查看: 2722|回復(fù): 0
12864滾動(dòng)顯示圖片
ID:228147 發(fā)表于 2017-9-13 16:55 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include "LCD_12864.h"
#include <stdio.h>
extern void cls();
extern uchar LCD_Initialise();
extern uchar LCD_Write_Command(uchar cmd);
extern uchar LCD_Write_Command_P2(uchar cmd,uchar para1,uchar para2);
extern uchar LCD_Write_Data(uchar dat);
extern void Set_LCD_POS(uchar row,uchar col);
extern uchar code LCD_WIDTH;
extern uchar code LCD_HEIGHT;
sbit S1 = P1^0;
sbit S2 = P1^1;
uchar code ImageX[] =
        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
        uchar i,j,m;
        uint k,x;
        LCD_Initialise();
        Set_LCD_POS(0,0);
        cls();
                 if(S1!=0)
                         LCD_Write_Command_P2(LC_GRH_STP,0,0);
                        for(i=0;i<LCD_HEIGHT;i++)
                                 Set_LCD_POS(i,0);
                                LCD_Write_Command(LC_AUT_WR);
                                for(j=0;j<LCD_WIDTH;j++)
                                         m = ImageX[i*LCD_WIDTH + j];
                                        if(S2 == 0)
                                                m = ~m;
                                        LCD_Write_Data(m);
                                LCD_Write_Command(LC_AUT_OVR);
                         k = 0;
                        while(k!=128/8*LCD_HEIGHT)
                                LCD_Write_Command_P2(LC_GRH_STP,k%256,k/256);
                                for(x=0;x<5000;x++);
                                k+=LCD_WIDTH;
        for(x=0;x<40000;x++);
相關(guān)帖子
