查看: 3000|回復: 0
PCB設計中專業英譯術語之形狀與尺寸
ID:156167 發表于 2018-5-10 14:46 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  1. 導線(信道):conduction (track)
  2. 導線(體)寬度:conductor width
  3. 導線距離:conductor spacing
  4. 導線層:conductor layer
  5. 導線寬度/間距:conductor line/space
  6. 第一導線層:conductor layer No.1
  7. 圓形盤:round pad
  8. 方形盤:square pad
  9. 菱形盤:diamond pad
  10. 長方形焊盤:oblong pad
  11. 子彈形盤:bullet pad
  12. 淚滴盤:teardrop pad
  13. 雪人盤:snowman pad
  14. V形盤:V-shaped pad
  15. 環形盤:annular pad
  16. 非圓形盤:non-circular pad
  17. 隔離盤:isolation pad
  18. 非功能連接盤:monfunctional pad
  19. 偏置連接盤:offset land
  20. 腹(背)裸盤:back-bard land
  21. 盤址:anchoring spaur
  22. 連接盤圖形:land pattern
  23. 連接盤網格陣列:land grid array
  24. 孔環:annular ring
  25. 組件孔:component hole
  26. 安裝孔:mounting hole
  27. 支撐孔:supported hole
  28. 非支撐孔:unsupported hole
  29. 導通孔:via
  30. 鍍通孔:plated through hole (PTH)
  31. 余隙孔:access hole
  32. 盲孔:blind via (hole)
  33. 埋孔:buried via hole
  34. /盲孔:buried /blind via
  35. 任意層內部導通孔:any layer inner via hole (ALIVH)
  36. 全部鉆孔:all drilled hole
  37. 定位孔:toaling hole
  38. 無連接盤孔:landless hole
  39. 中間孔:interstitial hole
  40. 無連接盤導通孔:landless via hole
  41. 引導孔:pilot hole
  42. 端接全隙孔:terminal clearomee hole
  43. 準表面間鍍覆孔:quasi-interfacing plated-through hole
  44. 準尺寸孔:dimensioned hole
  45. 在連接盤中導通孔:via-in-pad
  46. 孔位:hole location
  47. 孔密度:hole density
  48. 孔圖:hole pattern
  49. 鉆孔圖:drill drawing
  50. 裝配圖:assembly drawing
  51. 印制板組裝圖:printed board assembly drawing
52. 參考基準:datum referan
