1.開料:CutLamination/Material cutting 2.鉆孔:Drilling 3.內鉆:Inner LayerDrilling 4一次孔:Outer Layer Drilling 5.二次孔:2nd Drilling 6.雷射鉆孔:Laser Drilling /Laser Ablation 7.盲(埋)孔鉆孔:Blind & Buried Hole Drilling 8.干膜制程:PhotoProcess(D/F)/Dry Film 9.前處理 (Pretreatment) 10.壓膜:Dry Film Lamination 11.曝光:Exposure 12.顯影:Developing 13.去膜:Stripping 14.壓合:Lamination 15:黑化:Black OxideTreatment 16.微蝕:Microetching 17.鉚釘組合:eyelet 18.迭板:Lay up 19.壓合:Lamination 20.后處理:Post Treatment 21.黑氧化:Black Oxide Removal 22.銑靶:spot face 23.去溢膠:resin flush removal 24.減銅:Copper Reduction 25.水平電鍍:HorizontalElectrolytic Plating 26.電鍍:Panel plating 27.錫鉛電鍍:Tin-Lead Plating /Pattern Plating 28.低于 1 mil: Less than 1 mil Thickness 29.高于 1 mil:More than 1 mil Thickness 30.砂帶研磨:Belt Sanding 31:剝錫鉛:Tin-Lead Stripping 32.微切片: Microsection 33.蝕銅:Etching 34.初檢:Touch-up 35.塞孔:Plug Hole 36.防焊(綠漆/綠油):SolderMask 37.C面印刷:Printing Top Side 38.S面印刷:Printing Bottom Side 39.靜電噴涂:Spray Coating 40.前處理:Pretreatment 41.預烤:Precure 42.后烘烤:Postcure 43.印刷:Ink Print 44.表面刷磨:Scrub 45.后烘烤:Postcure 46.UV烘烤:UV Cure 47.文字印刷:Printing of Legend 48.噴砂:Pumice/Wet Blasting 49.印可剝離防焊/藍膠:Peelable Solder Mask) 50.化學前處理,化學研磨:Chemical Milling 51.選擇性浸金壓膜:Selective Gold Dry Film Lamination 52.鍍金:Gold plating 53.噴錫:Hot Air SolderLeveling 54.成型:Profile/Form 55.開短路測試:Electrical Testing 56.終檢:Final VisualInspection 57.金手指鍍鎳金:Gold Finger 58.電鍍軟金:Soft Ni/Au Plating 59.浸鎳金:Immersion Ni/Au / Electroless Ni/Au 60.噴錫:Hot Air Solder Leveling 61.水平噴錫:HorizontalHot Air Solder Leveling 62.垂直噴錫: Vertical Hot Air Solder Leveling 63.超級焊錫:Super Solder 64.印焊錫突點:Solder Bump 65.數控銑/鑼板:N/C Routing/Milling 66.模具沖/啤板:Punch 67.板面清洗烘烤:Cleaning & Backing 68.V型槽/V-CUT: V-Cut/V-Scoring 69.金手指斜邊:Beveling of G/F 70.短斷路測試Electrical Testing/Continuity & Insulation Testing 71.AOI 光學檢查:AOI Inspection 72:VRS 目檢:Verified & Repaired 73.泛用型治具測試:Universal Tester 74.專用治具測試:Dedicated Tester 75.飛針測試:Flying Probe 76.終檢:Final Visual Inspection 77.壓板翹:Warpage Remove 78.X-OUT 印刷:X-Out Marking 79.包裝及出貨:Packing& shipping 80.清洗及烘烤: Final Clean & Baking 81.銅面保護劑:ENTEK Cu-106A/OSP 82.離子殘余量測試:Ionic Contamination Test/ Cleanliness Test 83.冷熱沖擊試驗:Thermal cycling Testing 84.焊錫性試驗:Solderability Testing 85.雷射鉆孔:Laser Ablation 86.雷射鉆Tooling孔:Laser ablationTooling Hole 87.雷射曝光對位孔:Laser Ablation Registration Hole 88.雷射Mask制作:Laser Mask 89.雷射鉆孔:Laser Ablation 90.AOI檢查及VRS:AOI Inspection & Verified & Repaired 91.除膠渣:Desmear 92.專用治具測試:Dedicated Tester 93.飛針測試:Flying Probe 94.壓板翹: Warpage Remove 95.底片:Ablation 96.燒溶:laser) 97.切/磨:abrade 98.粗化:abrasion 99.耐磨性:absorption resistance 100.允收:ACC /accept 101.加速腐蝕:accelerated corrosion test 102加速試驗:accelerated test 103.速化反應:acceleration 104.加速劑:accelerator 105.允許:acceptable 106.活化液:activator 107.實際在制品:active work in process 108.附著力:adhesion 109.黏著法:adhesive method 110.氣泡:air inclusion 111.風刀:air knife 112.不定形的改變:amorphous change 113.總量:amount 114.硝基戊烷:amylnitrite 115.分析儀:analyzer 116環狀墊圈;孔環annular ring 117.陽極泥:anodeslime (sludge) 118.陽極清洗:anodizing 119.自動光學檢測:AOI/automatic optical inspection 120.引用之文件:applicable documents 121.允收水平抽樣:AQL sampling 122.液態光阻:aqueous photoresist 123.縱橫比(厚寬比):aspect ratioAs received 124.背光:back lighting 125.墊板:back-up 126.預留在制品:banked work in process 127.基材:base material 128.基準績效:baseline performance 129.批:batch 130.貝他射線照射法:beta backscattering 131.切斜邊;斜邊:beveling 132.二方向之變形:biaxial deformation 133.黑化:black-oxide 134.空板:blank panel 135.挖空:blanking 136.彈開:blip 137.氣泡:blister blistering 138.吹孔:blow hole 139.板厚錯誤:board-thickness error 140.黏結層:bonding plies 141.板彎:bow ; bowing 142.破空:break out 143.搭橋;橋接:bridging 144.接單生產:BTO (Build To Order) 145,.燒焦:burning 146.毛邊(毛頭):burr 147.碳化物:carbide 148.定位梢:carlson pin 149.載運劑:carrier 150.催化:catalyzing 151.陰極濺射法:catholicsputtering 152.隔板;鋼板:caul plate 153.校驗系統之各種要求:calibration system requirements 154.中心光束法:center beam method 155.集中式投射線:central projection 156.認證:certification 157.倒角 (金手指):chamfer chamfer 158.切斜邊;倒角:chamfering 159.特性阻抗:characteristic impedance 160.電量傳遞過電壓:charge transfer overpotential 161.網框:chase 162.棋盤:checkboard 163.蟹和劑:chelator 164.化學鍵:chemical bond 165.化學蒸著鍍:chemical vapor deposition 166.圓周性之孔破:circumferential void 167.包夾金屬:clad metal 168.無塵室:clean room 169.間隙:clearance 170.表面處理:Coating/Surface Finish |
