查看: 7881|回復: 0
基于51單片機的計時器的設計
ID:212540 發表于 2017-6-19 13:13 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
計時器573.rar (39.5 KB, 下載次數: 12)
單片機代碼:
  1. #include<reg51.h>
  2. #include<intrins.h>
  4. #define uint unsigned int
  5. #define ucint unsigned long int
  6. uchar A1,A2,A3,A4,A5,A6;
  7. uchar B1,B2,B3,B4,B5,B6;
  8. uchar C1,C2,C3,C4,C5,C6;
  9. uchar D1,D2,D3,D4,D5,D6;
  10. uint  DZ,num,choice,time1,time2,time3,time4,time5,time6,m,beepten,pause;
  11. uchar roll;
  12. sbit led1=P1^0;
  13. sbit led2=P1^1;
  14. sbit led3=P1^2;
  15. sbit led4=P1^3;
  16. sbit led5=P1^4;
  17. sbit dula=P2^6;
  18. sbit wela=P2^7;
  19. sbit beep=P2^3;
  20. sbit dian=P1^5;
  21. sbit key1=P3^4;
  22. sbit key2=P3^5;
  23. sbit key3=P3^6;
  24. sbit key4=P3^7;
  25. sbit key5=P3^2;
  26. uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x0f};//數字編碼
  27. uchar code led[]={0xdf,0xef,0xf7,0xfb,0xfd,0xfe};//位編碼
  28. void delay(unsigned char x)//延時子程序
  29. {
  30. unsigned char i,j;
  31. for(i=0;i<x;i++)
  32. for(j=0;j<x;j++);
  33. }
  34. void InitTimer0()
  35. {
  36.     TMOD = 0x01;
  37.     TH0 = 0x3C;
  38.     TL0 = 0x0B0;
  39.     EA = 1;
  40.     ET0 = 1;
  41.     TR0 = 1;
  42. }
  43. void display(uchar swan_c,uchar wan_c,uchar qian_c,uchar bai_c,uchar sh_c,uchar g_c) //顯示函數
  44. {
  45. wela=1;
  46. P0=led[0];
  47. wela=0;
  48. P0=0xff;//數碼管消隱1
  49. dula=1;
  50. P0=table[g_c];
  51. dula=0;
  52. delay(10);
  53. P0=0xff;//數碼管消隱2
  54. wela=1;
  55. P0=led[1];
  56. wela=0;
  57. P0=0xff;//數碼管消隱3
  58. dula=1;
  59. P0=table[sh_c];
  60. dula=0;
  61. delay(20);
  62. P0=0xff;//數碼管消隱4
  63. wela=1;
  64. P0=led[2];
  65. wela=0;
  66. P0=0xff;//數碼管消隱5
  67. dula=1;
  68. P0=table[bai_c];
  69. dula=0;
  70. delay(10);
  71. P0=0xff;//數碼管消隱6
  72. if(roll==0)        //點位顯示
  73. {
  74. wela=1;
  75. P0=led[2];
  76. wela=0;
  77. P0=0xff;//數碼管消隱
  78. dula=1;
  79. P0=0x80;
  80. dula=0;
  81. delay(10);
  82. P0=0xff;//數碼管消隱
  83. }
  84. wela=1;
  85. P0=led[3];
  86. wela=0;
  87. P0=0xff;//數碼管消隱7
  88. dula=1;
  89. P0=table[qian_c];
  90. dula=0;
  91. delay(10);
  92. P0=0xff;//數碼管消隱8
  93. wela=1;
  94. P0=led[4];
  95. wela=0;
  96. P0=0xff;//數碼管消隱9
  97. dula=1;
  98. P0=table[wan_c];
  99. dula=0;
  100. delay(10);
  101. P0=0xff;//數碼管消隱10
  102. if(roll==0)//點位顯示
  103. {
  104. wela=1;
  105. P0=led[4];
  106. wela=0;
  107. P0=0xff;//數碼管消隱
  108. dula=1;
  109. P0=0x80;
  110. dula=0;
  111. delay(10);
  112. P0=0xff;//數碼管消隱
  113. }
  114. wela=1;
  115. P0=led[5];
  116. wela=0;
  117. P0=0xff;//數碼管消隱11
  118. dula=1;
  119. P0=table[swan_c];
  120. dula=0;
  121. delay(10);
  122. P0=0xff;//數碼管消隱12
  123. }
  124. void adjustjstime()         //計時時間調整
  125. {
  126. if((m==0)&&(pause==0))
  127. {
  128. if(key2==0)
  129. {
  130. delay(50);
  131. EA=0;
  132. ET0=0;
  133. TR0=0;
  134. choice++;
  135. while(!key2)display(A1,A2,A3,A4,A5,A6);
  136. }
  137. EA=1;
  138. ET0=1;
  139. TR0=1;
  140. if(choice>3)choice=1;
  141. if(choice==1)
  142. {
  143. led1=0;
  144. led2=1;
  145. led3=1;
  146. if(key3==0)
  147. {
  148. delay(50);
  149. EA=0;
  150. ET0=0;
  151. TR0=0;
  152. A6++;
  153. if(A6>9)
  154. {
  155. A5++;
  156. A6=0;
  157. }
  158. if(A5>=6)A5=0;
  159. while(!key3)display(A1,A2,A3,A4,A5,A6);
  160. }
  161. EA=1;
  162. ET0=1;
  163. TR0=1;
  164. }
  165. if(choice==2)
  166. {
  167. led1=1;
  168. led2=0;
  169. led3=1;
  170. if(key3==0)
  171. {
  172. delay(50);
  173. EA=0;
  174. ET0=0;
  175. TR0=0;
  176. A4++;
  177. if(A4>9)
  178. {
  179. A3++;
  180. A4=0;
  181. }
  182. if(A3>=6)A3=0;
  183. while(!key3)display(A1,A2,A3,A4,A5,A6);
  184. }
  185. EA=1;
  186. ET0=1;
  187. TR0=1;
  188. }
  189. if(choice==3)
  190. {
  191. led1=1;
  192. led2=1;
  193. led3=0;
  194. if(key3==0)
  195. {
  196. delay(50);
  197. EA=0;
  198. ET0=0;
  199. TR0=0;
  200. A2++;
  201. if(A2>9)
  202. {
  203. A1++;
  204. A2=0;
  205. }
  206. if(A1>9)A1=0;
  207. while(!key3)display(A1,A2,A3,A4,A5,A6);
  208. }
  209. EA=1;
  210. ET0=1;
  211. TR0=1;
  212. }
  213. display(A1,A2,A3,A4,A5,A6);
  214. if(DZ==1)
  215. {
  216. led4=0;
  217. led5=1;
  218. }
  219. if(DZ==2)
  220. {
  221. led4=1;
  222. led5=0;
  223. }
  224. time1=A6+(A5*10);
  225. time2=A4+(A3*10);
  226. time3=A2+(A1*10);
  227. beep=1;
  228. time4=0;
  229. time5=0;
  230. time6=0;
  231. }
  232. if((m==0)&&(pause==1))
  233. {
  234. if(DZ==0)
  235. {
  236. choice=0;
  237. led1=0;
  238. led2=0;
  239. led3=0;
  240. led4=0;
  241. led5=0;
  242. display(A1,A2,A3,A4,A5,A6);
  243. }
  244. if(DZ==1)
  245. {
  246. choice=0;
  247. led1=1;
  248. led2=1;
  249. led3=1;
  250. led4=0;
  251. led5=1;
  252. B5=time4/10;
  253. B6=time4%10;
  254. B3=time5/10;
  255. B4=time5%10;
  256. B1=time6/10;
  257. B2=time6%10;
  258. display(B1,B2,B3,B4,B5,B6);
  259. }
  260. if(DZ==2)
  261. {
  262. choice=0;
  263. led1=1;
  264. led2=1;
  265. led3=1;
  266. led4=1;
  267. led5=0;
  268. C5=time1/10;
  269. C6=time1%10;
  270. C3=time2/10;
  271. C4=time2%10;
  272. C1=time3/10;
  273. C2=time3%10;
  274. display(C1,C2,C3,C4,C5,C6);
  275. }
  276. }
  277. }
  278. void Zstimedisplay()//正計時函數顯示函數
  279. {
  280. if(m==1)
  281. {
  282. if(DZ==1)
  283. {
  284. choice=0;
  285. led1=1;
  286. led2=1;
  287. led3=1;
  288. pause=1;
  289. B5=time4/10;
  290. B6=time4%10;
  291. B3=time5/10;
  292. B4=time5%10;
  293. B1=time6/10;
  294. B2=time6%10;
  295. display(B1,B2,B3,B4,B5,B6);
  296. }
  297. }
  298. }
  299. void Zstime() //正計時函數
  300. {
  301. if(m==1)
  302. {
  303. if(DZ==1)
  304. {
  305. ++time4;
  306. if(time4==60)
  307. {
  308. time4=0;
  309. time5++;
  310. if(time5==60)
  311. {
  312. time5=0;
  313. time6++;
  314. }
  315. }
  316. if((time1==time4)&&(time2==time5)&&(time3==time6))m=2;
  317. led4=!led4;
  318. }
  319. }
  320. }
  321. void Dstimedisplay() //倒計時顯示函數
  322. {
  323. if(m==1)
  324. {
  325. if(DZ==2)
  326. {
  327. choice=0;
  328. led1=1;
  329. led2=1;
  330. led3=1;
  331. pause=1;
  332. C5=time1/10;
  333. C6=time1%10;
  334. C3=time2/10;
  335. C4=time2%10;
  336. C1=time3/10;
  337. C2=time3%10;
  338. display(C1,C2,C3,C4,C5,C6);
  339. }
  340. }
  341. }
  342. void Dstime()//倒計時函數
  343. {
  344. if(m==1)
  345. {
  346. if(DZ==2)
  347. {
  348. if(time1==0)
  349. {
  350. time1=60;
  351. if(time2==0)
  352. {
  353. time2=60;
  354. time3--;
  355. }
  356. time2--;
  357. }
  358. --time1;
  359. if((time1||time2||time3)==0)m=2;
  360. led5=!led5;
  361. }
  362. }
  363. }
  364. void ZDdisplay()//函數計時結束顯示
  365. {
  366. if(m==2)
  367. {
  368. pause=0;
  369. if(DZ==1)
  370. {
  371. if(beepten==20)
  372. {
  373. m=0;
  374. beepten=0;
  375. }
  376. choice=0;
  377. B5=time4/10;
  378. B6=time4%10;
  379. B3=time5/10;
  380. B4=time5%10;
  381. B1=time6/10;
  382. B2=time6%10;
  383. display(B1,B2,B3,B4,B5,B6);
  384. }
  385. if(DZ==2)
  386. {
  387. if(beepten==20)
  388. {
  389. m=0;
  390. beepten=0;
  391. }
  392. choice=0;
  393. C5=time1/10;
  394. C6=time1%10;
  395. C3=time2/10;
  396. C4=time2%10;
  397. C1=time3/10;
  398. C2=time3%10;
  399. display(C1,C2,C3,C4,C5,C6);
  400. }
  401. }
  402. }
  403. void startpause()//開始暫停函數
  404. {
  405. if(DZ!=0)
  406. {
  407. if(key4==0)
  408. {
  409. delay(50);
  410. EA=0;
  411. ET0=0;
  412. TR0=0;
  413. m++;
  414. if(m>=2)
  415. {
  416. m=0;
  417. led1=1;
  418. led2=1;
  419. led3=1;
  420. }
  421. while(!key4)
  422. {
  423. if((m==0)&&(pause==0))display(A1,A2,A3,A4,A5,A6);
  424. if(DZ==1)display(B1,B2,B3,B4,B5,B6);
  425. if(DZ==2)display(C1,C2,C3,C4,C5,C6);
  426. }
  427. }
  428. EA=1;
  429. ET0=1;
  430. TR0=1;
  431. }
  432. }
  433. void ZDJ()//正倒計調整函數
  434. {
  435. if(m==0)
  436. {
  437. if(key1==0)
  438. {
  439. delay(50);
  440. EA=0;
  441. ET0=0;
  442. TR0=0;
  443. DZ++;
  444. if(DZ>=3)
  445. {
  446. DZ=0;
  447. led4=1;
  448. led5=1;
  449. }
  450. if(DZ==1)
  451. {
  452. led4=0;
  453. led5=1;
  454. }
  455. if(DZ==2)
  456. {
  457. led4=1;
  458. led5=0;
  459. }
  460. while(!key1)
  461. {
  462. if(DZ==0)display(A1,A2,A3,A4,A5,A6);
  463. if(DZ==1)display(B1,B2,B3,B4,B5,B6);
  464. if(DZ==2)display(C1,C2,C3,C4,C5,C6);
  465. }
  466. }
  467. EA=1;
  468. ET0=1;
  469. TR0=1;
  470. }
  471. }
  472. void adjustjd()//精度調整函數
  473. {
  474. if(num==20)
  475. {
  476. num=0;
  477. Zstime();
  478. Dstime();
  479. if(m==2)
  480. {
  481. beepten++;
  482. beep=!beep;
  483. led1=!led1;
  484. led2=!led2;
  485. led3=!led3;
  486. }
  487. roll=!roll;
  488. dian=!dian;
  489. }
  490. }
  491. void main() //主函數
  492. {
  493. InitTimer0();
  494. key5=0;
  495. while(1)
  496. {
  497. adjustjstime();
  498. Zstimedisplay();
  499. Dstimedisplay();
  500. startpause();
  501. adjustjd();
  502. ZDJ();
  503. ZDdisplay();
  504. }
  505. }
  506. void Timer0Interrupt() interrupt 1
  507. {
  508.     TH0 = 0x3C;
  509.     TL0 = 0x0B0;
  510.     num++;
  511. }
