一體化的紅外接收頭信號(hào)腳接到單片機(jī)的RXD,紅外發(fā)射管信號(hào)是從單片機(jī)串口TXD輸出的,其中單片機(jī)的P3.4腳是輸出38KHZ的載波信號(hào),是用定時(shí)器0工作在方式2,自動(dòng)重載的,在中斷里進(jìn)行端口取反,產(chǎn)生38.4KHZ的方波,晶振用的是11.0592M,通信的波特率是9600
#include <reg51.h>
sbit led=P3^3;
uchar a;
sfr AUXR = 0x8E; //STC單片機(jī)1T的芯片時(shí)需要用的
void InitUART(void) //這個(gè)初始化是用的STC的1T單片機(jī)時(shí)用的
TMOD = 0x22;
SCON = 0x40;
TH1 = 0xDC;
TL1 = TH1;
PCON = 0x00;
TH0 = 0x70;
TL0 = TH0;
ET0 = 1;
TR0 = 1;
EA = 1;
ES=1;
TR1 = 1;
////////////////////////////////////////////////////下面的初始化是用的12T的單片機(jī)時(shí),
/*void InitUART(void)
TMOD = 0x22;
SCON = 0x40;
TH1 = 0xDC;
TL1 = TH1;
PCON = 0x00;
TH0 = 0xf4;
TL0 = TH0;
ET0 = 1;
TR0 = 1;
EA = 1;
ES=1;
TR1 = 1;
void Timer0Interrupt(void) interrupt 1 //定時(shí)器0工作在方式2自動(dòng)重載的,產(chǎn)生38.4KHZ方波作為載波用的
led=!led;
void SendOneByte(unsigned char c)
SBUF = c;
while(!TI);
TI = 0;
void main(void)
AUXR = AUXR|0xB0; // T1, 1T Mode
InitUART();
SendOneByte(a); //發(fā)射數(shù)據(jù)
void UARTInterrupt(void) interrupt 4
if(RI)
RI = 0;
a=SBUF ; //把收到的數(shù)據(jù)存入變量a中
TI = 0;
