"4.7k","R24","",""
"5.1V","D4","","Schottky Diode"
"10k %1","R17","",""
"10k","R1","",""
"10k","R2","",""
"10k","R5","",""
"10k","R30","",""
"10k","R3","",""
"10k","R4","",""
"10nf","C6","","Capacitor"
"10nf","C5","","Capacitor"
"10nf","C4","","Capacitor"
"10uf","C1","","Capacitor"
"20k","R29","",""
"20k","R28","",""
"33uf 30V","C7","","Capacitor"
"33uf-100uf 25v","C8","","Capacitor"
"100nf","C3","","Capacitor"
"100nf","C2","","Capacitor"
"470","R12","",""
"470","R11","",""
"470","R9","",""
"470","R10","",""
"470","R15","",""
"470","R16","",""
"470","R13","",""
"470","R14","",""
"470","R8","",""
"470","R6","",""
"470","R7","",""
"936_SWITCH_A","J2","","Connector"
"936_SWITCH_B","J3","","Connector"
"DPY_7-SEG_DP_3","DS1","JM-S03631A-B","共陰3位數碼管 SM420363 0.36英寸數碼管"
"KIS-3R33S","U3","","KIS-3R33S DC-DC 電源模塊"
"LED Red","D2","",""
"LM358","U2","CAN_8","Fast Settling Dual Operational Amplifier"
"MOSFET P 9435","Q1","",""
"NTC-MF52AT 10K 5% B 3950 %1","R18","",""
"ROTARYENCODER","encoder1","","rotary encoder 旋轉編碼開關"
"STC15F200-28PIN_A","U1","",""
"T12_OUT","J4","","Connector"
"TL431","D1","",""
"UART","J1","","Connector"
"s8050","Q2","","NPN Transistor"
二手原裝TS-172升溫到300
打算出套件的朋友建議先測測這個系統的一致性, 我不對任何使用造成的后果負責
編程器設置
OK啦,沒有仔細調整,能正常工作了。
PDF格式電路圖 Protel Schematic.pdf (50.63 KB, 下載次數: 405)
串口調試固件 T12Ctrl調試固件.rar (3.65 KB, 下載次數: 241)
上位機軟件 上位機軟件.rar (293.37 KB, 下載次數: 205)
Protel 99 SE 電路圖 V100.rar (8.15 KB, 下載次數: 225)
我洞洞板做的沒PCB
參與人數 1黑幣 +5 收起 理由
darkly5251 + 5 很給力!
ID:86777 發表于 2015-7-25 10:20 | 顯示全部樓層
恩,,,,挺好
ID:89718 發表于 2015-9-9 15:42 | 顯示全部樓層
有時間試試
ID:89718 發表于 2015-9-9 15:43 | 顯示全部樓層
沒黑比了
ID:61140 發表于 2015-10-13 06:03 | 顯示全部樓層
正在學習這個,過來看一下,做的確實不錯哦.
ID:97811 發表于 2016-1-26 11:28 | 顯示全部樓層
新手學習來了
ID:107219 發表于 2016-3-3 21:57 | 顯示全部樓層
沒黑比了
ID:126709 發表于 2016-6-14 16:57 | 顯示全部樓層
上位機軟件接收協議有嗎
ID:123466 發表于 2016-6-14 22:53 來自觸屏版 | 顯示全部樓層
正式版出了嗎?
ID:130552 發表于 2016-7-15 12:24 來自觸屏版 | 顯示全部樓層
超好的資料
ID:87745 發表于 2016-11-17 09:38 來自觸屏版 | 顯示全部樓層
怎么打不開
ID:87745 發表于 2016-11-17 09:42 | 顯示全部樓層
怎么不是開原的去。
ID:195235 發表于 2017-5-1 13:40 | 顯示全部樓層
想要的好東西
ID:157057 發表于 2017-5-1 18:24 | 顯示全部樓層
感謝分享。我想做個洞洞板的。嘿嘿。
ID:195950 發表于 2017-5-4 14:58 | 顯示全部樓層
樓主啊!你能照顧一下沒有黑幣的我們么?下不起啊真心想要啊
ID:101305 發表于 2017-5-5 08:55 | 顯示全部樓層
不錯辛苦了,這東西做出來會比某寶白菜白光要好么?
ID:198048 發表于 2017-6-5 15:01 | 顯示全部樓層
不錯不錯,正好最近在研究T12
ID:198583 發表于 2017-6-7 15:30 | 顯示全部樓層
感謝分享。
ID:35873 發表于 2017-6-18 02:24 | 顯示全部樓層
難得的好資料  頂
ID:223725 發表于 2017-8-4 13:57 | 顯示全部樓層
MARK一下先
ID:193705 發表于 2017-10-5 09:46 | 顯示全部樓層
過來看一下,做的確實不錯
ID:254251 發表于 2018-1-23 15:44 | 顯示全部樓層
拿來試一下看能不能用
ID:272625 發表于 2018-1-24 22:29 | 顯示全部樓層
好資料,用不上發要支持下
ID:66287 發表于 2018-2-7 14:28 | 顯示全部樓層
樓主能力真棒
ID:318305 發表于 2018-4-28 12:23 | 顯示全部樓層
看著好強大,謝謝了,收藏起來
ID:47634 發表于 2018-6-18 07:47 | 顯示全部樓層
過來學習一下,做的確實很好
ID:351417 發表于 2018-6-18 10:13 | 顯示全部樓層
學習下
ID:75745 發表于 2018-7-25 08:38 來自觸屏版 | 顯示全部樓層
好東西
ID:379423 發表于 2018-7-26 14:59 | 顯示全部樓層
高手,人才啊
ID:403624 發表于 2018-9-28 15:07 | 顯示全部樓層
想下載但是我窮啊
ID:405613 發表于 2018-10-5 17:09 | 顯示全部樓層
這個很有用,試試看,謝謝
ID:399179 發表于 2018-10-5 19:37 來自觸屏版 | 顯示全部樓層
空板子哪有賣的?
ID:77454 發表于 2018-10-15 11:59 | 顯示全部樓層
新手學習來了
ID:411116 發表于 2018-10-17 14:51 | 顯示全部樓層
這個必須頂一個啊
ID:411116 發表于 2018-11-1 13:41 | 顯示全部樓層
支持STC15F204EA 白光T12控制器
ID:15286 發表于 2018-11-9 07:26 來自觸屏版 | 顯示全部樓層
又有一種方案,謝謝啦
ID:146110 發表于 2018-11-10 17:08 | 顯示全部樓層
謝謝啦
ID:481401 發表于 2019-2-27 10:19 | 顯示全部樓層
又有一種方案,謝謝啦
ID:121029 發表于 2019-11-6 15:19 | 顯示全部樓層
用32單片機嘗試下
ID:115923 發表于 2020-2-21 16:38 | 顯示全部樓層
希望可以幫到我哦, 的啊附近撒;閥;分類三伏
