查看: 14667|回復: 32
STM32F103+RFID(RC522)OLED 0.96顯示 源碼
ID:46986 發表于 2017-7-22 10:06 | 顯示全部樓層 |閱讀模式
該系統以STM32F103C8T6為核心(可自行修改成103系列其他芯片,修改編譯參數)。通過OLED 0.96顯示相關信息。通過對RFID模塊(RC522)的控制,讀取RFID標簽的信息,并通過串口上傳(可配套相應的上位機,完成簡單的考勤,安保等系統)
  1. #include "stm32f10x.h"
  2. #include "oled.h"
  3. #include "MAIN.h"
  4. #include "mfrc522.h"
  5. #include "usart.h"
  6. #include "string.h"
  7. unsigned char card1[4] = {0xF0,0x1C,0x70,0x3B};  //卡序列號
  8. unsigned char card2[4] = {0xDE,0x8A,0xDF,0x2B};  //卡序列號
  9. unsigned char card3[4] = {0xD2,0xB2,0x73,0x5B};
  10. unsigned char card4[4] = {0xB7,0x29,0xDF,0x2B};
  11. unsigned char snr, buf[16]="liu-bridge",bufr[16], TagType[2], SelectedSnr[4], DefaultKey[6] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
  12. unsigned char Read_Data[16],PassWd[6],WriteData[16],RevBuffer[30], MLastSelectedSnr[4],NewKey[16];
  13. char cardID[4];
  14. unsigned char kahao;
  15. void findcard();
  16. void GPIO_ini()
  17. {
  18.   GPIO_InitTypeDef  GPIO_InitStructure;
  19.
  20.   /* Enable the GPIO Clock */
  21.   RCC_APB2PeriphClockCmd(MF522_RST_CLK, ENABLE);
  22.   /* Configure the GPIO pin */
  23.   GPIO_InitStructure.GPIO_Pin = MF522_RST_PIN;
  24.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  25.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
  26.   GPIO_Init(MF522_RST_PORT, &GPIO_InitStructure);
  27.
  28.   /* Enable the GPIO Clock */
  29.   RCC_APB2PeriphClockCmd(MF522_MISO_CLK, ENABLE);
  30.   /* Configure the GPIO pin */
  31.   GPIO_InitStructure.GPIO_Pin = MF522_MISO_PIN;
  32.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  33.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
  34.   GPIO_Init(MF522_MISO_PORT, &GPIO_InitStructure);
  35.
  36.   /* Enable the GPIO Clock */
  37.   RCC_APB2PeriphClockCmd(MF522_MOSI_CLK, ENABLE);
  38.   /* Configure the GPIO pin */
  39.   GPIO_InitStructure.GPIO_Pin = MF522_MOSI_PIN;
  40.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  41.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
  42.   GPIO_Init(MF522_MOSI_PORT, &GPIO_InitStructure);
  43.
  44.   /* Enable the GPIO Clock */
  45.   RCC_APB2PeriphClockCmd(MF522_SCK_CLK, ENABLE);
  46.   /* Configure the GPIO pin */
  47.   GPIO_InitStructure.GPIO_Pin = MF522_SCK_PIN;
  48.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  49.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
  50.   GPIO_Init(MF522_SCK_PORT, &GPIO_InitStructure);
  51.
  52.   /* Enable the GPIO Clock */
  53.   RCC_APB2PeriphClockCmd(MF522_NSS_CLK, ENABLE);
  54.   /* Configure the GPIO pin */
  55.   GPIO_InitStructure.GPIO_Pin = MF522_NSS_PIN;
  56.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  57.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
  58.   GPIO_Init(MF522_NSS_PORT, &GPIO_InitStructure);
  59.
  60.   /* Enable the GPIO Clock */
  61.   RCC_APB2PeriphClockCmd(LED_CLK, ENABLE);
  62.   /* Configure the GPIO pin */
  63.   GPIO_InitStructure.GPIO_Pin = LED_PIN;
  64.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  65.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
  66.   GPIO_Init(LED_PORT, &GPIO_InitStructure);
  67. }
  68. void InitializeSystem()
  69. {
  70.         LED_OFF;
  71.         delay_10ms(10);
  72.         PcdReset();
  73.         PcdAntennaOff();
  74.         PcdAntennaOn();
  75.         M500PcdConfigISOType( 'A' );
  76.         LED_ON;
  77.         delay_10ms(10);
  78.         LED_OFF;
  79.         delay_10ms(10);
  80.         LED_ON;
  81.         delay_10ms(10);
  82.         LED_OFF;
  83. }
  84. int i,j;
  85. int main(void)
  86. {
  87.         char status;
  88.         unsigned char rfidflag;
  89.         unsigned char discnt;
  90.         kahao=0;
  91.         GPIO_ini();
  92.   InitializeSystem( );
  93.   uart_init(9600);
  94.         OLED_Init();
  95.         //Draw_Logo();
  96.   for(i=0;i<2000;i++)
  97.           for(j=0;j<2000;j++);
  98.         OLED_Fill(0x00);
  99.   OLED_ShowString1(0,0," RFID EPC SYS");
  100.         OLED_ShowString1(0,3," Status:  OK");
  101.         printf("\r\n This is a RFID System \r\n");
  102.         while(1)
  103.         { status= PcdRequest(REQ_ALL,TagType);
  104.                 if(!status)
  105.                 {
  106.                         status = PcdAnticoll(SelectedSnr);
  107.                         if(!status)
  108.                         {
  109.                                 status=PcdSelect(SelectedSnr);
  110.                                 if(!status)
  111.                                 {
  112.                                         snr = 1;  //扇區號1
  113.           status = PcdAuthState(KEYA, (snr*4+3), DefaultKey, SelectedSnr);// 校驗1扇區密碼,密碼位于每一扇區第3塊
  114.                                         {
  115.                                                 if(!status)
  116.                                                 {
  117.                                                         //status = PcdRead((snr*4+0), buf);  // 讀卡,讀取1扇區0塊數據到buf[0]-buf[16]
  118.                                                 //        buf[0]=2;buf[1]=2;buf[2]=3;buf[3]=4;buf[4]=5;buf[6]=1;;buf[7]=1;buf[8]=1;buf[9]=9;
  119.                                 //                        status = PcdWrite((snr*4+0), buf);  // 寫卡,將buf[0]-buf[16]寫入1扇區0塊
  120.                                                         if(!status)
  121.                                                         {
  122.        //讀寫成功,點亮LED
  123.        LED_ON;
  124.        PcdAuthState(KEYA, (snr*4+3), DefaultKey, SelectedSnr);
  125.        status = PcdRead((snr*4+0), bufr);
  126.
  127.        //printf(" %s \r\n",bufr );
  128.                                                     //printf("%s", SelectedSnr);
  129.                                                     findcard();
  130.        if(kahao==1)
  131.                                                           {  OLED_ShowString1(0,5," ID 1 Pass");
  132.        printf("%s","#1001[        DISCUZ_CODE_0        ]quot;);
  133.        discnt=0;
  134.        rfidflag=1;
  135.        }
  136.        else if(kahao==2)
  137.                                                           {  OLED_ShowString1(0,5," ID 2 Pass");
  138.        printf("%s","#1002[        DISCUZ_CODE_0        ]quot;);
  139.        discnt=0;
  140.        rfidflag=1;
  141.        }
  142.        else if(kahao==3)
  143.                                                           {  OLED_ShowString1(0,5," ID 3 Pass");
  144.        printf("%s","#1003[        DISCUZ_CODE_0        ]quot;);
  145.        discnt=0;
  146.        rfidflag=1;
  147.        }
  148.        else if(kahao==4)
  149.                                                           {  OLED_ShowString1(0,5," ID 4 Pass");
  150.        printf("%s","#1004[        DISCUZ_CODE_0        ]quot;);
  151.        discnt=0;
  152.        rfidflag=1;
  153.        }
  154.        //printf(" %s %s",bufr,SelectedSnr);
  155.        WaitCardOff();
  156.                                                         }
  157.                                                 }
  158.                                         }
  159.                                 }
  160.                         }
  161.                 }
  162.                 LED_OFF;
  163.                 if(rfidflag==1)
  164.           { discnt++;
  165.                         if(discnt>200)
  166.                         { OLED_ShowString1(0,5,"          ");
  167.                                 discnt=0;
  168.                                 rfidflag=0;
  169.                         }
  170.                   OLED_DLY_ms(5);
  171.                 }
  172.   }
  173. }
  174. void findcard()
  175. { unsigned char ii;
  176.         for (ii=0;ii<4;ii++)          //比較卡序列號
  177.   { if (SelectedSnr[ii] != card1[ii])
  178.     { kahao=0;
  179.             break;
  180.           }
  181.           else
  182.           { if (ii==3)
  183.             { kahao=1;
  184.               goto A;
  185.               break;
  186.                   }
  187.           }
  188.   }
  189.   for (ii=0;ii<4;ii++)
  190.   { if (SelectedSnr[ii] != card2[ii])
  191.      { kahao=0;
  192.              break;
  193.            }
  194.            else
  195.            { if (ii==3)
  196.              { kahao=2;
  197.                                  goto A;
  198.                       break;
  199.                    }
  200.            }
  201.   }
  202.         for (ii=0;ii<4;ii++)
  203.   { if (SelectedSnr[ii] != card3[ii])
  204.      { kahao=0;
  205.              break;
  206.            }
  207.            else
  208.            { if (ii==3)
  209.              { kahao=3;
  210.                                  goto A;
  211.                       break;
  212.                    }
  213.            }
  214.   }
  215.         for (ii=0;ii<4;ii++)
  216.   { if (SelectedSnr[ii] != card4[ii])
  217. ……………………
  218. …………限于本文篇幅 余下代碼請從51黑下載附件…………
STM32_RFID&amp;OLED.rar (300.1 KB, 下載次數: 819)
ID:214312 發表于 2017-8-31 23:04 | 顯示全部樓層
謝謝分享!1
ID:75585 發表于 2017-9-8 09:53 | 顯示全部樓層
謝謝樓主,
ID:239125 發表于 2017-10-13 11:50 | 顯示全部樓層
多謝多謝 很重要啊~~
ID:252297 發表于 2017-11-22 15:43 | 顯示全部樓層
正在找這一類的資料
ID:254398 發表于 2017-12-8 22:15 | 顯示全部樓層
感謝分享
ID:281066 發表于 2018-1-31 10:06 | 顯示全部樓層
非常感謝
ID:281066 發表于 2018-1-31 10:25 | 顯示全部樓層
非常感謝
ID:297264 發表于 2018-3-26 14:50 | 顯示全部樓層
學習下
ID:297264 發表于 2018-3-26 14:53 | 顯示全部樓層
感謝分享
ID:76606 發表于 2018-4-28 21:45 | 顯示全部樓層
好東西
ID:334442 發表于 2018-5-20 21:08 | 顯示全部樓層
好東西,感謝分享!
ID:336115 發表于 2018-6-3 20:40 | 顯示全部樓層
好東西,感謝分享!
ID:336115 發表于 2018-6-14 15:46 | 顯示全部樓層
小白想問下stm32板子和RC522模塊怎么接線
ID:202414 發表于 2018-7-4 15:44 | 顯示全部樓層
下載的不是rar文件,麻煩問一下需要用什么打開啊?
ID:337376 發表于 2018-7-6 11:14 | 顯示全部樓層
謝謝分享~
ID:384422 發表于 2018-8-9 01:32 | 顯示全部樓層
感謝分享
ID:386577 發表于 2018-8-15 16:29 | 顯示全部樓層
謝謝分享!1
ID:143047 發表于 2018-9-3 15:31 | 顯示全部樓層
學習學習,
ID:379988 發表于 2018-11-22 20:05 | 顯示全部樓層
13671276812 發表于 2018-7-4 15:44
下載的不是rar文件,麻煩問一下需要用什么打開。
擴展拓展名,把.rar寫上
ID:256850 發表于 2019-4-9 14:30 | 顯示全部樓層
謝謝分享~~
ID:101620 發表于 2019-7-31 18:41 | 顯示全部樓層
并不能正常使用,不知為何,引腳的鏈接方式可以找到,貌似并不對
ID:426861 發表于 2019-8-9 13:57 | 顯示全部樓層
OLED的主控是什么型號的啊
ID:595938 發表于 2019-8-9 15:34 | 顯示全部樓層
非常感謝樓主分享!
ID:174087 發表于 2019-8-9 16:54 | 顯示全部樓層
有沒有兄弟用過RC523啊,我想識讀ISO14443B的卡,但是網上找到的資料調試并沒成功,兄弟們有沒有啥經驗啊
ID:511456 發表于 2019-10-10 12:53 | 顯示全部樓層
感謝分享
ID:607641 發表于 2019-12-29 21:47 | 顯示全部樓層
謝謝分享。。。
ID:607641 發表于 2020-1-9 13:39 | 顯示全部樓層
已經下載學習謝謝
ID:192515 發表于 2020-4-5 23:37 | 顯示全部樓層
感謝分享
ID:743538 發表于 2020-5-3 20:16 | 顯示全部樓層
十分感謝
十分感謝
ID:743538 發表于 2020-5-3 20:17 | 顯示全部樓層
十分感謝
ID:979426 發表于 2024-1-12 12:06 | 顯示全部樓層
aptx4860 發表于 2017-11-22 15:43
正在找這一類的資料
剛好上學期做了這個
