2024-10-21 16:10 上傳
- * @file adc.c
- * @author 正點原子團隊(ALIENTEK)
- * @version V1.3
- * @date 2020-04-24
- * @brief ADC 驅動代碼
- * @license Copyright (c) 2020-2032, 廣州市星翼電子科技有限公司
- * @attention
- * 修改說明
- * V1.0 20200423
- * 第一次發布
- * V1.1 20200423
- * 1,支持ADC單通道DMA采集
- * 2,新增adc_dma_init和adc_dma_enable函數.
- * V1.2 20200423
- * 1,支持ADC多通道DMA采集
- * 2,新增adc_nch_dma_init函數.
- * V1.3 20200424
- * 1,支持內部溫度傳感器溫度采集
- * 2,新增adc_temperature_init和adc_get_temperature函數.
- #include "./BSP/ADC/adc.h"
- //#include "./BSP/DMA/dma.h"
- #include "./SYSTEM/delay/delay.h"
- #include "./SYSTEM/usart/usart.h"
- ADC_HandleTypeDef g_adc_handle; /* ADC句柄 */
- DMA_HandleTypeDef g_dma_adc_handle; /* 與ADC關聯的DMA句柄 */
- uint8_t g_adc_dma_sta = 0; /* DMA傳輸狀態標志, 0,未完成; 1, 已完成 */
- uint16_t g_adc_value[ADC_CH_NUM * ADC_COLL] = {0}; /* 存儲ADC原始值 */
- //float g_adc_u_value[ADC_CH_NUM] = {0}; /* 存儲ADC轉換后的電壓值 */
- * @brief ADC初始化函數
- * @note 本函數支持ADC1/ADC2任意通道, 但是不支持ADC3
- * 我們使用12位精度, ADC采樣時鐘=12M, 轉換時間為: 采樣周期 + 12.5個ADC周期
- * 設置最大采樣周期: 239.5, 則轉換時間 = 252 個ADC周期 = 21us
- * @param 無
- * @retval 無
- void adc_init(void)
- ADC_ChannelConfTypeDef sConfig = {0};
- g_adc_handle.Instance = ADC_ADCX;
- g_adc_handle.Init.ContinuousConvMode = ENABLE;
- g_adc_handle.Init.DataAlign = ADC_DATAALIGN_RIGHT;
- g_adc_handle.Init.DiscontinuousConvMode = DISABLE;
- g_adc_handle.Init.ExternalTrigConv = ADC_SOFTWARE_START;
- g_adc_handle.Init.NbrOfConversion = ADC_CH_NUM;
- g_adc_handle.Init.NbrOfDiscConversion = 0;
- g_adc_handle.Init.ScanConvMode = ENABLE;
- HAL_ADC_Init(&g_adc_handle);
- HAL_ADCEx_Calibration_Start(&g_adc_handle);//ADC校準
- sConfig.Channel = ADC_ADCX_CH4;
- sConfig.Rank = 1;
- sConfig.SamplingTime = ADC_SAMPLETIME_239CYCLES_5;
- HAL_ADC_ConfigChannel(&g_adc_handle,&sConfig);
- sConfig.Channel = ADC_ADCX_CH5;
- sConfig.Rank = 2;
- __HAL_LINKDMA(&g_adc_handle, DMA_Handle ,g_dma_adc_handle);
- // HAL_NVIC_SetPriority(DMA1_Channel1_IRQn,3,3);
- // HAL_NVIC_EnableIRQ(DMA1_Channel1_IRQn);
- // HAL_DMA_Start_IT(&g_dma_adc_handle, (uint32_t)&ADC1->DR, (uint32_t)g_adc_value, ADC_CH_NUM * ADC_COLL);
- // HAL_ADC_Start_DMA(&g_adc_handle,(uint32_t *)g_adc_value,ADC_CH_NUM * ADC_COLL);
- void adc_dma_init(void)
- if ((uint32_t)ADC_ADCX_DMACx > (uint32_t)DMA1_Channel7) /* 大于DMA1_Channel7, 則為DMA2的通道了 */
- __HAL_RCC_DMA2_CLK_ENABLE(); /* DMA2時鐘使能 */
- else
- __HAL_RCC_DMA1_CLK_ENABLE(); /* DMA1時鐘使能 */
- g_dma_adc_handle.Instance = DMA1_Channel1;
- g_dma_adc_handle.Init.Direction = DMA_PERIPH_TO_MEMORY;
- g_dma_adc_handle.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD;
- g_dma_adc_handle.Init.MemInc = DMA_MINC_ENABLE;
- g_dma_adc_handle.Init.Mode = DMA_NORMAL;
- g_dma_adc_handle.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD;
- g_dma_adc_handle.Init.PeriphInc = DMA_PINC_DISABLE;
- g_dma_adc_handle.Init.Priority = DMA_PRIORITY_MEDIUM;
- HAL_DMA_Init(&g_dma_adc_handle);
- // __HAL_LINKDMA(&g_adc_handle, DMA_Handle ,g_dma_adc_handle);
- HAL_NVIC_SetPriority(DMA1_Channel1_IRQn,1,3);
- HAL_NVIC_EnableIRQ(DMA1_Channel1_IRQn);
- HAL_ADC_Start_DMA(&g_adc_handle,(uint32_t *)g_adc_value,ADC_CH_NUM * ADC_COLL);
- // if (HAL_ADC_Start_DMA(&g_adc_handle, (uint32_t *)g_adc_value, ADC_CH_NUM * ADC_COLL) != HAL_OK)
- // // 處理錯誤
- // printf("error");
- * @brief ADC底層驅動,引腳配置,時鐘使能
- 此函數會被HAL_ADC_Init()調用
- * @param hadc:ADC句柄
- * @retval 無
- void HAL_ADC_MspInit(ADC_HandleTypeDef *hadc)
- if(hadc->Instance == ADC_ADCX)
- GPIO_InitTypeDef GPIO_Initure;
- ADC_ADCX_CHY_CLK_ENABLE(); //adc時鐘
- ADC_ADCX_CH4_GPIO_CLK_ENABLE(); /* 開啟GPIO時鐘 */
- ADC_ADCX_CH5_GPIO_CLK_ENABLE(); /* 開啟GPIO時鐘 */
- /* AD采集引腳模式設置,模擬輸入 */
- GPIO_Initure.Pin = ADC_ADCX_CH4_GPIO_PIN;
- GPIO_Initure.Mode = GPIO_MODE_ANALOG;
- GPIO_Initure.Pull = GPIO_PULLUP;
- HAL_GPIO_Init(ADC_ADCX_CH4_GPIO_PORT, &GPIO_Initure);
- GPIO_Initure.Pin = ADC_ADCX_CH5_GPIO_PIN;
- HAL_GPIO_Init(ADC_ADCX_CH5_GPIO_PORT, &GPIO_Initure);
- //ADC時鐘初始化
- RCC_PeriphCLKInitTypeDef adc_clk_init = {0};
- adc_clk_init.PeriphClockSelection = RCC_PERIPHCLK_ADC;
- adc_clk_init.AdcClockSelection = RCC_ADCPCLK2_DIV6;
- HAL_RCCEx_PeriphCLKConfig(&adc_clk_init);
- void ADC_ADCX_DMASX_IRQHandler(void)
- HAL_DMA_IRQHandler(&g_dma_adc_handle);
- g_adc_dma_sta = 1; // 標記DMA傳輸完成
- uint16_t g_adc_val[ADC_CH_NUM];
- void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef *hadc)
- uint32_t temp;
- // print_adc_values();
- HAL_ADC_Stop_DMA(hadc);
- calc_adc_val(g_adc_val);
- HAL_ADC_Start_DMA(&g_adc_handle,(uint32_t *)&g_adc_value,ADC_SUM);
- //void print_adc_values(void)
- // // 確保在打印之前進行數據校驗,例如檢查數據個數和有效性
- // for (int i = 0; i < ADC_CH_NUM * ADC_COLL; i++)
- // // 確認數組中的數據是否有效
- // if (g_adc_value[i] != 0) // 例如,不等于0表示有效
- // printf("g_adc_value[%d]: %u\r\n", i, g_adc_value[i]);
- * @brief 獲取通道ch的轉換值,取times次, 然后平均
- * @param ch: 通道號, 0~17
- * @retval 通道ch的times次轉換結果平均值
- uint32_t adc_get_result_average(uint8_t ch)
- uint32_t temp_val = 0;
- uint16_t t;
- for(t = ch; t < ADC_SUM; t += ADC_CH_NUM)
- temp_val += g_adc_value[t];
- return temp_val / ADC_COLL;
- * @brief 計算ADC的平均值(濾波)
- * @param * p :存放ADC值的指針地址
- * @note 此函數對電壓、溫度、電流對應的ADC值進行濾波
- * @retval 無
- void calc_adc_val(uint16_t * p)
- uint32_t temp[ADC_CH_NUM] = {0,0}; /* 定義一個緩存數組 */
- int i,j;
- for(i = 0; i < ADC_COLL; i++) /* 循環采集ADC_COLL次數 */
- for(j = 0; j < ADC_CH_NUM; j++) /* 根據ADC通道數循環獲取,并累加 */
- temp[j] += g_adc_value[j+i*ADC_CH_NUM]; /* 將采集到的ADC值,各通道進行累加 */
- temp[j] /= ADC_COLL; /* 獲取平均值 */
- p[j] = temp[j]; /* 存到*p */
- * @file main.c
- * @version V1.0
- * @brief SPI 實驗
- * @attention
- * 實驗平臺:正點原子 STM32F103開發板
- #include "./SYSTEM/sys/sys.h"
- #include "./USMART/usmart.h"
- #include "./BSP/LED/led.h"
- #include "./BSP/LCD/lcd.h"
- #include "./BSP/KEY/key.h"
- #include "./BSP/NORFLASH/norflash.h"
- #include "./BSP/SPI/spi.h"
- #include "./BSP/ICM42688/icm42688.h"
- #include "./BSP/ESP8266USART/esp8266usart.h"
- #include "./BSP/ESP8266/esp8266.h"
- //int time=50;
- int8_t accel1[3];
- int16_t accel[3];
- int16_t gyro[3];
- int16_t adc_result[ADC_CH_NUM];
- //uint8_t ret;
- uint8_t *frame = NULL;
- uint8_t result;
- extern uint16_t g_adc_value[ADC_CH_NUM * ADC_COLL] ;
- extern uint16_t g_adc_val[ADC_CH_NUM];
- extern uint8_t g_adc_dma_sta;
- extern ADC_HandleTypeDef g_adc_handle; /* ADC句柄 */
- int main(void)
- HAL_Init(); /* 初始化HAL庫 */
- sys_stm32_clock_init(RCC_PLL_MUL9); /* 設置時鐘, 72Mhz */
- delay_init(72); /* 延時初始化 */
- usart_init(115200); /* 串口初始化為115200 */
- // usmart_dev.init(72); /* 初始化USMART */
- // led_init(); /* 初始化LED */
- // key_init(); /* 初始化按鍵 */
- spi2_init();
- Icm42688_Init();
- // ICM42688_Connect();
- esp8266_uart_init(115200);
- adc_init();
- adc_dma_init();
- // // 等待DMA傳輸完成
- // while (!g_adc_dma_sta)
- // // 等待DMA傳輸完成
- // printf("Waiting for DMA transfer to complete...\r\n");
- // // 輸出第一個ADC值
- // printf("g_adc_value[0]:%d\r\n", g_adc_value[0]);
- // ESP8266_EN(0);
- // result = esp8266_Init(115200);
- // printf("result:%d\r\n",result);
- // result = esp8266_send_at_cmd("AT","OK",500);
- // 連接wifi成功
- // result = esp8266_join_ap("xiao","312312312");
- //for(int i = 0; i < 2 ;i++)
- // printf("g_adc_value[%d]:%u\r\n",i,g_adc_val[i]);
- // printf("wraeyrut");
- // printf("g_adc_value");
- // printf("x,y:%u\r\n",g_adc_val[0]);
- while (1)
- //多通道ADC轉化,沒有DMA
- // uint16_t adcx;
- // adcx = adc_get_result(adc_result);
- // printf("adcx:%d,adcy:%d,\r\n",adc_result[0],adc_result[1]);
- printf("adcx:%d,adcy:%d\r\n",g_adc_val[0],g_adc_val[1]);
- // //測試串口3是否正常
- // //測試串口3是否正常
- // //測試串口3是否正常
- // frame = esp8266_uart_rx_get_frame();
- // if (frame != NULL) {
- // // 處理接收到的數據,這里假設我們要打印接收到的數據
- // esp8266_uart_printf("Received: %s\r\n", frame);
- // // 處理完之后,重置接收狀態
- // esp8266_uart_rx_restart(); // 重新啟動接收
- // } else {
- // // 如果沒有接收到完整數據,可以選擇處理超時或者其他邏輯
- // esp8266_uart_printf("No complete frame received yet.\r\n");
- // esp8266_uart_printf("AT\r\n");
- // printf("456\r\n");
- // delay_ms(1000);
- // printf("frame:%s\r\n",frame);
- // printf("123\r\n");
- //測試ICM42688
- // ICM42688_Read_Data(accel,gyro);
- // printf("gyro_x:%d gyro_y:%d gyro_z:%d\r\n",gyro[0],gyro[1],gyro[2]);
- // printf("accel_x:%d accel_y:%d accel_z:%d\r\n",accel[0],accel[1],accel[2]);
復制代碼 |
