查看: 2330|回復: 3
這個單片機程序為什么會無法測距?
ID:660005 發表于 2021-8-10 10:29 | 顯示全部樓層 |閱讀模式
為什么會無法測距?是程序上的錯誤,還是我沒有寫完全?
但是網上的程序與這個差別不大
#include "delay.h"
#include "sys.h"
#include "usart.h"
#include "HCSR04.h"
int main(void)
         delay_init();                     //延時函數初始化
         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //設置NVIC中斷分組2:2位搶占優先級,2位響應優先級
         uart_init(115200);         //串口初始化為115200
         HCSR04_Init();
   float T=gettime();
                int i;
                float s=0;
                float t=0;
                float a=0;
                while(i=0,i<5,i++)
                t=T*170/1000;
                s=t+s;
                        a=s/5;
         printf("距離為:%d cm\r\n",a);//打印總的距離
         delay_ms(1000);
以上是主函數
#include "HCSR04.h"
#include "delay.h"
int n=0;
int time=0;
void HCSR04_Init(void)
        GPIO_InitTypeDef  GPIO_InitStructure;
        NVIC_InitTypeDef NVIC_InitStructure;
        TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);         //使能PB端口時鐘
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;                                 //PB.13 端口配置
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                  //推挽輸出
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;                 //IO口速度為50MHz
        GPIO_Init(GPIOB, &GPIO_InitStructure);                                         //根據設定參數初始化GPIOB.13
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14;                                 //PB.14 端口配置
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;                  //下拉輸入
        GPIO_Init(GPIOB, &GPIO_InitStructure);                                         //根據設定參數初始化GPIOB.14
                //定時器TIM3初始化
        TIM_TimeBaseStructure.TIM_Period =10000-1; //設置在下一個更新事件裝入活動的自動重裝載寄存器周期的值
        TIM_TimeBaseStructure.TIM_Prescaler =7200-1; //設置用來作為TIMx時鐘頻率除數的預分頻值
        TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //設置時鐘分割:TDTS = Tck_tim
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //TIM向上計數模式
        TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); //根據指定的參數初始化TIMx的時間基數單位
        TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE ); //使能指定的TIM3中斷,允許更新中斷
        //中斷優先級NVIC設置
        NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;  //TIM3中斷
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;  //先占優先級0級
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;  //從優先級3級
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道被使能
        NVIC_Init(&NVIC_InitStructure);  //初始化NVIC寄存器
        TIM_Cmd(TIM3,ENABLE);
void TIM3_IRQHandler(void)   //TIM3中斷
        if (TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET)  //檢查TIM3更新中斷發生與否
                n+=1;
                TIM_ClearITPendingBit(TIM3, TIM_IT_Update  );  //清除TIMx更新中斷標志
float gettime(void)//時間獲取函數
        GPIO_ResetBits(GPIOB,GPIO_Pin_13);                //預拉低trig引腳
        delay_ms(20);
        GPIO_SetBits(GPIOB,GPIO_Pin_13);
        delay_ms(20);
        GPIO_ResetBits(GPIOB,GPIO_Pin_13);//發出脈沖
        if(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_14)==0)//等待信號發出,信號發出,計數器置0,同時變為高電平
                TIM3->CNT=0;//清零
        if(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_14)==1)//等待信號接收,信號發出時,引腳一直置1
                time=TIM3->CNT;//獲取時間
                return time;
//以上是超聲波模塊的
ID:959346 發表于 2021-8-10 22:15 | 顯示全部樓層
1     while(i=0,i<5,i++)                 {                 t=T*170/1000;                 s=t+s;                 }里T不會變化,做5次沒有意義。
ID:959346 發表于 2021-8-10 22:21 | 顯示全部樓層
不知道你芯片型號,所以關于硬件初始化及操作的部分不清楚,邏輯的部分,下面建議供參考:
                t=T*170/1000;
                s=t+s;
      過程中T沒有變化。
2 if(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_14)==1)//等待信號接收,信號發出時,引腳一直置1
   這部分是否要用while?然后改一下條件?
3 建議你先把你參考的網上的程序完整的試一遍,確認可以了再模仿。
ID:660005 發表于 2021-8-11 11:00 | 顯示全部樓層
Jiang_YY 發表于 2021-8-10 22:21
1     while(i= ...
T不是被gettime這個函數賦值了嗎?為什么會沒得用,第二個用while還是if區別都不大吧,我都運行過,數值都沒得區別,第三個這個程序我都是抄的除了引腳改變了,基本沒得區別?所以我想不通為什么別人的可以運行,我的不行
芯片型號為stm32f103zet6,初始化部分用的正點原子的stm32f103的初始化部分
