查看: 7983|回復: 6
汽車總線sent協議轉RS232輸出單片機源程序
ID:214242 發表于 2017-6-24 13:35 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
將汽車總線sent協議內容通過RS232方式輸出。程序使用C8051F340芯片。
  1. //串口通迅實驗,將該程序的HEX下載到開發板,用串口調試助手軟件波特率設為9600
  2. //發送任意一個字符,單片機返回該字符的ASII碼
  3. //-----------------------------------------------------------------------------
  4. // Includes
  5. //-----------------------------------------------------------------------------
  6. #include <c8051f340.h>                 // SFR declarations
  7. #include <stdio.h>
  8. //-----------------------------------------------------------------------------
  9. // Global CONSTANTS
  10. //-----------------------------------------------------------------------------
  11. #define SYSCLK      22118400           // SYSCLK frequency in Hz
  12. #define BAUDRATE    9600           // Baud rate of UART in bps
  13. sbit led1=P2^2;
  14. sbit led2=P2^3;
  15. sbit P20=P2^0;
  16. //-----------------------------------------------------------------------------
  17. // Function PROTOTYPES
  18. //-----------------------------------------------------------------------------
  19. void SYSCLK_Init (void);
  20. void UART0_Init (void);
  21. void PORT_Init (void);
  22. void Timer0_Init (int);
  23. void Ext_Interrupt_Init (void);
  24. void INT1_ISR (void);
  25. void Timer0_init (void);
  26. unsigned int data count,tick,tickTemp,i,type;
  27. unsigned int data dataR[20] ;
  28. unsigned short data Sent=0,i;
  29. bit data flagR,flag2,flagp01;
  30. //-----------------------------------------------------------------------------
  31. // MAIN Routine
  32. //-----------------------------------------------------------------------------
  33. void main (void)
  34. {
  35.    flag2=0;
  36.    PORT_Init();                                            // Initialize Port I/O
  37.    PCA0MD &= ~0x40;                    // WDTE = 0 (clear watchdog timer
  38.    SYSCLK_Init ();                     // Initialize Oscillator
  39.    Ext_Interrupt_Init();                                    // enable)
  40.    led1=1;
  41.    led2=0;
  42.    UART0_Init();
  43.    Timer0_init();
  44.    EA=1;
  45.    while (1)
  46.    {
  47.       if(flag2||P20==0)
  48.            {
  49.             EA=0;
  50.              printf("angle= %f\n",(dataR[1]*256+dataR[2]*16+dataR[3])*283.0/4095);
  51.                  led2=~led2;
  52.                  Sent=0;
  53.                  type=0;
  54.                  flag2=0;
  55.                 EA=1;
  56.                 }
  57.    }
  58. }
  59. //-----------------------------------------------------------------------------
  60. // PORT_Init
  61. //-----------------------------------------------------------------------------
  62. //
  63. // P0.4   digital   push-pull    UART TX
  64. // P0.5   digital   open-drain   UART RX
  65. //
  66. //-----------------------------------------------------------------------------
  67. void PORT_Init (void)
  68. {
  69.    P0MDIN  &=~0xc0 ;
  70.    P0MDOUT |= 0x10;                    // Enable UTX as push-pull output
  71.    XBR0     = 0x01;                    // Enable UART on P0.4(TX) and P0.5(RX)
  72.    XBR1     = 0x40;                    // Enable crossbar and weak pull-ups
  73.    P2MDOUT |= 0x0c;
  74. }
  75. //-----------------------------------------------------------------------------
  76. // SYSCLK_Init
  77. //-----------------------------------------------------------------------------
  78. //
  79. // Return Value : None
  80. // Parameters   : None
  81. //
  82. // This routine initializes the system clock to use the internal oscillator
  83. // at its maximum frequency.
  84. // Also enables the Missing Clock Detector.
  85. //-----------------------------------------------------------------------------
  86. void SYSCLK_Init (void)                   //初始化系統時鐘
  87. {
  88.            //int i=0;
  89.           unsigned short data dly=0,dlyb=12;
  90.         //------------------------------------
  91.         //使能外部振蕩器
  92.         OSCXCN |=0X67;                //0110 0111
  93.                 dlyb=22;
  94.         do {
  95.                 dly=120;
  96.                 while(dly--);
  97.                  }while(dlyb--);
  98.         //等待1毫秒
  99.         do{
  100.                dly=100;
  101.                          while(dly--);
  102.        }while((OSCXCN&0X80)!=0X80);
  103.         //查詢XTLVLD =>1。
  104.         dly=100;
  105.         while(dly--);
  106.         CLKSEL |=0X01;
  107.        // OSCICN    = 0x00;
  108. }
  109. void Timer0_init (void)
  110. {
  111.
  112.    CKCON |=0X04;
  113.    TL0 = TH0=190;                          // Init Timer1
  114.    TMOD &= ~0x0f;                      // TMOD: timer 1 in 8-bit autoreload
  115.    TMOD |=  0x02;
  116.    TR0 = 1;                            // START Timer1
  117.    ET0=1;
  118. }
  119. //-----------------------------------------------------------------------------
  120. // UART0_Init
  121. //-----------------------------------------------------------------------------
  122. //
  123. // Configure the UART0 using Timer1, for <BAUDRATE> and 8-N-1.
  124. //-----------------------------------------------------------------------------
  125. void UART0_Init (void)
  126. {
  127.    SCON0 = 0x10;                       // SCON0: 8-bit variable bit rate
  128.                                        //        level of STOP bit is ignored
  129.                                        //        RX enabled
  130.                                        //        ninth bits are zeros
  131.                                        //        clear RI0 and TI0 bits
  132.    //TH1 = 256-(SYSCLK/BAUDRATE/2/12);
  133.    TH1=256-96;
  134.   // CKCON &=~0x0c;
  135.   // CKCON |= 0x00;                  // T1M = 1; SCA1:0 = 00
  136.    TL1 = TH1;                          // Init Timer1
  137.    TMOD &= ~0xf0;                      // TMOD: timer 1 in 8-bit autoreload
  138.    TMOD |=  0x20;
  139.    TR1 = 1;                            // START Timer1
  140.    TI0 = 1;                            // Indicate TX0 ready
  141. }
  142. void Ext_Interrupt_Init (void)
  143. {
  144.    TCON |= 0x05;                        // /INT 0 and /INT 1 are edge triggered
  145.    IT01CF = 0x10;                      // /INT0 active low; /INT0 on P0.0;
  146.                                        // /INT1 active low; /INT1 on P0.1
  147.    EX0 = 1;                            // Enable /INT0 interrupts
  148.    EX1 = 1;                            // Enable /INT1 interrupts
  149. }
  150. void INT1_ISR (void) interrupt 2
  151. {
  152.
  153.         //同步計時器
  154.         TR0 = 0;
  155.         TL0 = TH0=191;
  156.     TR0 = 1;                            // START Timer1
  157. //
  158.          if(tick>=34) tick=0;
  159.         //flagp01=P0^1;
  160.         tickTemp=tick;
  161.          tick=0;
  162.         if(flagR&&(Sent<=9)&&(tickTemp>=11)&&(tickTemp<=28))
  163.       {
  164.             dataR[Sent]=tickTemp-11;
  165.         Sent++;
  166.            }
  167.
  168.         if(flagR&&(Sent>=8))
  169.             {
  170.                 Sent=0;
  171.                 flagR=0;
  172.                 flag2=1;
  173.                 }
  174. //         if((tickTemp<10)||(tickTemp>28))
  175. ……………………
  176. …………限于本文篇幅 余下代碼請從51黑下載附件…………
Sent協議轉RS232.rar (40.53 KB, 下載次數: 79)
收藏收藏2 分享淘帖 頂 踩
ID:450798 發表于 2018-12-20 15:37 | 只看該作者
剛好要用到,學習下!
ID:529487 發表于 2019-5-7 13:34 | 只看該作者
支持
ID:600602 發表于 2019-8-15 22:44 | 只看該作者
支持一下,不知道有沒有參考價值
ID:468262 發表于 2020-11-24 10:53 | 只看該作者
tick=0;    // ?    tick 不是恒定 3us 或 3.3us , 為什么要清0?
ID:468262 發表于 2020-11-24 14:38 | 只看該作者
本帖最后由 wwbiu 于 2020-11-24 15:45 編輯
幫看一下,我要抓到SENT信號的8個數據,其中6個用來解碼,怎么改?
if(INT2IF)                                                 //下降沿中斷,每個節拍計數 1/16us
      SENT.table[0]=TMR3L;                       // 抓到的數值
      SENT.table[1]=TMR3H;                       //SENT:168us=2688個計數 <- 同步較準信號
      TMR3H=0;                                         //         36us =576 個計數 <- 0
      TMR3L=0;                                         //          81us =1296個計數 <- 15
      if(SENT.x>2500){SENT_flag=1;SENT_CNT=0;}  //同步較準信號到來后,設定標記
      if((SENT_flag==1)&&(SENT_CNT<9)&&(SENT.x>500)&&(SENT.x<1350)) //濾波
         SENT_CNT++;
         SENT_data[SENT_CNT]=SENT.x;                  //保存抓取到的8個數字信號
         if(SENT_CNT>=9)
            SENT_CNT=0;            SENT_flag=2;
       if(SENT_flag=2)                                              //解碼,
           tps1=((SENT_data[1]&0x0F)*256)+((SENT_data[2]&0x0F)*16)+(SENT_data[3]&0x0F);           tps2=((SENT_data[6]&0x0F)*256)+((SENT_data[5]&0x0F)*16)+(SENT_data[4]&0x0F);
           SENT_flag=0;                           //從頭開始
      INT2IF=0;
      TMR3IF=0;
   if(TMR3IF)TMR3IF=0;
ID:432835 發表于 2022-5-12 09:09 | 只看該作者
STC89C52單片機可以解析嗎?
