- *Application:xmlrpc_client.c
- *description:A simple string sort XML-RPC client program written in C.
- *author:hemmingway
- *time:26/05/2012 09:18:09
- *compile with: gcc -Wall -c -I/usr/local/include -O2 -o xmlrpc_client.o xmlrpc_client.c
- gcc -lxmlrpc_client -lxmlrpc -lxmlrpc_util -lcurl -o xmlrpc_client xmlrpc_client.o
- #include <stdio.h>
- #include <stdlib.h>
- #include <string.h>
- #include <unistd.h>
- #include <xmlrpc-c/base.h>
- #include <xmlrpc-c/client.h>
- #include <xmlrpc-c/util.h>
- /*xmlrpc_env is defined in xmlrpc-c/util.h*/
- #define NAME "XMLRPC string sort C Client"
- #define VERSION "0.1"
- #define SLEEP(seconds) sleep(seconds);
- #define MAXLEN 1000 /*max length of any input line*/
- #define MAXLINES 500 /*max #lines to be sorted*/
- char *lineptr[MAXLINES];
- void die_if_fault_occurred (xmlrpc_env *env)
- /* Check our error-handling environment for an XML-RPC fault. */
- if (env->fault_occurred) {
- fprintf(stderr, "XML-RPC Fault: %s (%d)\n",
- env->fault_string, env->fault_code);
- exit(1);
- /*getline:read a line into s, return length*/
- int getline(char s[], int lim)
- int c = 0 , i;
- for(i=0; i < lim-1 && (c=getchar()!=EOF) && c!='\n';++i)
- s[i]=c;
- i = 0;
- while(--lim > 0 && (c=getchar()) != EOF && c != '\n')
- s[i++] = c;
- if(c == '\n')
- s[i++] = c;
- s[i] = '\0';
- return i;
- /*readlines: read input lines*/
- int readlines(char *linrptr[], int maxlines)
- int len,nlines;
- char *p,line[MAXLEN];
- nlines = 0;
- while( (len = getline(line,MAXLEN) ) > 1)
- if(nlines >= maxlines || (p = malloc(len*sizeof(char)) )== NULL)
- return -1;
- else
- line[len-1] = '\0'; /*delete new line*/
- strcpy(p,line);
- lineptr[nlines++] = p;
- return nlines;
- void writelines(char *lineptr[], int nlines)
- int i;
- for(i= 0; i < nlines; i++)
- printf("%s\n",lineptr[i]);
- int main(int argc, char **argv)
- xmlrpc_env env;
- xmlrpc_value *myArrayP;
- xmlrpc_value *resultArrayP;
- xmlrpc_value *itemP;
- const char * const serverUrl = "http://localhost:8080/RPC2";
- const char * const methodName = "string.qsort";
- char *line;
- int nlines, i;
- /* Initialize our error-handling environment. */
- xmlrpc_env_init(&env);
- /* Start up our XML-RPC client library. */
- xmlrpc_client_init2(&env, XMLRPC_CLIENT_NO_FLAGS, NAME, VERSION, NULL, 0);
- die_if_fault_occurred(&env);
- printf("Making XMLRPC call to server url '%s' method '%s' "
- "to sort \'char *lineptr[]\' into increasing order...\n", serverUrl, methodName);
- printf("\n\n");
- printf(">>>plz input a line to be sort(press <ENTER><ENTER> to done!):\n");
- while(getline(line,MAXLEN) <= 0 )
- printf(">>>input line is:\n%s\n\n",line);
- if ( (nlines = readlines(lineptr,MAXLINES) ) < 0 ){
- printf("error:...");
- return 1;
- printf(">>>lines:%d\n",nlines);
- printf(">>>input line's is:\n");
- writelines(lineptr, nlines);
- printf("\n\n");
- printf(">>>\n");
- myArrayP = xmlrpc_array_new(&env);
- /*build array*/
- for( i= 0; i < nlines; i++)
- itemP = xmlrpc_string_new(&env, lineptr[i]);
- xmlrpc_array_append_item(&env, myArrayP, itemP);
- xmlrpc_DECREF(itemP);
- /*test...*/
- printf("test input array size:%d\n\n\n",xmlrpc_array_size(&env,myArrayP)); /*Array size*/
- /* Make the remote procedure call */
- resultArrayP = xmlrpc_array_new(&env);
- resultArrayP = xmlrpc_client_call(&env, serverUrl, methodName, "(iA)", (xmlrpc_int32)nlines, myArrayP);
- /* print sort string out. */
- printf(">>>string after sort.\n");
- nlines = xmlrpc_array_size(&env,resultArrayP);
- xmlrpc_array_read_item(&env, resultArrayP, i, &itemP);
- xmlrpc_read_string(&env, itemP, &line );
- printf("%s\n",line);
- /* Dispose of our result value. */
- xmlrpc_DECREF(myArrayP);
- xmlrpc_DECREF(resultArrayP);
- /* Shutdown our XML-RPC client library. */
- xmlrpc_env_clean(&env);
- xmlrpc_client_cleanup();
- return 0;
- *Application:xmlrpc_server.c
- *compile with: gcc -Wall -c -I/usr/local/include -O2 -o xmlrpc_server.o xmlrpc_server.c
- gcc -lxmlrpc_server -lxmlrpc_server_abyss -lxmlrpc -lxmlrpc_util -lcurl -o xmlrpc_server xmlrpc_server.o
- #include <xmlrpc-c/server.h>
- #include <xmlrpc-c/server_abyss.h>
- /*qsort:sort v[left]...v[right] into increasing order*/
- void str_qsort(char *v[], int left, int right)
- int i,last;
- void swap(char *v[], int i, int j);
- if(left >= right) /*do nothing if array contains fewer than two elements*/
- return;
- swap(v,left,(left + right)/2); /*move partition elem*/
- last = left;
- for(i = left + 1; i <= right; i++)
- if( strcmp(v[i],v[left]) < 0 )
- swap(v, ++last,i);
- swap(v,left,last);
- str_qsort(v, left,last-1);
- str_qsort(v, last+1, right);
- return;
- /*swap: interchange v[i] and v[j]*/
- char *temp;
- temp = v[i];
- v[i] = v[j];
- v[j] = temp;
- return ;
- /*compare_rise: for qsort*/
- int compare_rise(const void *a,const void *b)
- return *(char*)a - *(char*)b;
- /*sample_qsort:sort string's*/
- static xmlrpc_value *
- sample_qsort(xmlrpc_env * const envP,
- xmlrpc_value * const paramArrayP,
- void * const usr_data)
- xmlrpc_value *arrayP;
- xmlrpc_value *retval;
- xmlrpc_int32 nlines;
- char *line;
- xmlrpc_decompose_value(envP, paramArrayP, "(iA)", &nlines, &arrayP);
- if (envP->fault_occurred)
- retval = NULL;
- else
- size_t size = xmlrpc_array_size(envP, arrayP);
- fprintf(stderr,"service get of array size: %d\n", size);
- retval = NULL;
- else /*sort string*/
- retval = xmlrpc_array_new(envP);
- unsigned int i;
- for (i = 0; i < size && !envP->fault_occurred; ++i)
- xmlrpc_value * itemP;
- itemP = xmlrpc_array_get_item(envP, arrayP, i);
- if (!envP->fault_occurred)
- xmlrpc_read_string(envP, itemP, &line );
- fprintf(stderr,"server test output:%s\n",line);
- /*here we sort our current string*/
- qsort(line, strlen(line), sizeof (char), compare_rise);
- /*build sort string to retval*/
- itemP = xmlrpc_string_new(envP, line);
- xmlrpc_array_append_item(envP, retval, itemP);
- } /*end if */
- }/*end for*/
- xmlrpc_DECREF(arrayP);
- retval = NULL;
- }/*end second else*/
- }/*end firt else*/
- /* Return our result. */
- return retval;
- xmlrpc_server_abyss_parms serverparm;
- xmlrpc_registry * registryP;
- xmlrpc_env env;
- registryP = xmlrpc_registry_new(&env);
- /*xmlrpc_registry_add_method往服務(wù)器注冊一個(gè)新的方法。
- 所謂方法就是可以提供給客戶端的一個(gè)調(diào)用方法。
- 需要輸入方法名,以及方法的實(shí)現(xiàn)函數(shù)指針。
- xmlrpc_registry_add_method(&env, registryP, NULL, "string.qsort", &sample_qsort, NULL);
- serverparm.config_file_name = NULL;
- serverparm.registryP = registryP;
- serverparm.port_number = 8080;
- serverparm.log_file_name = "/tmp/xmlrpc_log";
- printf("Starting XML-RPC server...\n");
- /*xmlrpc_server_abyss啟動服務(wù),這是個(gè)循環(huán)函數(shù)*/
- xmlrpc_server_abyss(&env, &serverparm, XMLRPC_APSIZE(registryP));
- return 0;
